[pdal-commits] [PDAL/PDAL] b65004: Page Manager code.
Andrew Bell noreply at github.com
Tue Aug 4 13:40:14 PDT 2020
  Branch: refs/heads/esri
  Home:   https://github.com/PDAL/PDAL
  Commit: b6500456eb1c044155c875461e58816948487788
      https://github.com/PDAL/PDAL/commit/b6500456eb1c044155c875461e58816948487788
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2020-08-03 (Mon, 03 Aug 2020)
  Changed paths:
    M io/EptReader.cpp
    M pdal/util/ThreadPool.cpp
    M pdal/util/ThreadPool.hpp
    M plugins/i3s/CMakeLists.txt
    M plugins/i3s/io/EsriReader.cpp
    M plugins/i3s/io/EsriReader.hpp
    M plugins/i3s/io/EsriUtil.hpp
    A plugins/i3s/io/PageManager.cpp
    A plugins/i3s/io/PageManager.hpp
  Log Message:
  Page Manager code.
  Commit: eca54295767b4d2ff586469b964a2ea2035f99fa
      https://github.com/PDAL/PDAL/commit/eca54295767b4d2ff586469b964a2ea2035f99fa
  Changed paths:
    M plugins/i3s/io/PageManager.cpp
  Log Message:
  Thread traverseTree.
  Commit: f25e34d7b1a05497c05ccdb2af4850219d6f6909
      https://github.com/PDAL/PDAL/commit/f25e34d7b1a05497c05ccdb2af4850219d6f6909
  Date:   2020-08-04 (Tue, 04 Aug 2020)
  Changed paths:
    M io/EptAddonWriter.cpp
    M io/EptAddonWriter.hpp
    M io/EptReader.cpp
    M io/EptReader.hpp
    R io/private/ept/Pool.cpp
    R io/private/ept/Pool.hpp
    M pdal/private/MathUtils.cpp
    M pdal/private/MathUtils.hpp
    M pdal/private/SrsTransform.cpp
    M pdal/private/SrsTransform.hpp
    M pdal/util/CMakeLists.txt
    M pdal/util/FileUtils.cpp
    A pdal/util/ThreadPool.cpp
    A pdal/util/ThreadPool.hpp
    M plugins/i3s/io/EsriUtil.cpp
    M plugins/i3s/io/I3SReader.cpp
    M plugins/i3s/io/I3SReader.hpp
    A plugins/i3s/io/Obb.cpp
    A plugins/i3s/io/Obb.hpp
    R plugins/i3s/io/SlpkExtractor.cpp
    R plugins/i3s/io/SlpkExtractor.hpp
    M plugins/i3s/io/SlpkReader.cpp
    M plugins/i3s/io/SlpkReader.hpp
    R plugins/i3s/io/pool.hpp
    M plugins/i3s/lepcc/src/utl_const_array.h
    A plugins/i3s/test/ObbTest.cpp
    M plugins/i3s/test/SlpkReaderTest.cpp
    M plugins/i3s/test/i3sReaderTest.cpp
  Log Message:
  I3S streaming support (#3113)
* Streaming support.
* Remove unnecessary assignment.
* Esri notemp (#3116)
* Remove SLPKExtractor.
Load data from SLPK without writing to temp space.
* Fix type mismatch for threads.
* Typo #1.
* Move win header.
* Fix Windows min.
* More header.
* Fix CreateFileMapping args.
* PDAL_DLL
* Windows build fixes.
* Formatting.
* Clean up esri build file.
* Obb code.
* Specific OBB Test.
* Better comments and separate test.
* Don't try to filter with invalid OBB.
Filter points based on OBB if it's valid.
* Remove dead bounds boxes.
* Add math function to build for plugin.
* Fix incorrect use of m_pointId.
  Commit: 6927b884391b6223c0f4d87d8f0de8249e9a315a
      https://github.com/PDAL/PDAL/commit/6927b884391b6223c0f4d87d8f0de8249e9a315a
  Changed paths:
    M io/EptReader.cpp
  Log Message:
  Merge branch 'esri-pm' into esri
  Commit: e306c09ba2c23a5c8b484052e995c333a5fe8c9a
      https://github.com/PDAL/PDAL/commit/e306c09ba2c23a5c8b484052e995c333a5fe8c9a
  Changed paths:
    M plugins/i3s/io/Obb.hpp
    M plugins/i3s/io/PageManager.hpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into esri
Compare: https://github.com/PDAL/PDAL/compare/5966d8189d59...e306c09ba2c2
More information about the pdal-commits mailing list
