[pdal-commits] [PDAL/PDAL] ebb420: Add power parameter to GDAL writer (#2704)
chambbj noreply at github.com
Thu Sep 5 11:22:18 PDT 2019
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: ebb4204ceff943cdd0b83e162be81dece25e8d45
      https://github.com/PDAL/PDAL/commit/ebb4204ceff943cdd0b83e162be81dece25e8d45
  Author: chambbj <brad.chambers at gmail.com>
  Date:   2019-09-05 (Thu, 05 Sep 2019)
  Changed paths:
    M doc/stages/writers.gdal.rst
    M io/GDALWriter.cpp
    M io/GDALWriter.hpp
    M io/private/GDALGrid.cpp
    M io/private/GDALGrid.hpp
    M test/unit/io/GDALWriterTest.cpp
  Log Message:
* Add power parameter to GDAL writer such that IDW can be more heavily influenced by near points if desired
* Set power back to 1 for tests to pass
* Do not default power in the constructor, also return default to 1.0
More information about the pdal-commits mailing list
