[pdal-commits] [PDAL/PDAL] 655403: Copy icebridge files over to hdf plugin
Howard Butler noreply at github.com
Wed Feb 12 11:24:43 PST 2020
  Branch: refs/heads/hdf
  Home:   https://github.com/PDAL/PDAL
  Commit: 655403687383ec8b50e9acfc504e6b9ef028905e
      https://github.com/PDAL/PDAL/commit/655403687383ec8b50e9acfc504e6b9ef028905e
  Author: Ryan Pals <ryan at hobu.co>
  Date:   2020-01-16 (Thu, 16 Jan 2020)
  Changed paths:
    M cmake/options.cmake
    M plugins/CMakeLists.txt
    A plugins/hdf/CMakeLists.txt
    A plugins/hdf/io/Hdf5Handler.cpp
    A plugins/hdf/io/Hdf5Handler.hpp
    A plugins/hdf/io/HdfReader.cpp
    A plugins/hdf/io/HdfReader.hpp
    A plugins/hdf/test/HdfReadertest.cpp
  Log Message:
  Commit: 226b1cdc8314e5d35a4d483b91c9d7019f070b5d
      https://github.com/PDAL/PDAL/commit/226b1cdc8314e5d35a4d483b91c9d7019f070b5d
  Date:   2020-01-27 (Mon, 27 Jan 2020)
  Changed paths:
    M plugins/hdf/CMakeLists.txt
    M plugins/hdf/io/Hdf5Handler.cpp
    M plugins/hdf/io/HdfReader.cpp
    M plugins/hdf/io/HdfReader.hpp
    M plugins/hdf/test/HdfReadertest.cpp
  Log Message:
  WIP
Print out info from hard-coded autzen. remove test points in test file. iterate over dimensions and print size, offset, type and endianness
  Commit: c4ce3d2d2faf19ec54156cf0495a5bc96b8294f9
      https://github.com/PDAL/PDAL/commit/c4ce3d2d2faf19ec54156cf0495a5bc96b8294f9
  Changed paths:
  Log Message:
  Remove unused
  Commit: b81353efb98cb455d1e5c355319b2c0c2ee1865c
      https://github.com/PDAL/PDAL/commit/b81353efb98cb455d1e5c355319b2c0c2ee1865c
  Date:   2020-01-28 (Tue, 28 Jan 2020)
  Changed paths:
    M plugins/hdf/io/Hdf5Handler.hpp
  Log Message:
  Compiles!
  Commit: 3eb420d429ad65885d87069fba28751b74c69fb3
      https://github.com/PDAL/PDAL/commit/3eb420d429ad65885d87069fba28751b74c69fb3
  Date:   2020-01-29 (Wed, 29 Jan 2020)
  Changed paths:
  Log Message:
  Reads!
  Commit: 7cd36a6e0abdd25c991f7c35e6576055d1f2791e
      https://github.com/PDAL/PDAL/commit/7cd36a6e0abdd25c991f7c35e6576055d1f2791e
  Date:   2020-01-30 (Thu, 30 Jan 2020)
  Changed paths:
  Log Message:
  Fix offset calculation
  Commit: 946fb64c4e80ed0231be2f6affd8e47457cafed7
      https://github.com/PDAL/PDAL/commit/946fb64c4e80ed0231be2f6affd8e47457cafed7
  Changed paths:
  Log Message:
  Fix hard coded struct size
  Commit: 929fc3f68060a6ef2eeddcf19a50ffdf21b1d2e1
      https://github.com/PDAL/PDAL/commit/929fc3f68060a6ef2eeddcf19a50ffdf21b1d2e1
  Changed paths:
  Log Message:
  Fix hard coded number of points
  Commit: 800712e29c88a8e688c24960a6c4aca88af3e8fe
      https://github.com/PDAL/PDAL/commit/800712e29c88a8e688c24960a6c4aca88af3e8fe
  Changed paths:
  Log Message:
  Remove hard coded dataset name, add dataset selection from stage options
  Commit: 19cae8a6c9f54f1b0b410ed3ba15c81e2efc0eb6
      https://github.com/PDAL/PDAL/commit/19cae8a6c9f54f1b0b410ed3ba15c81e2efc0eb6
  Changed paths:
  Log Message:
  Add case for non-compound datatypes
  Commit: 623777428849ed52713632ceda53c86df5c9cb07
      https://github.com/PDAL/PDAL/commit/623777428849ed52713632ceda53c86df5c9cb07
  Date:   2020-01-31 (Fri, 31 Jan 2020)
  Changed paths:
  Log Message:
