[pdal-commits] [PDAL/PDAL] b24899: add AzP/docs build (#2919)
Howard Butler noreply at github.com
Sat Feb 8 08:18:27 PST 2020
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: b24899d44fe20214543f037614b370e2cca4ecd1
      https://github.com/PDAL/PDAL/commit/b24899d44fe20214543f037614b370e2cca4ecd1
  Author: Howard Butler <howard at hobu.co>
  Date:   2020-02-08 (Sat, 08 Feb 2020)
  Changed paths:
    M azure-pipelines.yml
    M scripts/azp/doc.yml
  Log Message:
* add AzP/docs build
* try uploading doc builds to s3
* rejigger variables
* remove extraneous ninja command
* variable settings
* variable quoting
* more variable churn
* more variable churns
* one more time
* azp variable churning some more
* build PDF too
* output URLs
* condition doc upload for only PullRequest
* yaml is whitespace sensitive
* --quiet aws sync
* try var subst again
* quiet file upload
* try quoting var
* reenable the rest of CI
More information about the pdal-commits mailing list
