[pdal-commits] [PDAL/PDAL] 896fcc: remove 'diff' kernel #2302 (#2423)
Andrew Bell noreply at github.com
Fri Mar 29 10:35:20 PDT 2019
  Branch: refs/heads/1.9-maintenance
  Home:   https://github.com/PDAL/PDAL
  Commit: 896fcc075a142ed64528c832680b13802a4badd5
      https://github.com/PDAL/PDAL/commit/896fcc075a142ed64528c832680b13802a4badd5
  Author: Howard Butler <howard at hobu.co>
  Date:   2019-03-29 (Fri, 29 Mar 2019)
  Changed paths:
    R doc/apps/diff.rst
    R kernels/DiffKernel.cpp
    R kernels/DiffKernel.hpp
    M scripts/conda/osx.sh
  Log Message:
  Commit: 888aadfae35dbce5e80badfea98f96ab1c527262
      https://github.com/PDAL/PDAL/commit/888aadfae35dbce5e80badfea98f96ab1c527262
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Changed paths:
    M pdal/util/FileUtils.hpp
  Log Message:
  Include <vector> for FileUtils.
  Commit: 5309eeb9152194a0fc94b124d30904a36486a498
      https://github.com/PDAL/PDAL/commit/5309eeb9152194a0fc94b124d30904a36486a498
  Changed paths:
    M io/PlyWriter.cpp
    A test/data/ply/issue_2421.ply
    M test/unit/io/PlyWriterTest.cpp
  Log Message:
  Change readers.ply output for integers with precision set (#2422)
* Don't write ints using fixed precision.
* Test for issue 2421.
Close #2421
  Commit: 0a4e3ab8e2e1c671ec507212eb4d51d799e097d7
      https://github.com/PDAL/PDAL/commit/0a4e3ab8e2e1c671ec507212eb4d51d799e097d7
  Changed paths:
    M filters/AssignFilter.cpp
  Log Message:
  Require assignment in filters.assign.
  Commit: 7b4bcf51b6558917baaba32601ce06b91070339a
      https://github.com/PDAL/PDAL/commit/7b4bcf51b6558917baaba32601ce06b91070339a
  Changed paths:
    M doc/development/compilation/dependencies.rst
    M doc/development/overview.rst
    M doc/python.rst
    M doc/stages/filters.approximatecoplanar.rst
    M doc/stages/filters.assign.rst
    M doc/stages/filters.chipper.rst
    M doc/stages/filters.cluster.rst
    M doc/stages/filters.colorinterp.rst
    M doc/stages/filters.colorization.rst
    M doc/stages/filters.cpd.rst
    M doc/stages/filters.crop.rst
    M doc/stages/filters.decimation.rst
    M doc/stages/filters.delaunay.rst
    M doc/stages/filters.dem.rst
    M doc/stages/filters.divider.rst
    M doc/stages/filters.eigenvalues.rst
    M doc/stages/filters.elm.rst
    M doc/stages/filters.estimaterank.rst
    M doc/stages/filters.ferry.rst
    M doc/stages/filters.greedyprojection.rst
    M doc/stages/filters.gridprojection.rst
    M doc/stages/filters.groupby.rst
    M doc/stages/filters.hag.rst
    M doc/stages/filters.head.rst
    M doc/stages/filters.hexbin.rst
    M doc/stages/filters.icp.rst
    M doc/stages/filters.info.rst
    M doc/stages/filters.iqr.rst
    M doc/stages/filters.kdistance.rst
    M doc/stages/filters.locate.rst
    M doc/stages/filters.lof.rst
    M doc/stages/filters.mad.rst
    M doc/stages/filters.matlab.rst
    M doc/stages/filters.merge.rst
    M doc/stages/filters.mongoexpression.rst
    M doc/stages/filters.mongus.rst
    M doc/stages/filters.mortonorder.rst
    M doc/stages/filters.movingleastsquares.rst
    M doc/stages/filters.neighborclassifier.rst
    M doc/stages/filters.nndistance.rst
    M doc/stages/filters.normal.rst
    M doc/stages/filters.outlier.rst
    M doc/stages/filters.overlay.rst
    M doc/stages/filters.pclblock.rst
    M doc/stages/filters.pmf.rst
    M doc/stages/filters.poisson.rst
    M doc/stages/filters.python.rst
    M doc/stages/filters.radialdensity.rst
    M doc/stages/filters.randomize.rst
    M doc/stages/filters.range.rst
    M doc/stages/filters.reprojection.rst
    M doc/stages/filters.returns.rst
    M doc/stages/filters.sample.rst
    M doc/stages/filters.smrf.rst
    M doc/stages/filters.sort.rst
    M doc/stages/filters.splitter.rst
    M doc/stages/filters.stats.rst
    M doc/stages/filters.streamcallback.rst
    M doc/stages/filters.tail.rst
    M doc/stages/filters.transformation.rst
    M doc/stages/filters.voxelcenternearestneighbor.rst
    M doc/stages/filters.voxelcentroidnearestneighbor.rst
    M doc/stages/filters.voxelgrid.rst
    M doc/stages/writers.bpf.rst
    M doc/stages/writers.ept_addon.rst
    M doc/stages/writers.gdal.rst
    M doc/stages/writers.geowave.rst
    M doc/stages/writers.greyhound.rst
    M doc/stages/writers.las.rst
    M doc/stages/writers.matlab.rst
    M doc/stages/writers.nitf.rst
    M doc/stages/writers.null.rst
    M doc/stages/writers.oci.rst
    M doc/stages/writers.ogr.rst
    M doc/stages/writers.pcd.rst
    M doc/stages/writers.pgpointcloud.rst
    M doc/stages/writers.ply.rst
    M doc/stages/writers.sbet.rst
    M doc/stages/writers.sqlite.rst
    M doc/stages/writers.text.rst
    M doc/stages/writers.tiledb.rst
    M doc/tutorial/clipping/index.rst
    M doc/tutorial/las.rst
    M doc/tutorial/reading.rst
    M filters/MongusFilter.cpp
    M filters/MongusFilter.hpp
    M plugins/python/filters/PythonFilter.cpp
  Log Message:
  Stage updates.
