[pdal-commits] [PDAL/PDAL] 51442a: Implement a Linux build based on Conda with a pinn...
Howard Butler noreply at github.com
Tue Feb 4 11:58:50 PST 2020
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 51442a846c2e4050a1e8d909bf9bb376616d2b1b
      https://github.com/PDAL/PDAL/commit/51442a846c2e4050a1e8d909bf9bb376616d2b1b
  Author: Howard Butler <howard at hobu.co>
  Date:   2020-02-04 (Tue, 04 Feb 2020)
  Changed paths:
    M azure-pipelines.yml
    M plugins/tiledb/CMakeLists.txt
    A scripts/azp/linux-conda.yml
  Log Message:
  Implement a Linux build based on Conda with a pinned GDAL dependency (#2911)
* add Linux/Conda build
* fix job name
* conda junk
* set uid/gid
* set uid:gid
* conda user stuff again
* more usermod
* clobber /opt/conda perms
* clobber user to vsts_azpcontainer
* use azp conda
* fix syntax
* remove manual env setting
* conda init
* LD_FLAGS
* no pin
* another swing
* selectively shut off tiledb tests with BUILD_TILEDB_TESTS
* try pinning gdal
* use correct GDAL pin
More information about the pdal-commits mailing list
