[pdal-commits] [PDAL/PDAL] e90659: I3S PageManager (#3208)
Andrew Bell noreply at github.com
Thu Aug 13 04:41:52 PDT 2020
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: e9065902e7b423a7b5c8782db7106643fc667662
      https://github.com/PDAL/PDAL/commit/e9065902e7b423a7b5c8782db7106643fc667662
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2020-08-13 (Thu, 13 Aug 2020)
  Changed paths:
    M io/EptReader.cpp
    M pdal/util/ThreadPool.cpp
    M pdal/util/ThreadPool.hpp
    M plugins/i3s/CMakeLists.txt
    M plugins/i3s/io/EsriReader.cpp
    M plugins/i3s/io/EsriReader.hpp
    M plugins/i3s/io/EsriUtil.hpp
    A plugins/i3s/io/PageManager.cpp
    A plugins/i3s/io/PageManager.hpp
  Log Message:
* Streaming support.
* Remove unnecessary assignment.
* Esri notemp (#3116)
* Remove SLPKExtractor.
Load data from SLPK without writing to temp space.
* Fix type mismatch for threads.
* Typo #1.
* Move win header.
* Fix Windows min.
* More header.
* Fix CreateFileMapping args.
* PDAL_DLL
* Windows build fixes.
* Formatting.
* Clean up esri build file.
* Obb code.
* Specific OBB Test.
* Better comments and separate test.
* Don't try to filter with invalid OBB.
Filter points based on OBB if it's valid.
* Remove dead bounds boxes.
* Add math function to build for plugin.
* Fix incorrect use of m_pointId.
* Page Manager code.
* Thread traverseTree.
* Update to correct?
Co-authored-by: Andrew <acbell at Andrews-MacBook-Pro.local>
More information about the pdal-commits mailing list
