[pdal-commits] [PDAL/PDAL] 14b09e: Sibling of 8ce109799a2ad4abe6913edae089c36db847f81...
backporting[bot] noreply at github.com
Fri Sep 6 09:05:02 PDT 2019
  Branch: refs/heads/cherry-pick-backport-2722-to-2.0-maintenance-2fec2ee5-9c32-4efd-b6c7-5d44390b37d8
  Home:   https://github.com/PDAL/PDAL
  Commit: 14b09efe1fcc3272ce592ba68144b9e8ced03e34
      https://github.com/PDAL/PDAL/commit/14b09efe1fcc3272ce592ba68144b9e8ced03e34
  Author: Daniel Brookes <dbrookes at micromine.com.au>
  Date:   2019-09-06 (Fri, 06 Sep 2019)
  Changed paths:
    R .github/ISSUE_TEMPLATE/bug_report.md
    M CMakeLists.txt
    M HOWTORELEASE.txt
    M apps/pdal-config-bat.in
    M apps/pdal-config.in
    M apps/pdal.cpp
    M apps/pdal.pc.in
    A appveyor.yml
    R azure-pipelines.yml
    M cmake/common.cmake
    M cmake/cpack.cmake
    M cmake/curl.cmake
    M cmake/gdal.cmake
    R cmake/install_dirs.cmake
    M cmake/macros.cmake
    M cmake/python.cmake
    M cmake/win32_compiler_options.cmake
    M doc/conf.py
    M doc/development/writing-filter.rst
    M doc/stages/filters.eigenvalues.rst
    R doc/stages/filters.firstinvoxel.rst
    M doc/stages/filters.rst
    M doc/stages/filters.voxelcentroidnearestneighbor.rst
    M doc/stages/readers.ept.rst
    M doc/stages/writers.gdal.rst
    M examples/CMakeLists.txt
    M examples/writing-filter/CMakeLists.txt
    M examples/writing-kernel/CMakeLists.txt
    M examples/writing-reader/CMakeLists.txt
    M examples/writing-writer/CMakeLists.txt
    M examples/writing/CMakeLists.txt
    M filters/EigenvaluesFilter.cpp
    M filters/EigenvaluesFilter.hpp
    R filters/FirstInVoxelFilter.cpp
    R filters/FirstInVoxelFilter.hpp
    M filters/StatsFilter.cpp
    M filters/VoxelCentroidNearestNeighborFilter.cpp
    M io/EptReader.cpp
    M io/EptReader.hpp
    M io/GDALWriter.cpp
    M io/GDALWriter.hpp
    M io/Ilvis2Reader.cpp
    M io/Ilvis2Reader.hpp
    M io/PcdHeader.hpp
    M io/PcdReader.cpp
    M io/private/GDALGrid.cpp
    M io/private/GDALGrid.hpp
    M pdal/GDALUtils.cpp
    M pdal/GDALUtils.hpp
    M pdal/Geometry.cpp
    M pdal/Log.cpp
    M pdal/Log.hpp
    M pdal/PipelineExecutor.cpp
    M pdal/PipelineManager.cpp
    M pdal/PipelineManager.hpp
    M pdal/PluginManager.cpp
    M pdal/Polygon.cpp
    M pdal/Polygon.hpp
    M pdal/Stage.cpp
    M pdal/Stage.hpp
    M pdal/StageExtensions.cpp
    M pdal/StageFactory.cpp
    M pdal/pdal_config.cpp
    M pdal_features.hpp.in
    M plugins/e57/io/E57Reader.cpp
    M plugins/e57/io/E57Reader.hpp
    M plugins/e57/io/E57Writer.cpp
    M plugins/e57/io/Scan.cpp
    M plugins/e57/io/Utils.cpp
    M plugins/e57/io/Utils.hpp
    M plugins/e57/test/E57ReaderTest.cpp
    M plugins/e57/test/E57UtilsTest.cpp
    M plugins/e57/test/E57WriterTest.cpp
    M plugins/e57/test/ScanTest.cpp
    M plugins/i3s/lepcc/CMakeLists.txt
    M plugins/i3s/lepcc/src/BitStuffer2.cpp
    M plugins/i3s/lepcc/src/ClusterRGB.cpp
    M plugins/i3s/lepcc/src/FlagBytes.cpp
    M plugins/i3s/lepcc/src/Huffman.cpp
    M plugins/i3s/lepcc/src/Intensity.cpp
    M plugins/i3s/lepcc/src/LEPCC.cpp
