[pdal-commits] [PDAL/PDAL] 888e25: ICP debug.
Andrew Bell noreply at github.com
Tue Mar 12 13:49:11 PDT 2019
  Branch: refs/heads/issue-2318
  Home:   https://github.com/PDAL/PDAL
  Commit: 888e25385951fa2ffd35fca5110b897359284f44
      https://github.com/PDAL/PDAL/commit/888e25385951fa2ffd35fca5110b897359284f44
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2018-12-17 (Mon, 17 Dec 2018)
  Changed paths:
    M plugins/pcl/filters/IcpFilter.cpp
    M plugins/pcl/test/IcpFilterTest.cpp
  Log Message:
  ICP debug.
  Commit: 3dc615fb7aa6990e031e57ffc5e29a71d3c151e5
      https://github.com/PDAL/PDAL/commit/3dc615fb7aa6990e031e57ffc5e29a71d3c151e5
  Date:   2018-12-18 (Tue, 18 Dec 2018)
  Changed paths:
  Log Message:
  Use the correct call to set the base point cloud.
  Commit: 0abfb94bc871466dbf05b88b1c8b2da24dfea19c
      https://github.com/PDAL/PDAL/commit/0abfb94bc871466dbf05b88b1c8b2da24dfea19c
  Date:   2019-03-12 (Tue, 12 Mar 2019)
  Changed paths:
    A .clang-format
    M .gitignore
    M CMakeLists.txt
    M CONTRIBUTING.md
    M HOWTORELEASE.txt
    M README.md
    M apps/CMakeLists.txt
    M appveyor.yml
    M cmake/config.cmake
    M cmake/examples/hobu-config.sh
    M cmake/gdal.cmake
    R cmake/geos.cmake
    M cmake/macros.cmake
    R cmake/modules/FindGDAL.cmake
    R cmake/modules/FindGEOS.cmake
    M cmake/modules/FindGeoTIFF.cmake
    A cmake/modules/FindTileDB.cmake
    M cmake/options.cmake
    M cmake/python.cmake
    A cmake/tiledb.cmake
    M doc/development/compilation/dependencies.rst
    M doc/development/compilation/windows.rst
    M doc/pipeline.rst
    M doc/quickstart.rst
    M doc/references.rst
    M doc/stages/filters.delaunay.rst
    M doc/stages/readers.ept.rst
    M doc/stages/readers.i3s.rst
    M doc/stages/readers.rxp.rst
    M doc/stages/readers.sbet.rst
    A doc/stages/readers.tiledb.rst
    M doc/stages/readers.tindex.rst
    A doc/stages/writers.ept_addon.rst
    M doc/stages/writers.gdal.rst
    M doc/stages/writers.ply.rst
    M doc/stages/writers.sbet.rst
    A doc/stages/writers.tiledb.rst
    M doc/workshop/docker.rst.save
    M doc/workshop/includes/substitutions.rst
    M doc/workshop/osgeo4w.rst
    M filters/CropFilter.cpp
    A filters/DelaunayFilter.cpp
    A filters/DelaunayFilter.hpp
    M filters/HexBinFilter.cpp
    M filters/NormalFilter.cpp
    M filters/OverlayFilter.cpp
    M filters/OverlayFilter.hpp
    M filters/SplitterFilter.cpp
    M filters/StatsFilter.cpp
    M filters/private/Point.cpp
    M filters/private/Point.hpp
    A filters/private/delaunator.hpp
    A io/EptAddonWriter.cpp
    A io/EptAddonWriter.hpp
    M io/EptReader.cpp
    M io/EptReader.hpp
    R io/GDALGrid.cpp
    R io/GDALGrid.hpp
    M io/GDALWriter.cpp
    M io/GDALWriter.hpp
    M io/Ilvis2MetadataReader.cpp
    M io/Ilvis2MetadataReader.hpp
    M io/LasWriter.cpp
    M io/LasWriter.hpp
    M io/PtsReader.cpp
    M io/SbetCommon.hpp
    M io/SbetReader.cpp
    M io/SbetReader.hpp
    M io/SbetWriter.cpp
    M io/SbetWriter.hpp
    M io/TIndexReader.cpp
    M io/private/EptSupport.hpp
    A io/private/GDALGrid.cpp
    A io/private/GDALGrid.hpp
    M kernels/SplitKernel.cpp
    M pdal/GDALUtils.cpp
    M pdal/GDALUtils.hpp
    R pdal/GEOSUtils.cpp
    R pdal/GEOSUtils.hpp
    M pdal/Geometry.cpp
    M pdal/Geometry.hpp
    M pdal/PluginDirectory.cpp
    M pdal/Polygon.cpp
    M pdal/Polygon.hpp
    M pdal/Reader.cpp
    M pdal/Stage.cpp
    M pdal/StageFactory.cpp
    M pdal/compression/ZstdCompression.cpp
    M pdal/compression/ZstdCompression.hpp
    M pdal/pdal_config.cpp
    M pdal/util/FileUtils.cpp
    M pdal/util/Utils.hpp
    M plugins/CMakeLists.txt
    M plugins/cpd/CMakeLists.txt
    R plugins/delaunay/CMakeLists.txt
    R plugins/delaunay/filters/DelaunayFilter.cpp
    R plugins/delaunay/filters/DelaunayFilter.hpp
    R plugins/delaunay/filters/Delaunay_psm.cpp
    R plugins/delaunay/filters/Delaunay_psm.h
