[pdal-commits] [PDAL/PDAL] 0897f8: Updates.
Andrew Bell noreply at github.com
Tue Feb 11 11:22:25 PST 2020
  Branch: refs/heads/issue-2886
  Home:   https://github.com/PDAL/PDAL
  Commit: 0897f871d1f4af62e4a18162424154b18f063fdc
      https://github.com/PDAL/PDAL/commit/0897f871d1f4af62e4a18162424154b18f063fdc
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2020-01-28 (Tue, 28 Jan 2020)
  Changed paths:
    A doc/stages/filters.hag-delaunay.rst
    A doc/stages/filters.hag-nn.rst
    R doc/stages/filters.hag.rst
    A filters/HagDelaunayFilter.cpp
    A filters/HagDelaunayFilter.hpp
    A filters/HagNnFilter.cpp
    A filters/HagNnFilter.hpp
  Log Message:
  Updates.
  Commit: 6ee65951a96ac9fe6ce22c49a7f502ab7e901518
      https://github.com/PDAL/PDAL/commit/6ee65951a96ac9fe6ce22c49a7f502ab7e901518
  Author: Julian Fell <hi at jtfell.com>
  Date:   2020-01-29 (Wed, 29 Jan 2020)
  Changed paths:
    A doc/stages/filters.hag_dem.rst
    A filters/HAGDEMFilter.cpp
    A filters/HAGDEMFilter.hpp
  Log Message:
  Add filters.hag_dem
  Commit: cbf97d4f30a4c2596abc7c9475e957e21aa00523
      https://github.com/PDAL/PDAL/commit/cbf97d4f30a4c2596abc7c9475e957e21aa00523
  Changed paths:
    M doc/stages/filters.hag_dem.rst
    M doc/stages/filters.rst
    M filters/HAGDEMFilter.cpp
    M filters/HAGDEMFilter.hpp
  Log Message:
  make filters.hag_dem streamable, improve docs
  Commit: 7f9dbf4e7ceaabb5436f62bf000252668bea9e52
      https://github.com/PDAL/PDAL/commit/7f9dbf4e7ceaabb5436f62bf000252668bea9e52
  Date:   2020-01-30 (Thu, 30 Jan 2020)
  Changed paths:
  Log Message:
  update copyright info
  Commit: 5e9697b2993cedaed1d4b7a274fe7f06c553a39a
      https://github.com/PDAL/PDAL/commit/5e9697b2993cedaed1d4b7a274fe7f06c553a39a
  Date:   2020-01-31 (Fri, 31 Jan 2020)
  Changed paths:
  Log Message:
  Make raster a positional argument in HAGDEMFilter
  Commit: f8875d8cfce8281529d157b57cc50d09672acdf5
      https://github.com/PDAL/PDAL/commit/f8875d8cfce8281529d157b57cc50d09672acdf5
  Date:   2020-02-03 (Mon, 03 Feb 2020)
  Changed paths:
    R doc/stages/filters.hag-delaunay.rst
    R doc/stages/filters.hag-nn.rst
    A doc/stages/filters.hag_delaunay.rst
    A doc/stages/filters.hag_nn.rst
    M filters/HagDelaunayFilter.cpp
    M filters/HagNnFilter.cpp
  Log Message:
  Break HAG into pieces.
  Commit: ec7e5f65e6468a35737827a2b7f5cfd92369d764
      https://github.com/PDAL/PDAL/commit/ec7e5f65e6468a35737827a2b7f5cfd92369d764
  Date:   2020-02-07 (Fri, 07 Feb 2020)
  Changed paths:
    M filters/DEMFilter.cpp
  Log Message:
  Fix validation error message for invalid band parameter
  Commit: a42fb606e6d4d2a485e6078816c26f837697cb58
      https://github.com/PDAL/PDAL/commit/a42fb606e6d4d2a485e6078816c26f837697cb58
  Date:   2020-02-11 (Tue, 11 Feb 2020)
  Changed paths:
    M CMakeLists.txt
    A doc/images/filters.transformation.rotation_x_axis_counter-clockwise.svg
    A doc/images/filters.transformation.rotation_x_axis_counter-clockwise.svg.png
    A doc/images/filters.transformation.rotation_y_axis_counter-clockwise.svg
    A doc/images/filters.transformation.rotation_y_axis_counter-clockwise.svg.png
    A doc/images/filters.transformation.rotation_z_axis_counter-clockwise.svg
    A doc/images/filters.transformation.rotation_z_axis_counter-clockwise.svg.png
    A doc/images/filters.transformation.scaling.svg
    A doc/images/filters.transformation.scaling.svg.png
    A doc/images/filters.transformation.translation.svg
    A doc/images/filters.transformation.translation.svg.png
    M doc/stages/filters.python.rst
    M doc/stages/filters.transformation.rst
    M doc/stages/readers.numpy.rst
    M filters/ClusterFilter.cpp
    M filters/ClusterFilter.hpp
    M pdal/GDALUtils.cpp
    M pdal/Geometry.hpp
    M pdal/Polygon.hpp
    M pdal/StageExtensions.cpp
    M plugins/python/io/CMakeLists.txt
    M plugins/python/io/NumpyReader.cpp
    M plugins/python/io/NumpyReader.hpp
    M plugins/python/plang/Invocation.cpp
    M plugins/python/plang/Invocation.hpp
    M plugins/python/test/NumpyReaderTest.cpp
    A test/data/filters/elm2.txt
    A test/data/plang/threedim.py
    M test/unit/filters/ELMFilterTest.cpp
    M tools/nitfwrap/NitfWrap.cpp
  Log Message:
  Merge branch 'filters.hag_dem' of https://github.com/jtfell/PDAL into issue-2886
  Commit: 5c891e4d502f378cadba05f7b39d8c744bf29ab8
      https://github.com/PDAL/PDAL/commit/5c891e4d502f378cadba05f7b39d8c744bf29ab8
  Changed paths:
    R filters/HAGDEMFilter.cpp
    R filters/HAGDEMFilter.hpp
    R filters/HAGFilter.cpp
    R filters/HAGFilter.hpp
    A filters/HagDemFilter.cpp
    A filters/HagDemFilter.hpp
  Log Message:
  Formatting changes.  Remove "static" in processOne()..
Compare: https://github.com/PDAL/PDAL/compare/0897f871d1f4%5E...5c891e4d502f
More information about the pdal-commits mailing list
