[pdal-commits] [PDAL/PDAL] 70b52e: readers.obj (#3207)
Ryan Pals noreply at github.com
Sat Aug 8 16:31:14 PDT 2020
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 70b52e2cee795cd69bbafbb16d30a63af6e40b49
      https://github.com/PDAL/PDAL/commit/70b52e2cee795cd69bbafbb16d30a63af6e40b49
  Author: Ryan Pals <ryan at hobu.co>
  Date:   2020-08-08 (Sat, 08 Aug 2020)
  Changed paths:
    A doc/stages/readers.obj.rst
    A io/ObjReader.cpp
    A io/ObjReader.hpp
    M pdal/Dimension.json
    M pdal/StageExtensions.cpp
    A test/data/obj/1.2-with-color.obj
    A test/data/obj/1.2-with-color.obj.mtl
    A test/data/obj/box.obj
    A test/data/obj/no_vertex.obj
    A test/data/obj/simple_binary.obj
    M test/unit/CMakeLists.txt
    A test/unit/io/ObjReaderTest.cpp
  Log Message:
  readers.obj (#3207)
* Stub.
* Correct return type.
* Vertex indices can be negative.
* WIP
* Copy over test data
* WIP
* Remove swap files
* Add simple test data from paulbourke.net
* WIP
* WIP
* WIP
* WIP
* WIP
* WIP -- feedback from call with Andrew
* Smaller pieces.
* Non-crashing code.
* Add face triangulation
* Read negative vertices correctly
* WIP
* Fix test of file key name.
* Copy unit test files from https://github.com/PDAL/PDAL/tree/readers.obj
* Add mesh
* Copy over unit tests from Hobu's branch
* WIP
* Throw error when no file is found
* WIP
* WIP
* Feedback -- get rid of try/catch blocks
* Feedback -- move reused code into a function
* Convert to lambda
* Tabs -> spaces
* Cleanup
* Add test stubs
* Small changes, mostly formatting.
* Feedback -- ensure entire string is read
* Add docs
* Remove unused file
* Finishing touches, finish tests
* Remove old
* Fix JSON error
* Fix JSON error part 2
* Change vertex init
* Change vertex init part 2
* Fix point ordering
* Potential cmake/windows fix
Co-authored-by: Andrew Bell <andrew.bell.ia at gmail.com>
More information about the pdal-commits mailing list