  Commit: dad7e0beb5a496b223963419d687f165a3855b95
      https://github.com/PDAL/PDAL/commit/dad7e0beb5a496b223963419d687f165a3855b95
  Changed paths:
  Log Message:
  Fix typos.
  Commit: 1ead1449bcbf7f2d398d7f153355b9f1e637a057
      https://github.com/PDAL/PDAL/commit/1ead1449bcbf7f2d398d7f153355b9f1e637a057
  Changed paths:
    M CMakeLists.txt
  Log Message:
  New version.
  Commit: 3012607d41ca9327a75d70c79d9e008acbedab47
      https://github.com/PDAL/PDAL/commit/3012607d41ca9327a75d70c79d9e008acbedab47
  Changed paths:
    M appveyor.yml
    M cmake/examples/hobu-config.sh
    M cmake/modules/FindOracle.cmake
    M doc/apps/tindex.rst
    M doc/development/compilation/unix.rst
    M doc/development/compilation/windows.rst
    M doc/download.rst
    M doc/images/reproject-merge-pipeline.png
    M doc/project/integration.rst
    M doc/stages/readers.ept.rst
    M doc/stages/readers.rst
    M doc/stages/writers.rst
    M doc/workshop/exercises/analysis/clipping/clipping.rst
    M doc/workshop/exercises/analysis/denoising/denoising.rst
    M doc/workshop/exercises/analysis/density/density.rst
    M doc/workshop/exercises/analysis/dtm/dtm.rst
    M doc/workshop/exercises/analysis/ground/ground.rst
    M doc/workshop/exercises/analysis/rasterize/classification.json
    M doc/workshop/exercises/analysis/rasterize/rasterize.rst
    M doc/workshop/exercises/georeferencing/index.rst
    M doc/workshop/exercises/info/metadata.rst
    M doc/workshop/exercises/info/single-point.rst
    M doc/workshop/exercises/translation/compression.rst
    M doc/workshop/exercises/translation/reprojection.rst
    M doc/workshop/includes/substitutions.rst
    R doc/workshop/osgeo4w.rst
    M doc/workshop/slides/source/software.rst
    M doc/workshop/software.rst
    M filters/HeadFilter.hpp
    M filters/TailFilter.hpp
    M io/EptAddonWriter.cpp
    M kernels/TIndexKernel.cpp
    M kernels/TIndexKernel.hpp
    M pdal/Kernel.cpp
    M pdal/Kernel.hpp
    M pdal/Metadata.hpp
    A pdal/SubcommandKernel.cpp
    A pdal/SubcommandKernel.hpp
    M plugins/i3s/lepcc/CMakeLists.txt
    M plugins/sqlite/io/SQLiteWriter.cpp
    M scripts/appveyor/conda/build.cmd
    M scripts/appveyor/config.cmd
    M scripts/appveyor/test/build.cmd
    M scripts/docker/ubuntu/Dockerfile
    M test/unit/CMakeLists.txt
    M test/unit/apps/TIndexTest.cpp
    A test/unit/filters/HeadTailFilterTest.cpp
    M vendor/kazhdan/MultiGridOctreeData.System.inl
  Log Message:
  Merge remote-tracking branch 'origin/1.9-maintenance' into 1.9-maintenance
Compare: https://github.com/PDAL/PDAL/compare/cd9897077862...3012607d41ca
More information about the pdal-commits mailing list
