[pdal-commits] [PDAL/PDAL] ff3d6b: Remove private headers from .hpp files.
Andrew Bell noreply at github.com
Thu Aug 27 17:14:07 PDT 2020
  Branch: refs/heads/2.2-maintenance
  Home:   https://github.com/PDAL/PDAL
  Commit: ff3d6b0f990776f01e57dbf38da213e0d9c8303c
      https://github.com/PDAL/PDAL/commit/ff3d6b0f990776f01e57dbf38da213e0d9c8303c
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2020-08-27 (Thu, 27 Aug 2020)
  Changed paths:
    M filters/FaceRasterFilter.cpp
    M filters/FaceRasterFilter.hpp
    M io/EptAddonWriter.hpp
    M io/EptReader.cpp
    M io/EptReader.hpp
    M kernels/GroundKernel.cpp
    M kernels/GroundKernel.hpp
    M pdal/PointView.cpp
    M pdal/PointView.hpp
    M test/unit/filters/FaceRasterTest.cpp
  Log Message:
  Commit: 18b9ae3c0b4b02c45b6982a18860e057cf5d8c3b
      https://github.com/PDAL/PDAL/commit/18b9ae3c0b4b02c45b6982a18860e057cf5d8c3b
  Changed paths:
    M HOWTORELEASE.txt
    M filters/IterativeClosestPoint.cpp
    M vendor/arbiter/arbiter.cpp
  Log Message:
  Fixes for clang 10.
  Commit: 68adb9c5a844e97a153bc47d5761af5ff6f0f0a0
      https://github.com/PDAL/PDAL/commit/68adb9c5a844e97a153bc47d5761af5ff6f0f0a0
  Author: trevorskaggs <skaggs.trevor at gmail.com>
  Changed paths:
    M doc/stages/readers.rst
  Log Message:
  Add HDF reader stage to readers page. (#3219)
  Commit: af2450a8bdafaffdb4b18447fc6ed533559e6b57
      https://github.com/PDAL/PDAL/commit/af2450a8bdafaffdb4b18447fc6ed533559e6b57
  Author: Ryan Pals <ryan at hobu.co>
  Changed paths:
    M io/ObjReader.cpp
    M io/ObjReader.hpp
    M pdal/Dimension.json
    A test/data/obj/box_texture.obj
    A test/data/obj/hyper_box.obj
    M test/unit/io/ObjReaderTest.cpp
  Log Message:
  Obj texture fix -- simplified. (#3222)
* Texture 2 element fix
* Allow for 0-3 fields in texture and 3-4 fields in vertex position
* Rename texture dimensions, add W
* Allow all dimensions
* Allow more than 4 fields in vertex specification
* Remove unused
* Copy over tests
* Add W dimension
* Check vertex length
  Commit: 4602a0b68df510028525a567c4549f1d8ffe2ae4
      https://github.com/PDAL/PDAL/commit/4602a0b68df510028525a567c4549f1d8ffe2ae4
  Changed paths:
    M kernels/TranslateKernel.cpp
    M pdal/Scaling.cpp
    M vendor/eigen/Eigen/Core
    M vendor/eigen/Eigen/Geometry
    M vendor/eigen/Eigen/src/Core/AssignEvaluator.h
    M vendor/eigen/Eigen/src/Core/products/GeneralMatrixVector.h
    M vendor/kazhdan/Allocator.h
  Log Message:
  Fixes for clang10. (#3221)
Compare: https://github.com/PDAL/PDAL/compare/1dff1be08450...4602a0b68df5
More information about the pdal-commits mailing list
