[pdal-commits] [PDAL/PDAL] a742a3: Type change for C++17
Andrew Bell noreply at github.com
Wed Feb 12 10:46:20 PST 2020
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: a742a3497107e262c6f08f057cb9a8b1c248ba2a
      https://github.com/PDAL/PDAL/commit/a742a3497107e262c6f08f057cb9a8b1c248ba2a
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2020-02-12 (Wed, 12 Feb 2020)
  Changed paths:
    M io/PlyReader.hpp
  Log Message:
  Commit: f2572ef60088020008fe2a0e7d81e5535c996fd8
      https://github.com/PDAL/PDAL/commit/f2572ef60088020008fe2a0e7d81e5535c996fd8
  Changed paths:
    M .gitattributes
    M CMakeLists.txt
    M apps/CMakeLists.txt
    M azure-pipelines.yml
    R cmake/sqlite.cmake
    M doc/conf.py
    A doc/pdal_rtd/README.md
    A doc/pdal_rtd/breadcrumbs.html
    A doc/pdal_rtd/footer.html
    A doc/pdal_rtd/searchbox.html
    A doc/pdal_rtd/static/css/pdal.css
    A doc/pdal_rtd/static/fonts/miriamlibre-bold-webfont.eot
    A doc/pdal_rtd/static/fonts/miriamlibre-bold-webfont.svg
    A doc/pdal_rtd/static/fonts/miriamlibre-bold-webfont.ttf
    A doc/pdal_rtd/static/fonts/miriamlibre-bold-webfont.woff
    A doc/pdal_rtd/static/fonts/miriamlibre-bold-webfont.woff2
    A doc/pdal_rtd/static/fonts/miriamlibre-regular-webfont.eot
    A doc/pdal_rtd/static/fonts/miriamlibre-regular-webfont.svg
    A doc/pdal_rtd/static/fonts/miriamlibre-regular-webfont.ttf
    A doc/pdal_rtd/static/fonts/miriamlibre-regular-webfont.woff
    A doc/pdal_rtd/static/fonts/miriamlibre-regular-webfont.woff2
    A doc/pdal_rtd/static/fonts/proximanova-light-webfont.eot
    A doc/pdal_rtd/static/fonts/proximanova-light-webfont.otf
    A doc/pdal_rtd/static/fonts/proximanova-light-webfont.svg
    A doc/pdal_rtd/static/fonts/proximanova-light-webfont.ttf
    A doc/pdal_rtd/static/fonts/proximanova-light-webfont.woff
    A doc/pdal_rtd/static/fonts/proximanova-sbold-webfont.eot
    A doc/pdal_rtd/static/fonts/proximanova-sbold-webfont.otf
    A doc/pdal_rtd/static/fonts/proximanova-sbold-webfont.svg
    A doc/pdal_rtd/static/fonts/proximanova-sbold-webfont.ttf
    A doc/pdal_rtd/static/fonts/proximanova-sbold-webfont.woff
    A doc/pdal_rtd/static/fonts/sintony-bold-webfont.eot
    A doc/pdal_rtd/static/fonts/sintony-bold-webfont.svg
    A doc/pdal_rtd/static/fonts/sintony-bold-webfont.ttf
    A doc/pdal_rtd/static/fonts/sintony-bold-webfont.woff
    A doc/pdal_rtd/static/fonts/sintony-bold-webfont.woff2
    A doc/pdal_rtd/static/fonts/sintony-regular-webfont.eot
    A doc/pdal_rtd/static/fonts/sintony-regular-webfont.svg
    A doc/pdal_rtd/static/fonts/sintony-regular-webfont.ttf
    A doc/pdal_rtd/static/fonts/sintony-regular-webfont.woff
    A doc/pdal_rtd/static/fonts/sintony-regular-webfont.woff2
    A doc/pdal_rtd/static/fonts/sourcecodepro-regular-webfont.eot
    A doc/pdal_rtd/static/fonts/sourcecodepro-regular-webfont.svg
