[pdal-commits] [PDAL/PDAL] 48d8db: make AzP/Windows use GDAL 3 (#2918)
Andrew Bell noreply at github.com
Wed Feb 12 07:28:41 PST 2020
  Branch: refs/heads/issue-2923
  Home:   https://github.com/PDAL/PDAL
  Commit: 48d8db4037e2259aa6c0fea3b5664c9f05a91323
      https://github.com/PDAL/PDAL/commit/48d8db4037e2259aa6c0fea3b5664c9f05a91323
  Author: Howard Butler <howard at hobu.co>
  Date:   2020-02-07 (Fri, 07 Feb 2020)
  Changed paths:
    M scripts/azp/win.yml
  Log Message:
  Commit: 3b8c0f5ca351fcb396355b06a8c154263fc460e7
      https://github.com/PDAL/PDAL/commit/3b8c0f5ca351fcb396355b06a8c154263fc460e7
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Changed paths:
    M plugins/e57/libE57Format/src/CheckedFile.cpp
  Log Message:
  E57 changes for GCC 9.2.
  Commit: b1970c9160d86032d2a4531549b4eaf3746ad152
      https://github.com/PDAL/PDAL/commit/b1970c9160d86032d2a4531549b4eaf3746ad152
  Changed paths:
  Log Message:
  Merge remote-tracking branch 'origin/master'
  Commit: b24899d44fe20214543f037614b370e2cca4ecd1
      https://github.com/PDAL/PDAL/commit/b24899d44fe20214543f037614b370e2cca4ecd1
  Date:   2020-02-08 (Sat, 08 Feb 2020)
  Changed paths:
    M azure-pipelines.yml
    M scripts/azp/doc.yml
  Log Message:
  add AzP/docs build (#2919)
* add AzP/docs build
* try uploading doc builds to s3
* rejigger variables
* remove extraneous ninja command
* variable settings
* variable quoting
* more variable churn
* more variable churns
* one more time
* azp variable churning some more
* build PDF too
* output URLs
* condition doc upload for only PullRequest
* yaml is whitespace sensitive
* --quiet aws sync
* try var subst again
* quiet file upload
* try quoting var
* reenable the rest of CI
  Commit: a8f82c2cf15307b775132039b0c9af729624d188
      https://github.com/PDAL/PDAL/commit/a8f82c2cf15307b775132039b0c9af729624d188
  Date:   2020-02-10 (Mon, 10 Feb 2020)
  Changed paths:
    M CMakeLists.txt
  Log Message:
  Revert #2890 – use C++11 as standard instead of C++17
  Commit: 8ce4403af2601f16f96f85ffa2f91a6f0d2c8c53
      https://github.com/PDAL/PDAL/commit/8ce4403af2601f16f96f85ffa2f91a6f0d2c8c53
  Author: chambbj <brad.chambers at gmail.com>
  Date:   2020-02-11 (Tue, 11 Feb 2020)
  Changed paths:
    M filters/ELMFilter.cpp
    M test/unit/filters/ELMFilterTest.cpp
  Log Message:
  Check for empty PointView in ELM filter (#2924)
  Commit: 4841169991484c6c8f4a5b0fffdb729ea8349890
      https://github.com/PDAL/PDAL/commit/4841169991484c6c8f4a5b0fffdb729ea8349890
  Changed paths:
    M doc/stages/filters.reprojection.rst
    M filters/ReprojectionFilter.cpp
    M filters/ReprojectionFilter.hpp
    M pdal/SpatialReference.cpp
    M pdal/SpatialReference.hpp
    M pdal/private/SrsTransform.cpp
    M pdal/private/SrsTransform.hpp
    A test/data/las/test_epsg_4326_axis.las
    M test/unit/SpatialReferenceTest.cpp
  Log Message:
  Implement in_axis_ordering and out_axis_ordering for filters.reprojection (#2916)
* whiff on implementing axis ordering for filters.reprojection
* implement axis order swapping for filters.reprojection
* validate input
* better str->int conversion
* my windows build config tweaks
* try --only-deps for PDAL dependencies on azp/linux
* install deps invocation
* condition axis order test on whether GDAL 3 is available
*  axis order override docs for filters.reprojection
* revert inadvertant changes
* Undo edits to my build script
* adjustments to PR comments
  Commit: 84502f2d0a6541b1ac379966c9f496e550ff95d3
      https://github.com/PDAL/PDAL/commit/84502f2d0a6541b1ac379966c9f496e550ff95d3
  Changed paths:
    M doc/conf.py
    A doc/pdal_rtd/README.md
    A doc/pdal_rtd/breadcrumbs.html
    A doc/pdal_rtd/footer.html
    A doc/pdal_rtd/searchbox.html
    A doc/pdal_rtd/static/css/pdal.css
    A doc/pdal_rtd/static/fonts/miriamlibre-bold-webfont.eot
    A doc/pdal_rtd/static/fonts/miriamlibre-bold-webfont.svg
    A doc/pdal_rtd/static/fonts/miriamlibre-bold-webfont.ttf
    A doc/pdal_rtd/static/fonts/miriamlibre-bold-webfont.woff
    A doc/pdal_rtd/static/fonts/miriamlibre-bold-webfont.woff2
    A doc/pdal_rtd/static/fonts/miriamlibre-regular-webfont.eot
