[pdal-commits] [PDAL/PDAL] 482599: Small updates and comments.
Andrew Bell noreply at github.com
Wed Mar 13 08:19:00 PDT 2019
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 482599f30c77ca6cf930dab7ffbb5f595d370d94
      https://github.com/PDAL/PDAL/commit/482599f30c77ca6cf930dab7ffbb5f595d370d94
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2019-02-11 (Mon, 11 Feb 2019)
  Changed paths:
    M pdal/EigenUtils.cpp
    M pdal/util/Extractor.hpp
    M pdal/util/IStream.hpp
  Log Message:
  Commit: 4dc47f781837b030c8edb35fbd8ebdfc6072bfbb
      https://github.com/PDAL/PDAL/commit/4dc47f781837b030c8edb35fbd8ebdfc6072bfbb
  Date:   2019-03-12 (Tue, 12 Mar 2019)
  Changed paths:
    M kernels/DensityKernel.cpp
  Log Message:
  Format fixes.  Remove dead code.
  Commit: 289d32038c29db40972c0ccf808256a8f1b8c37b
      https://github.com/PDAL/PDAL/commit/289d32038c29db40972c0ccf808256a8f1b8c37b
  Changed paths:
    M cmake/python.cmake
    M kernels/SplitKernel.cpp
    M pdal/PluginDirectory.cpp
    M pdal/util/FileUtils.cpp
    M pdal/util/Utils.hpp
    M plugins/python/filters/PythonFilter.cpp
    M plugins/python/plang/Environment.cpp
    M plugins/python/plang/Invocation.cpp
    M plugins/tiledb/io/TileDBReader.cpp
    M plugins/tiledb/io/TileDBReader.hpp
    M plugins/tiledb/io/TileDBWriter.cpp
    M plugins/tiledb/io/TileDBWriter.hpp
    M test/data/plang/predicate-embed.json.in
  Log Message:
  Merge remote-tracking branch 'origin/master'
  Commit: dee7d5847085e0aa02527ffacfbd56b260b83709
      https://github.com/PDAL/PDAL/commit/dee7d5847085e0aa02527ffacfbd56b260b83709
  Date:   2019-03-13 (Wed, 13 Mar 2019)
  Changed paths:
    A .clang-format
    M .gitignore
    M CMakeLists.txt
    M CONTRIBUTING.md
    M apps/CMakeLists.txt
    M appveyor.yml
    M cmake/examples/hobu-config.sh
    M cmake/gdal.cmake
    R cmake/geos.cmake
    R cmake/modules/FindGDAL.cmake
    R cmake/modules/FindGEOS.cmake
    A cmake/modules/FindTileDB.cmake
    M cmake/options.cmake
    A cmake/tiledb.cmake
    M doc/development/compilation/dependencies.rst
    M doc/development/compilation/windows.rst
    M doc/pipeline.rst
    M doc/quickstart.rst
    M doc/stages/readers.ept.rst
    M doc/stages/readers.sbet.rst
    A doc/stages/readers.tiledb.rst
    A doc/stages/writers.ept_addon.rst
    M doc/stages/writers.gdal.rst
    M doc/stages/writers.sbet.rst
    A doc/stages/writers.tiledb.rst
    M doc/workshop/docker.rst.save
    M doc/workshop/includes/substitutions.rst
    M doc/workshop/osgeo4w.rst
    M filters/CropFilter.cpp
    M filters/HexBinFilter.cpp
    M filters/NormalFilter.cpp
    M filters/OverlayFilter.cpp
    M filters/OverlayFilter.hpp
    M filters/SplitterFilter.cpp
    M filters/StatsFilter.cpp
    M filters/private/Point.cpp
    M filters/private/Point.hpp
    A io/EptAddonWriter.cpp
    A io/EptAddonWriter.hpp
    M io/EptReader.cpp
    M io/EptReader.hpp
    M io/Ilvis2MetadataReader.cpp
    M io/Ilvis2MetadataReader.hpp
    M io/SbetCommon.hpp
    M io/SbetReader.cpp
    M io/SbetReader.hpp
    M io/SbetWriter.cpp
    M io/SbetWriter.hpp