    A doc/pdal_rtd/static/fonts/sourcecodepro-regular-webfont.ttf
    A doc/pdal_rtd/static/fonts/sourcecodepro-regular-webfont.woff
    A doc/pdal_rtd/static/img/hobu-emblem-32x32.png
    A doc/pdal_rtd/theme.conf
    A doc/pdal_rtd/versions.html
    M doc/references.rst
    R doc/rtd_theme/__init__.py
    R doc/rtd_theme/breadcrumbs.html
    R doc/rtd_theme/footer.html
    R doc/rtd_theme/layout.html
    R doc/rtd_theme/layout_old.html
    R doc/rtd_theme/search.html
    R doc/rtd_theme/searchbox.html
    R doc/rtd_theme/static/css/badge_only.css
    R doc/rtd_theme/static/css/badge_only.css.map
    R doc/rtd_theme/static/css/theme.css
    R doc/rtd_theme/static/css/theme.css.map
    R doc/rtd_theme/static/fonts/FontAwesome.otf
    R doc/rtd_theme/static/fonts/Inconsolata-Bold.ttf
    R doc/rtd_theme/static/fonts/Inconsolata-Regular.ttf
    R doc/rtd_theme/static/fonts/Lato-Bold.ttf
    R doc/rtd_theme/static/fonts/Lato-Regular.ttf
    R doc/rtd_theme/static/fonts/RobotoSlab-Bold.ttf
    R doc/rtd_theme/static/fonts/RobotoSlab-Regular.ttf
    R doc/rtd_theme/static/fonts/fontawesome-webfont.eot
    R doc/rtd_theme/static/fonts/fontawesome-webfont.svg
    R doc/rtd_theme/static/fonts/fontawesome-webfont.ttf
    R doc/rtd_theme/static/fonts/fontawesome-webfont.woff
    R doc/rtd_theme/static/js/modernizr.min.js
    R doc/rtd_theme/static/js/theme.js
    R doc/rtd_theme/theme.conf
    R doc/rtd_theme/versions.html
    M doc/stages/filters.crop.rst
    A doc/stages/filters.dbscan.rst
    M doc/stages/filters.python.rst
    M doc/stages/filters.reprojection.rst
    M doc/stages/filters.rst
    M doc/stages/filters.transformation.rst
    M doc/stages/readers.numpy.rst
    M filters/ClusterFilter.cpp
    M filters/ClusterFilter.hpp
    M filters/CropFilter.cpp
    M filters/CropFilter.hpp
    A filters/DBSCANFilter.cpp
    A filters/DBSCANFilter.hpp
    M filters/ELMFilter.cpp
    M filters/ReprojectionFilter.cpp
    M filters/ReprojectionFilter.hpp
    M io/LasHeader.cpp
    M io/PcdReader.cpp
    M kernels/InfoKernel.cpp
    M pdal/GDALUtils.cpp
    M pdal/GDALUtils.hpp
    M pdal/Geometry.hpp
    M pdal/KDIndex.hpp
    M pdal/Polygon.hpp
    M pdal/SpatialReference.cpp
    M pdal/SpatialReference.hpp
    M pdal/StageExtensions.cpp
    M pdal/private/SrsTransform.cpp
    M pdal/private/SrsTransform.hpp
    M pdal/util/Uuid.hpp
    M plugins/CMakeLists.txt
    M plugins/e57/CMakeLists.txt
    M plugins/e57/io/Utils.cpp
    M plugins/e57/libE57Format/CMakeLists.txt
    R plugins/e57/libE57Format/cmake/Modules/CMakeGenerateDocumentation.cmake
    R plugins/e57/libE57Format/cmake/Modules/FindICU.cmake
    R plugins/e57/libE57Format/cmake/Modules/Tags.cmake
    R plugins/e57/libE57Format/cmake/c_flag_overrides.cmake
    R plugins/e57/libE57Format/cmake/cxx_flag_overrides.cmake
    M plugins/e57/libE57Format/src/CheckedFile.cpp
    M plugins/e57/libE57Format/src/E57Exception.cpp