  Fix compound case
  Commit: 8d4b4199b45aa47f3a45131015cbfba195dff8b8
      https://github.com/PDAL/PDAL/commit/8d4b4199b45aa47f3a45131015cbfba195dff8b8
  Date:   2020-02-04 (Tue, 04 Feb 2020)
  Changed paths:
  Log Message:
  Remove code for compound types
  Commit: fb4254307dd2d30a39bb0a331262f832a0806ab5
      https://github.com/PDAL/PDAL/commit/fb4254307dd2d30a39bb0a331262f832a0806ab5
  Changed paths:
  Log Message:
  Add ability to name dataset
  Commit: f7e62a28cf78f64426f294beaaab2fa950ed57d8
      https://github.com/PDAL/PDAL/commit/f7e62a28cf78f64426f294beaaab2fa950ed57d8
  Date:   2020-02-06 (Thu, 06 Feb 2020)
  Changed paths:
  Log Message:
  Cleanup
  Commit: 408fed567aadb1f38876dd08d01376a30b26354a
      https://github.com/PDAL/PDAL/commit/408fed567aadb1f38876dd08d01376a30b26354a
  Changed paths:
  Log Message:
  Fix type bug
  Commit: c865e880c10dcf0b05e9b7b9ba258ab62d2b12b5
      https://github.com/PDAL/PDAL/commit/c865e880c10dcf0b05e9b7b9ba258ab62d2b12b5
  Date:   2020-02-07 (Fri, 07 Feb 2020)
  Changed paths:
  Log Message:
  Reads one chunk - wip
  Commit: 1dc6ce367922f17116237b2d008df6d446c015e2
      https://github.com/PDAL/PDAL/commit/1dc6ce367922f17116237b2d008df6d446c015e2
  Changed paths:
  Log Message:
  WIP
  Commit: b079046dc0315c4d7db747a4bc5d583163a50e72
      https://github.com/PDAL/PDAL/commit/b079046dc0315c4d7db747a4bc5d583163a50e72
  Changed paths:
  Log Message:
  No longer segfaults - wip
  Commit: bcd8c3aeea62590032593a18c07f33aee4174762
      https://github.com/PDAL/PDAL/commit/bcd8c3aeea62590032593a18c07f33aee4174762
  Changed paths:
  Log Message:
  Reads an entire array
  Commit: 63ace00706596a3eb766296da8c7b2dc9c543dc7
      https://github.com/PDAL/PDAL/commit/63ace00706596a3eb766296da8c7b2dc9c543dc7
  Changed paths:
  Log Message:
  Add JSON
  Commit: 6f1202171ac3ca7937e040936678e2ffcef9ad17
      https://github.com/PDAL/PDAL/commit/6f1202171ac3ca7937e040936678e2ffcef9ad17
  Changed paths:
  Log Message:
  Read dataset and dims from JSON map
  Commit: aac7c0c73e5bb67ae3f17b070f6e26ccb8a21a63
      https://github.com/PDAL/PDAL/commit/aac7c0c73e5bb67ae3f17b070f6e26ccb8a21a63
  Changed paths:
  Log Message:
  WIP
  Commit: 1ef7923712f85c380226636fd4bc5bd6b9c6aa74
      https://github.com/PDAL/PDAL/commit/1ef7923712f85c380226636fd4bc5bd6b9c6aa74
  Changed paths:
  Log Message:
  Remove unused
  Commit: c017b1f1b665f794ce5ff92a9ddc3b2eb9134857
      https://github.com/PDAL/PDAL/commit/c017b1f1b665f794ce5ff92a9ddc3b2eb9134857
  Changed paths:
  Log Message:
  Cleanup
  Commit: c138fb751043c63cef3bafd8f9889784fdab2724
      https://github.com/PDAL/PDAL/commit/c138fb751043c63cef3bafd8f9889784fdab2724
  Date:   2020-02-10 (Mon, 10 Feb 2020)
  Changed paths:
  Log Message:
  Fix key-value misordering
  Commit: 89dc09f52334f5e73386b59fabd2e085e1c4be5f
      https://github.com/PDAL/PDAL/commit/89dc09f52334f5e73386b59fabd2e085e1c4be5f
  Changed paths:
    M .gitattributes
    M CMakeLists.txt
    M apps/CMakeLists.txt
    M azure-pipelines.yml
    R cmake/sqlite.cmake
    M doc/references.rst
    A doc/stages/filters.dbscan.rst
    M doc/stages/filters.python.rst
    M doc/stages/filters.rst
