[pdal-commits] [PDAL/PDAL] 80bca2: tighten up EPT bounds test (#3018)
Andrew Bell noreply at github.com
Fri Apr 10 09:04:05 PDT 2020
  Branch: refs/heads/issue-3019
  Home:   https://github.com/PDAL/PDAL
  Commit: 80bca2319a8aaa24a928b54a92d541f14f23c295
      https://github.com/PDAL/PDAL/commit/80bca2319a8aaa24a928b54a92d541f14f23c295
  Author: Howard Butler <howard at hobu.co>
  Date:   2020-04-09 (Thu, 09 Apr 2020)
  Changed paths:
    M test/unit/io/EptReaderTest.cpp
  Log Message:
  Commit: 297fc364c0c10b8e753008cbff6c7f3122acb48c
      https://github.com/PDAL/PDAL/commit/297fc364c0c10b8e753008cbff6c7f3122acb48c
  Changed paths:
    M test/unit/CMakeLists.txt
  Log Message:
  EPT test fixes (#3020)
* tighten up EPT bounds test
* shut off PROJ_NETWORK to eliminate grid shifts in ept test
* set test environment properties for PROJ_NETWORK=OFF
* set properties for tile test
  Commit: b6c74d715cc333aeb847fac213c0b2f0e2312902
      https://github.com/PDAL/PDAL/commit/b6c74d715cc333aeb847fac213c0b2f0e2312902
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2020-04-10 (Fri, 10 Apr 2020)
  Changed paths:
  Log Message:
  Merge remote-tracking branch 'origin/master' into issue-3019
Compare: https://github.com/PDAL/PDAL/compare/e65f2f55fae4...b6c74d715cc3
More information about the pdal-commits mailing list
