[pdal-commits] [PDAL/PDAL] 679da0: EPT doesn't do count.
Andrew Bell noreply at github.com
Wed Mar 20 10:10:40 PDT 2019
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 679da05cd1e83c016f5ab81364cfc81e73f7a07e
      https://github.com/PDAL/PDAL/commit/679da05cd1e83c016f5ab81364cfc81e73f7a07e
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2019-03-20 (Wed, 20 Mar 2019)
  Changed paths:
    M doc/stages/readers.ept.rst
  Log Message:
  Commit: 00db7b8b5e5e001296bd14438a3ff2ad92f32097
      https://github.com/PDAL/PDAL/commit/00db7b8b5e5e001296bd14438a3ff2ad92f32097
  Changed paths:
    M .gitignore
    M appveyor.yml
    M cmake/examples/hobu-config.sh
    M cmake/gdal.cmake
    M cmake/python.cmake
    M doc/apps/tindex.rst
    M doc/pipeline.rst
    M doc/stages/readers.sbet.rst
    A doc/stages/writers.ept_addon.rst
    M doc/stages/writers.gdal.rst
    M doc/stages/writers.sbet.rst
    M filters/HeadFilter.hpp
    M filters/TailFilter.hpp
    M filters/private/Point.cpp
    M filters/private/Point.hpp
    A io/EptAddonWriter.cpp
    A io/EptAddonWriter.hpp
    M io/EptReader.cpp
    M io/EptReader.hpp
    M io/Ilvis2MetadataReader.cpp
    M io/SbetCommon.hpp
    M io/SbetReader.cpp
    M io/SbetReader.hpp
    M io/SbetWriter.cpp
    M io/SbetWriter.hpp
    M io/private/EptSupport.hpp
    M kernels/DensityKernel.cpp
    M kernels/SplitKernel.cpp
    M kernels/TIndexKernel.cpp
    M kernels/TIndexKernel.hpp
    M pdal/EigenUtils.cpp
    M pdal/GDALUtils.cpp
    M pdal/GDALUtils.hpp
    M pdal/Geometry.cpp
    M pdal/Geometry.hpp
    M pdal/Kernel.cpp
    M pdal/Kernel.hpp
    M pdal/PipelineManager.cpp
    M pdal/PluginDirectory.cpp
    M pdal/Polygon.cpp
    M pdal/Polygon.hpp
    M pdal/StageFactory.cpp
    A pdal/SubcommandKernel.cpp
    A pdal/SubcommandKernel.hpp
    M pdal/compression/ZstdCompression.cpp
    M pdal/compression/ZstdCompression.hpp
    M pdal/util/Extractor.hpp
    M pdal/util/FileUtils.cpp
    M pdal/util/IStream.hpp
    M pdal/util/Utils.hpp
    M plugins/i3s/io/EsriReader.cpp
    M plugins/i3s/io/EsriReader.hpp
    M plugins/pcl/CMakeLists.txt
    M plugins/python/filters/PythonFilter.cpp
    M plugins/python/plang/Environment.cpp
    M plugins/python/plang/Invocation.cpp
    M plugins/python/test/PythonFilterTest.cpp
    M plugins/rdb/CMakeLists.txt
    M plugins/tiledb/io/TileDBReader.cpp
    M plugins/tiledb/io/TileDBReader.hpp
    M plugins/tiledb/io/TileDBWriter.cpp
    M plugins/tiledb/io/TileDBWriter.hpp
    M scripts/appveyor/conda/build.cmd
    M scripts/appveyor/config.cmd
    M scripts/appveyor/test/build.cmd
    A scripts/docker/centos/Dockerfile
    M scripts/docker/ubuntu/Dockerfile
    A test/data/i3s/plineSonoma3.json
    M test/data/plang/predicate-embed.json.in
    M test/unit/CMakeLists.txt
    M test/unit/SpatialReferenceTest.cpp
    M test/unit/apps/TIndexTest.cpp
    A test/unit/filters/HeadTailFilterTest.cpp
    A test/unit/io/EptAddonWriterTest.cpp
    M test/unit/io/SbetReaderTest.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master'
Compare: https://github.com/PDAL/PDAL/compare/5927898fde96...00db7b8b5e5e
More information about the pdal-commits mailing list