    M io/private/EptSupport.hpp
    M pdal/GDALUtils.cpp
    M pdal/GDALUtils.hpp
    R pdal/GEOSUtils.cpp
    R pdal/GEOSUtils.hpp
    M pdal/Geometry.cpp
    M pdal/Geometry.hpp
    M pdal/Polygon.cpp
    M pdal/Polygon.hpp
    M pdal/Stage.cpp
    M pdal/StageFactory.cpp
    M pdal/compression/ZstdCompression.cpp
    M pdal/compression/ZstdCompression.hpp
    M pdal/pdal_config.cpp
    M plugins/CMakeLists.txt
    M plugins/geowave/io/GeoWaveReader.hpp
    M plugins/i3s/io/EsriReader.cpp
    M plugins/i3s/io/EsriReader.hpp
    M plugins/pcl/CMakeLists.txt
    M plugins/python/test/PythonFilterTest.cpp
    M plugins/rdb/CMakeLists.txt
    M plugins/sqlite/CMakeLists.txt
    A plugins/tiledb/CMakeLists.txt
    A plugins/tiledb/io/TileDBReader.cpp
    A plugins/tiledb/io/TileDBReader.hpp
    A plugins/tiledb/io/TileDBWriter.cpp
    A plugins/tiledb/io/TileDBWriter.hpp
    A plugins/tiledb/test/TileDBReaderTest.cpp
    A plugins/tiledb/test/TileDBWriterTest.cpp
    R scripts/appveyor/build.cmd
    A scripts/appveyor/conda/build.cmd
    A scripts/appveyor/conda/recipe/bld.bat
    A scripts/appveyor/conda/recipe/build.sh
    A scripts/appveyor/conda/recipe/meta.yaml
    A scripts/appveyor/conda/recipe/scripts/activate.bat
    A scripts/appveyor/conda/recipe/scripts/activate.sh
    A scripts/appveyor/conda/recipe/scripts/deactivate.bat
    A scripts/appveyor/conda/recipe/scripts/deactivate.sh
    M scripts/appveyor/config.cmd
    R scripts/appveyor/install.cmd
    R scripts/appveyor/test.cmd
    A scripts/appveyor/test/build.cmd
    A scripts/appveyor/test/test.cmd
    M scripts/conda/osx.sh
    M scripts/conda/win64.sh
    M scripts/docker/Dockerfile
    R scripts/docker/Dockerfile.alpinedeps
    M scripts/docker/alpine/Dockerfile.dependencies
    A scripts/docker/centos/Dockerfile
    R scripts/docker/master/alpine/Dockerfile
    R scripts/docker/master/ubuntu/Dockerfile
    M scripts/docker/ubuntu/Dockerfile
    M scripts/docker/ubuntu/dependencies/Dockerfile
    M scripts/linux-install-scripts/packages.sh
    A test/data/i3s/plineSonoma3.json
    M test/data/pipeline/crop_wkt.json.in
    A test/data/tiledb/array/__7683a2d8dd0b48ae809dd3f1a9501da4_1549556043355/OffsetTime.tdb
    A test/data/tiledb/array/__7683a2d8dd0b48ae809dd3f1a9501da4_1549556043355/__coords.tdb
    A test/data/tiledb/array/__7683a2d8dd0b48ae809dd3f1a9501da4_1549556043355/__fragment_metadata.tdb
    A test/data/tiledb/array/__array_schema.tdb
    A test/data/tiledb/array/__lock.tdb
    M test/unit/CMakeLists.txt
    M test/unit/PolygonTest.cpp
    M test/unit/SpatialReferenceTest.cpp
    M test/unit/filters/SplitterTest.cpp
    A test/unit/io/EptAddonWriterTest.cpp
    M test/unit/io/SbetReaderTest.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into misc-updates
  Commit: 465d3ece961e34c8cc8bcf9935a579931f12301e
      https://github.com/PDAL/PDAL/commit/465d3ece961e34c8cc8bcf9935a579931f12301e
  Changed paths:
  Log Message:
  Merge branch 'misc-updates'
Compare: https://github.com/PDAL/PDAL/compare/4b95836cb9dc...465d3ece961e
More information about the pdal-commits mailing list