    M plugins/fbx/CMakeLists.txt
    M plugins/geowave/io/GeoWaveReader.hpp
    M plugins/greyhound/CMakeLists.txt
    M plugins/i3s/CMakeLists.txt
    M plugins/i3s/io/EsriReader.cpp
    M plugins/i3s/io/EsriReader.hpp
    M plugins/icebridge/CMakeLists.txt
    M plugins/matlab/CMakeLists.txt
    M plugins/mbio/CMakeLists.txt
    M plugins/mrsid/CMakeLists.txt
    M plugins/nitf/CMakeLists.txt
    M plugins/oci/CMakeLists.txt
    M plugins/openscenegraph/CMakeLists.txt
    M plugins/pcl/CMakeLists.txt
    M plugins/pgpointcloud/CMakeLists.txt
    M plugins/python/filters/CMakeLists.txt
    M plugins/python/filters/PythonFilter.cpp
    M plugins/python/io/CMakeLists.txt
    M plugins/python/plang/Environment.cpp
    M plugins/python/plang/Invocation.cpp
    M plugins/python/test/PythonFilterTest.cpp
    M plugins/rdb/CMakeLists.txt
    M plugins/rxp/CMakeLists.txt
    M plugins/rxp/io/RxpPointcloud.cpp
    M plugins/rxp/io/RxpPointcloud.hpp
    M plugins/rxp/io/RxpReader.cpp
    M plugins/rxp/io/RxpReader.hpp
    M plugins/sqlite/CMakeLists.txt
    A plugins/tiledb/CMakeLists.txt
    A plugins/tiledb/io/TileDBReader.cpp
    A plugins/tiledb/io/TileDBReader.hpp
    A plugins/tiledb/io/TileDBWriter.cpp
    A plugins/tiledb/io/TileDBWriter.hpp
    A plugins/tiledb/test/TileDBReaderTest.cpp
    A plugins/tiledb/test/TileDBWriterTest.cpp
    R scripts/appveyor/build.cmd
    A scripts/appveyor/conda/build.cmd
    A scripts/appveyor/conda/recipe/bld.bat
    A scripts/appveyor/conda/recipe/build.sh
    A scripts/appveyor/conda/recipe/meta.yaml
    A scripts/appveyor/conda/recipe/scripts/activate.bat
    A scripts/appveyor/conda/recipe/scripts/activate.sh
    A scripts/appveyor/conda/recipe/scripts/deactivate.bat
    A scripts/appveyor/conda/recipe/scripts/deactivate.sh
    M scripts/appveyor/config.cmd
    R scripts/appveyor/install.cmd
    R scripts/appveyor/test.cmd
    A scripts/appveyor/test/build.cmd
    A scripts/appveyor/test/test.cmd
    M scripts/conda/osx.sh
    M scripts/conda/win64.sh
    M scripts/docker/Dockerfile
    R scripts/docker/Dockerfile.alpinedeps
    M scripts/docker/alpine/Dockerfile.dependencies
    A scripts/docker/centos/Dockerfile
    R scripts/docker/master/alpine/Dockerfile
    R scripts/docker/master/ubuntu/Dockerfile
    M scripts/docker/ubuntu/Dockerfile
    M scripts/docker/ubuntu/dependencies/Dockerfile
    M scripts/linux-install-scripts/packages.sh
    M test/data/ept/ept-star/ept.json
    A test/data/filters/delaunaytest.txt
    A test/data/i3s/plineSonoma3.json
    A test/data/las/wontcompress3.las
    M test/data/pipeline/crop_wkt.json.in
    M test/data/plang/predicate-embed.json.in
    A test/data/pts/bunny_8.pts
    A test/data/pts/site_56_8.pts
    A test/data/tiledb/array/__7683a2d8dd0b48ae809dd3f1a9501da4_1549556043355/OffsetTime.tdb
    A test/data/tiledb/array/__7683a2d8dd0b48ae809dd3f1a9501da4_1549556043355/__coords.tdb
    A test/data/tiledb/array/__7683a2d8dd0b48ae809dd3f1a9501da4_1549556043355/__fragment_metadata.tdb
    A test/data/tiledb/array/__array_schema.tdb
    A test/data/tiledb/array/__lock.tdb
    M test/unit/CMakeLists.txt
    M test/unit/PolygonTest.cpp
    M test/unit/SpatialReferenceTest.cpp
    M test/unit/filters/CropFilterTest.cpp
    A test/unit/filters/DelaunayFilterTest.cpp
    M test/unit/filters/SplitterTest.cpp
    A test/unit/io/EptAddonWriterTest.cpp
    M test/unit/io/EptReaderTest.cpp
    M test/unit/io/GDALWriterTest.cpp
    M test/unit/io/LasWriterTest.cpp
    M test/unit/io/PtsReaderTest.cpp
    M test/unit/io/SbetReaderTest.cpp
    M vendor/arbiter/CMakeLists.txt
    M vendor/arbiter/README
    M vendor/arbiter/arbiter.cpp
    M vendor/arbiter/arbiter.hpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into issue-2318
Compare: https://github.com/PDAL/PDAL/compare/888e25385951%5E...0abfb94bc871
More information about the pdal-commits mailing list
