[pdal-commits] [PDAL/PDAL] c09f2b: Windows updates (#2917)
Howard Butler noreply at github.com
Sat Feb 8 08:21:07 PST 2020
  Branch: refs/heads/axis-ordering
  Home:   https://github.com/PDAL/PDAL
  Commit: c09f2b1b5a8c060fc44b787d90aee105bddfbcf7
      https://github.com/PDAL/PDAL/commit/c09f2b1b5a8c060fc44b787d90aee105bddfbcf7
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2020-02-07 (Fri, 07 Feb 2020)
  Changed paths:
    M .gitattributes
    M apps/CMakeLists.txt
    M io/LasHeader.cpp
    M pdal/util/Uuid.hpp
    M tools/lasdump/Header.cpp
  Log Message:
* Updates for VS 2017
* Use constexpr function call for Uuid size.
  Commit: 48d8db4037e2259aa6c0fea3b5664c9f05a91323
      https://github.com/PDAL/PDAL/commit/48d8db4037e2259aa6c0fea3b5664c9f05a91323
  Author: Howard Butler <howard at hobu.co>
  Changed paths:
    M scripts/azp/win.yml
  Log Message:
  make AzP/Windows use GDAL 3 (#2918)
  Commit: 3b8c0f5ca351fcb396355b06a8c154263fc460e7
      https://github.com/PDAL/PDAL/commit/3b8c0f5ca351fcb396355b06a8c154263fc460e7
  Changed paths:
    M plugins/e57/libE57Format/src/CheckedFile.cpp
  Log Message:
  E57 changes for GCC 9.2.
  Commit: b1970c9160d86032d2a4531549b4eaf3746ad152
      https://github.com/PDAL/PDAL/commit/b1970c9160d86032d2a4531549b4eaf3746ad152
  Changed paths:
  Log Message:
  Merge remote-tracking branch 'origin/master'
  Commit: b24899d44fe20214543f037614b370e2cca4ecd1
      https://github.com/PDAL/PDAL/commit/b24899d44fe20214543f037614b370e2cca4ecd1
  Date:   2020-02-08 (Sat, 08 Feb 2020)
  Changed paths:
    M azure-pipelines.yml
    M scripts/azp/doc.yml
  Log Message:
  add AzP/docs build (#2919)
* add AzP/docs build
* try uploading doc builds to s3
* rejigger variables
* remove extraneous ninja command
* variable settings
* variable quoting
* more variable churn
* more variable churns
* one more time
* azp variable churning some more
* build PDF too
* output URLs
* condition doc upload for only PullRequest
* yaml is whitespace sensitive
* --quiet aws sync
* try var subst again
* quiet file upload
* try quoting var
* reenable the rest of CI
  Commit: 3f4f589486f007075bf160285ca43f929c51ba60
      https://github.com/PDAL/PDAL/commit/3f4f589486f007075bf160285ca43f929c51ba60
  Changed paths:
    M .gitattributes
    M io/LasHeader.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into axis-ordering
Compare: https://github.com/PDAL/PDAL/compare/8a2959d52683...3f4f589486f0
More information about the pdal-commits mailing list
