[pdal-commits] [PDAL/PDAL] 6e2b07: Update PROJ_NETWORK to get tests to pass.
Andrew Bell noreply at github.com
Fri Apr 10 08:13:39 PDT 2020
  Branch: refs/heads/2.1-maintenance
  Home:   https://github.com/PDAL/PDAL
  Commit: 6e2b07b366f4a01eb61c36a7c0c6423cc457be4d
      https://github.com/PDAL/PDAL/commit/6e2b07b366f4a01eb61c36a7c0c6423cc457be4d
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2020-04-10 (Fri, 10 Apr 2020)
  Changed paths:
    M test/unit/CMakeLists.txt
  Log Message:
* tighten up EPT bounds test
* shut off PROJ_NETWORK to eliminate grid shifts in ept test
* set test environment properties for PROJ_NETWORK=OFF
* set properties for tile test
More information about the pdal-commits mailing list