    A doc/pdal_rtd/static/fonts/miriamlibre-regular-webfont.svg
    A doc/pdal_rtd/static/fonts/miriamlibre-regular-webfont.ttf
    A doc/pdal_rtd/static/fonts/miriamlibre-regular-webfont.woff
    A doc/pdal_rtd/static/fonts/miriamlibre-regular-webfont.woff2
    A doc/pdal_rtd/static/fonts/proximanova-light-webfont.eot
    A doc/pdal_rtd/static/fonts/proximanova-light-webfont.otf
    A doc/pdal_rtd/static/fonts/proximanova-light-webfont.svg
    A doc/pdal_rtd/static/fonts/proximanova-light-webfont.ttf
    A doc/pdal_rtd/static/fonts/proximanova-light-webfont.woff
    A doc/pdal_rtd/static/fonts/proximanova-sbold-webfont.eot
    A doc/pdal_rtd/static/fonts/proximanova-sbold-webfont.otf
    A doc/pdal_rtd/static/fonts/proximanova-sbold-webfont.svg
    A doc/pdal_rtd/static/fonts/proximanova-sbold-webfont.ttf
    A doc/pdal_rtd/static/fonts/proximanova-sbold-webfont.woff
    A doc/pdal_rtd/static/fonts/sintony-bold-webfont.eot
    A doc/pdal_rtd/static/fonts/sintony-bold-webfont.svg
    A doc/pdal_rtd/static/fonts/sintony-bold-webfont.ttf
    A doc/pdal_rtd/static/fonts/sintony-bold-webfont.woff
    A doc/pdal_rtd/static/fonts/sintony-bold-webfont.woff2
    A doc/pdal_rtd/static/fonts/sintony-regular-webfont.eot
    A doc/pdal_rtd/static/fonts/sintony-regular-webfont.svg
    A doc/pdal_rtd/static/fonts/sintony-regular-webfont.ttf
    A doc/pdal_rtd/static/fonts/sintony-regular-webfont.woff
    A doc/pdal_rtd/static/fonts/sintony-regular-webfont.woff2
    A doc/pdal_rtd/static/fonts/sourcecodepro-regular-webfont.eot
    A doc/pdal_rtd/static/fonts/sourcecodepro-regular-webfont.svg
    A doc/pdal_rtd/static/fonts/sourcecodepro-regular-webfont.ttf
    A doc/pdal_rtd/static/fonts/sourcecodepro-regular-webfont.woff
    A doc/pdal_rtd/static/img/hobu-emblem-32x32.png
    A doc/pdal_rtd/theme.conf
    A doc/pdal_rtd/versions.html
    R doc/rtd_theme/__init__.py
    R doc/rtd_theme/breadcrumbs.html
    R doc/rtd_theme/footer.html
    R doc/rtd_theme/layout.html
    R doc/rtd_theme/layout_old.html
    R doc/rtd_theme/search.html
    R doc/rtd_theme/searchbox.html
    R doc/rtd_theme/static/css/badge_only.css
    R doc/rtd_theme/static/css/badge_only.css.map
    R doc/rtd_theme/static/css/theme.css
    R doc/rtd_theme/static/css/theme.css.map
    R doc/rtd_theme/static/fonts/FontAwesome.otf
    R doc/rtd_theme/static/fonts/Inconsolata-Bold.ttf
    R doc/rtd_theme/static/fonts/Inconsolata-Regular.ttf
    R doc/rtd_theme/static/fonts/Lato-Bold.ttf
    R doc/rtd_theme/static/fonts/Lato-Regular.ttf
    R doc/rtd_theme/static/fonts/RobotoSlab-Bold.ttf
    R doc/rtd_theme/static/fonts/RobotoSlab-Regular.ttf
    R doc/rtd_theme/static/fonts/fontawesome-webfont.eot
    R doc/rtd_theme/static/fonts/fontawesome-webfont.svg
    R doc/rtd_theme/static/fonts/fontawesome-webfont.ttf
    R doc/rtd_theme/static/fonts/fontawesome-webfont.woff
    R doc/rtd_theme/static/js/modernizr.min.js
    R doc/rtd_theme/static/js/theme.js
    R doc/rtd_theme/theme.conf
    R doc/rtd_theme/versions.html
    M scripts/ci/build_docs.sh
  Log Message:
  Proper overrides of Sphinx RTD theme based on GDAL.org (#2928)
* WIP Sphinx RTD theme
* implement BoundlessGeo sphinx_rtd_theme based on GDAL.org
  Commit: 3ec842de4aa7124792f239cc7630cb3a64e5c8a3
      https://github.com/PDAL/PDAL/commit/3ec842de4aa7124792f239cc7630cb3a64e5c8a3
  Date:   2020-02-12 (Wed, 12 Feb 2020)
  Changed paths:
    M plugins/nitf/CMakeLists.txt
  Log Message:
  Nitro needs bad WIN32 macro.
  Commit: c6c8734ad98b8fda60e406d0d7a6b8131bdfcfd7
      https://github.com/PDAL/PDAL/commit/c6c8734ad98b8fda60e406d0d7a6b8131bdfcfd7
  Changed paths:
    M CMakeLists.txt
    M doc/conf.py
  Log Message:
  Merge remote-tracking branch 'origin/master' into issue-2923
  Commit: 6734036d73c4f90e6f4d6a2099600419bf3f9284
      https://github.com/PDAL/PDAL/commit/6734036d73c4f90e6f4d6a2099600419bf3f9284
  Changed paths:
    M io/LasReader.hpp
    M plugins/nitf/io/NitfFileReader.cpp
    M plugins/nitf/io/NitfReader.hpp
  Log Message:
  Merge remote-tracking branch 'origin/issue-2923' into issue-2923
Compare: https://github.com/PDAL/PDAL/compare/9028d5ae02e8...6734036d73c4
More information about the pdal-commits mailing list