    M plugins/i3s/lepcc/src/ClusterRGB.cpp
    M plugins/i3s/lepcc/src/ClusterRGB.h
    M plugins/i3s/lepcc/src/Huffman.cpp
    M plugins/i3s/lepcc/src/include/lepcc_types.h
    M plugins/matlab/filters/Environment.cpp
    R plugins/python/CMakeLists.txt
    R plugins/python/filters/CMakeLists.txt
    R plugins/python/filters/PythonFilter.cpp
    R plugins/python/filters/PythonFilter.hpp
    R plugins/python/io/CMakeLists.txt
    R plugins/python/io/NumpyReader.cpp
    R plugins/python/io/NumpyReader.hpp
    R plugins/python/plang/Environment.cpp
    R plugins/python/plang/Environment.hpp
    R plugins/python/plang/Invocation.cpp
    R plugins/python/plang/Invocation.hpp
    R plugins/python/plang/Redirector.cpp
    R plugins/python/plang/Redirector.hpp
    R plugins/python/plang/Script.cpp
    R plugins/python/plang/Script.hpp
    R plugins/python/test/NumpyReaderTest.cpp
    R plugins/python/test/PythonFilterTest.cpp
    R plugins/python/test/make-test-data.py
    M plugins/rdb/CMakeLists.txt
    R plugins/sqlite/CMakeLists.txt
    R plugins/sqlite/io/SQLiteCommon.cpp
    R plugins/sqlite/io/SQLiteCommon.hpp
    R plugins/sqlite/io/SQLiteReader.cpp
    R plugins/sqlite/io/SQLiteReader.hpp
    R plugins/sqlite/io/SQLiteWriter.cpp
    R plugins/sqlite/io/SQLiteWriter.hpp
    R plugins/sqlite/test/SQLiteTest.cpp
    M plugins/tiledb/CMakeLists.txt
    M scripts/azp/doc.yml
    A scripts/azp/linux-conda.yml
    M scripts/azp/linux.yml
    M scripts/azp/osx.yml
    M scripts/azp/win.yml
    M scripts/ci/build_docs.sh
    M scripts/ci/script.sh
    M scripts/conda/osx.sh
    M scripts/conda/win64-setup.bat
    M scripts/conda/win64.bat
    M scripts/docker/ubuntu/Dockerfile
    A test/data/filters/elm2.txt
    A test/data/las/test_epsg_4326_axis.las
    A test/data/plang/threedim.py
    M test/unit/SpatialReferenceTest.cpp
    M test/unit/apps/InfoTest.cpp
    M test/unit/filters/CropFilterTest.cpp
    M test/unit/filters/ELMFilterTest.cpp
    M test/unit/filters/SkewnessFilterTest.cpp
    M tools/lasdump/Header.cpp
    M tools/nitfwrap/NitfWrap.cpp
    M vendor/eigen/Eigen/src/Core/ArrayWrapper.h
    M vendor/eigen/Eigen/src/Core/util/XprHelper.h
    M vendor/pdalboost/boost/iostreams/detail/adapter/concept_adapter.hpp
    M vendor/pdalboost/boost/iostreams/detail/functional.hpp
  Log Message:
  Merge remote-tracking branch 'origin/master'
  Commit: a1883d8e46576d2d824d4b2e9baedd864c8d8760
      https://github.com/PDAL/PDAL/commit/a1883d8e46576d2d824d4b2e9baedd864c8d8760
  Changed paths:
    R scripts/docker/alpine/Dockerfile
    A scripts/docker/alpine/Dockerfile.2.0
    M scripts/docker/alpine/Dockerfile.dependencies
    A scripts/docker/alpine/Dockerfile.master
  Log Message:
  Update Alpine Docker builds to 3.11.
Compare: https://github.com/PDAL/PDAL/compare/809c1ef4a267...a1883d8e4657
More information about the pdal-commits mailing list
