[pdal-commits] [PDAL/PDAL] b33d1c: Improve writers.gdal doc.
Andrew Bell noreply at github.com
Fri Mar 8 09:15:54 PST 2019
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: b33d1cd80078222f20cf57a928ddb77a8ba0ae0b
      https://github.com/PDAL/PDAL/commit/b33d1cd80078222f20cf57a928ddb77a8ba0ae0b
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2019-03-08 (Fri, 08 Mar 2019)
  Changed paths:
    M doc/stages/writers.gdal.rst
  Log Message:
  Commit: 4ec3d665702c6bec5b35a6ff390386977ac3445d
      https://github.com/PDAL/PDAL/commit/4ec3d665702c6bec5b35a6ff390386977ac3445d
  Changed paths:
    A .clang-format
    M .gitignore
    M CMakeLists.txt
    M CONTRIBUTING.md
    M apps/CMakeLists.txt
    M appveyor.yml
    M cmake/examples/hobu-config.sh
    M cmake/gdal.cmake
    R cmake/geos.cmake
    R cmake/modules/FindGDAL.cmake
    R cmake/modules/FindGEOS.cmake
    A cmake/modules/FindTileDB.cmake
    M cmake/options.cmake
    M cmake/python.cmake
    A cmake/tiledb.cmake
    M doc/development/compilation/dependencies.rst
    M doc/development/compilation/windows.rst
    M doc/quickstart.rst
    M doc/stages/readers.ept.rst
    M doc/stages/readers.sbet.rst
    A doc/stages/readers.tiledb.rst
    A doc/stages/writers.ept_addon.rst
    M doc/stages/writers.sbet.rst
    A doc/stages/writers.tiledb.rst
    M doc/workshop/docker.rst.save
    M doc/workshop/includes/substitutions.rst
    M doc/workshop/osgeo4w.rst
    M filters/CropFilter.cpp
    M filters/HexBinFilter.cpp
    M filters/NormalFilter.cpp
    M filters/OverlayFilter.cpp
    M filters/OverlayFilter.hpp
    M filters/SplitterFilter.cpp
    M filters/StatsFilter.cpp
    M filters/private/Point.cpp
    M filters/private/Point.hpp
    A io/EptAddonWriter.cpp
    A io/EptAddonWriter.hpp
    M io/EptReader.cpp
    M io/EptReader.hpp
    M io/Ilvis2MetadataReader.cpp
    M io/Ilvis2MetadataReader.hpp
    M io/SbetCommon.hpp
    M io/SbetReader.cpp
    M io/SbetReader.hpp
    M io/SbetWriter.cpp
    M io/SbetWriter.hpp
    M io/private/EptSupport.hpp
    M pdal/GDALUtils.cpp
    M pdal/GDALUtils.hpp
    R pdal/GEOSUtils.cpp
    R pdal/GEOSUtils.hpp
    M pdal/Geometry.cpp
    M pdal/Geometry.hpp
    M pdal/Polygon.cpp
    M pdal/Polygon.hpp
    M pdal/Stage.cpp
    M pdal/StageFactory.cpp
    M pdal/pdal_config.cpp
    M pdal/util/Utils.hpp
    M plugins/CMakeLists.txt
    M plugins/geowave/io/GeoWaveReader.hpp
    M plugins/pcl/CMakeLists.txt
    M plugins/rdb/CMakeLists.txt
    M plugins/sqlite/CMakeLists.txt
    A plugins/tiledb/CMakeLists.txt
    A plugins/tiledb/io/TileDBReader.cpp
    A plugins/tiledb/io/TileDBReader.hpp
    A plugins/tiledb/io/TileDBWriter.cpp
    A plugins/tiledb/io/TileDBWriter.hpp
    A plugins/tiledb/test/TileDBReaderTest.cpp
    A plugins/tiledb/test/TileDBWriterTest.cpp
    R scripts/appveyor/build.cmd
    A scripts/appveyor/conda/build.cmd
    A scripts/appveyor/conda/recipe/bld.bat
    A scripts/appveyor/conda/recipe/build.sh
    A scripts/appveyor/conda/recipe/meta.yaml
    A scripts/appveyor/conda/recipe/scripts/activate.bat
    A scripts/appveyor/conda/recipe/scripts/activate.sh
    A scripts/appveyor/conda/recipe/scripts/deactivate.bat
    A scripts/appveyor/conda/recipe/scripts/deactivate.sh
    M scripts/appveyor/config.cmd
    R scripts/appveyor/install.cmd
    R scripts/appveyor/test.cmd
    A scripts/appveyor/test/build.cmd
    A scripts/appveyor/test/test.cmd
    M scripts/conda/osx.sh
    M scripts/conda/win64.sh
    M scripts/docker/Dockerfile
    R scripts/docker/Dockerfile.alpinedeps
    M scripts/docker/alpine/Dockerfile.dependencies
    R scripts/docker/master/alpine/Dockerfile
    R scripts/docker/master/ubuntu/Dockerfile
    M scripts/docker/ubuntu/Dockerfile
    M scripts/docker/ubuntu/dependencies/Dockerfile
    M scripts/linux-install-scripts/packages.sh
    M test/data/pipeline/crop_wkt.json.in
    A test/data/tiledb/array/__7683a2d8dd0b48ae809dd3f1a9501da4_1549556043355/OffsetTime.tdb
    A test/data/tiledb/array/__7683a2d8dd0b48ae809dd3f1a9501da4_1549556043355/__coords.tdb
    A test/data/tiledb/array/__7683a2d8dd0b48ae809dd3f1a9501da4_1549556043355/__fragment_metadata.tdb
    A test/data/tiledb/array/__array_schema.tdb
    A test/data/tiledb/array/__lock.tdb
    M test/unit/CMakeLists.txt
    M test/unit/PolygonTest.cpp
    M test/unit/SpatialReferenceTest.cpp
    M test/unit/filters/SplitterTest.cpp
    A test/unit/io/EptAddonWriterTest.cpp
    M test/unit/io/SbetReaderTest.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master'
Compare: https://github.com/PDAL/PDAL/compare/4036086a303d...4ec3d665702c
More information about the pdal-commits mailing list