    M plugins/matlab/test/MatlabFilterTest.cpp
    M plugins/nitf/CMakeLists.txt
    M plugins/python/test/PythonFilterTest.cpp
    M plugins/sqlite/io/SQLiteCommon.cpp
    M plugins/sqlite/test/SQLiteTest.cpp
    M plugins/tiledb/CMakeLists.txt
    R scripts/azp/doc.yml
    R scripts/azp/linux.yml
    R scripts/azp/osx.yml
    R scripts/azp/win.yml
    M scripts/docker/alpine/Dockerfile
    M scripts/docker/ubuntu/Dockerfile
    M scripts/docker/ubuntu/dependencies/Dockerfile
    R scripts/proj-datumshift
    M test/data/autzen/autzen-selection.json
    R test/data/ept/1.2-with-color/ept-build.json
    R test/data/ept/1.2-with-color/ept-data/0-0-0-0.laz
    R test/data/ept/1.2-with-color/ept-hierarchy/0-0-0-0.json
    R test/data/ept/1.2-with-color/ept-sources/0.json
    R test/data/ept/1.2-with-color/ept-sources/list.json
    R test/data/ept/1.2-with-color/ept.json
    M test/unit/CMakeLists.txt
    M test/unit/LogTest.cpp
    M test/unit/PolygonTest.cpp
    R test/unit/filters/FirstInVoxelFilterTest.cpp
    M test/unit/filters/MergeTest.cpp
    M test/unit/filters/OverlayFilterTest.cpp
    M test/unit/filters/ReciprocityFilterTest.cpp
    M test/unit/io/EptReaderTest.cpp
    M test/unit/io/GDALWriterTest.cpp
    M vendor/arbiter/arbiter.cpp
    M vendor/arbiter/arbiter.hpp
    M vendor/pdalboost/boost/config/compiler/visualc.hpp
    R vendor/pdalboost/boost/exception/all.hpp
    M vendor/pdalboost/boost/exception/current_exception_cast.hpp
    M vendor/pdalboost/boost/exception/detail/error_info_impl.hpp
    M vendor/pdalboost/boost/exception/detail/exception_ptr.hpp
    M vendor/pdalboost/boost/exception/detail/is_output_streamable.hpp
    M vendor/pdalboost/boost/exception/detail/object_hex_dump.hpp
    R vendor/pdalboost/boost/exception/detail/shared_ptr.hpp
    M vendor/pdalboost/boost/exception/detail/type_info.hpp
    M vendor/pdalboost/boost/exception/diagnostic_information.hpp
    R vendor/pdalboost/boost/exception/enable_current_exception.hpp
    R vendor/pdalboost/boost/exception/enable_error_info.hpp
    R vendor/pdalboost/boost/exception/errinfo_api_function.hpp
    R vendor/pdalboost/boost/exception/errinfo_at_line.hpp
    R vendor/pdalboost/boost/exception/errinfo_errno.hpp
    R vendor/pdalboost/boost/exception/errinfo_file_handle.hpp
    R vendor/pdalboost/boost/exception/errinfo_file_name.hpp
    R vendor/pdalboost/boost/exception/errinfo_file_open_mode.hpp
    R vendor/pdalboost/boost/exception/errinfo_nested_exception.hpp
    R vendor/pdalboost/boost/exception/errinfo_type_info_name.hpp
    R vendor/pdalboost/boost/exception/error_info.hpp
    M vendor/pdalboost/boost/exception/exception.hpp
    M vendor/pdalboost/boost/exception/get_error_info.hpp
    M vendor/pdalboost/boost/exception/info.hpp
    R vendor/pdalboost/boost/exception/info_tuple.hpp
    M vendor/pdalboost/boost/exception/to_string.hpp
    M vendor/pdalboost/boost/exception/to_string_stub.hpp
    M vendor/pdalboost/boost/throw_exception.hpp
  Log Message:
  Sibling of 8ce109799a2ad4abe6913edae089c36db847f818 [skip ci]
skip-checks: true
More information about the pdal-commits mailing list