    M doc/stages/filters.transformation.rst
    M doc/stages/readers.numpy.rst
    M doc/stages/readers.text.rst
    M filters/ClusterFilter.cpp
    M filters/ClusterFilter.hpp
    A filters/DBSCANFilter.cpp
    A filters/DBSCANFilter.hpp
    M filters/ELMFilter.cpp
    M filters/HAGFilter.cpp
    M filters/OutlierFilter.cpp
    M filters/PMFFilter.cpp
    M filters/SMRFilter.cpp
    M filters/SkewnessBalancingFilter.cpp
    M io/LasHeader.cpp
    M io/PcdReader.cpp
    M kernels/InfoKernel.cpp
    M pdal/GDALUtils.cpp
    M pdal/Geometry.hpp
    M pdal/KDIndex.hpp
    M pdal/Polygon.hpp
    M pdal/StageExtensions.cpp
    M pdal/pdal_types.hpp
    M pdal/util/Uuid.hpp
    M plugins/e57/CMakeLists.txt
    M plugins/e57/io/Utils.cpp
    M plugins/e57/libE57Format/CMakeLists.txt
    R plugins/e57/libE57Format/cmake/Modules/CMakeGenerateDocumentation.cmake
    R plugins/e57/libE57Format/cmake/Modules/FindICU.cmake
    R plugins/e57/libE57Format/cmake/Modules/Tags.cmake
    R plugins/e57/libE57Format/cmake/c_flag_overrides.cmake
    R plugins/e57/libE57Format/cmake/cxx_flag_overrides.cmake
    M plugins/e57/libE57Format/src/CheckedFile.cpp
    M plugins/e57/libE57Format/src/E57Exception.cpp
    M plugins/i3s/lepcc/src/ClusterRGB.cpp
    M plugins/i3s/lepcc/src/ClusterRGB.h
    M plugins/i3s/lepcc/src/Huffman.cpp
    M plugins/i3s/lepcc/src/include/lepcc_types.h
    M plugins/matlab/filters/Environment.cpp
    R plugins/python/CMakeLists.txt
    R plugins/python/filters/CMakeLists.txt
    R plugins/python/filters/PythonFilter.cpp
    R plugins/python/filters/PythonFilter.hpp
    R plugins/python/io/CMakeLists.txt
    R plugins/python/io/NumpyReader.cpp
    R plugins/python/io/NumpyReader.hpp
    R plugins/python/plang/Environment.cpp
    R plugins/python/plang/Environment.hpp
    R plugins/python/plang/Invocation.cpp
    R plugins/python/plang/Invocation.hpp
    R plugins/python/plang/Redirector.cpp
    R plugins/python/plang/Redirector.hpp
    R plugins/python/plang/Script.cpp
    R plugins/python/plang/Script.hpp
    R plugins/python/test/NumpyReaderTest.cpp
    R plugins/python/test/PythonFilterTest.cpp
    R plugins/python/test/make-test-data.py
    M plugins/rdb/CMakeLists.txt
    R plugins/sqlite/CMakeLists.txt
    R plugins/sqlite/io/SQLiteCommon.cpp
    R plugins/sqlite/io/SQLiteCommon.hpp
    R plugins/sqlite/io/SQLiteReader.cpp
    R plugins/sqlite/io/SQLiteReader.hpp
    R plugins/sqlite/io/SQLiteWriter.cpp
    R plugins/sqlite/io/SQLiteWriter.hpp
    R plugins/sqlite/test/SQLiteTest.cpp
    M plugins/tiledb/CMakeLists.txt
    M scripts/azp/doc.yml
    A scripts/azp/linux-conda.yml
    M scripts/azp/linux.yml
    M scripts/azp/osx.yml
    M scripts/azp/win.yml
    M scripts/ci/script.sh
    M scripts/conda/osx.sh
    M scripts/conda/win64-setup.bat
    M scripts/conda/win64.bat
    M scripts/docker/ubuntu/Dockerfile
    A test/data/filters/elm2.txt
    A test/data/plang/threedim.py
    M test/unit/apps/InfoTest.cpp
    M test/unit/filters/AssignFilterTest.cpp
    M test/unit/filters/ELMFilterTest.cpp
    M test/unit/filters/HAGFilterTest.cpp
    M test/unit/filters/OverlayFilterTest.cpp
    M test/unit/filters/SMRFilterTest.cpp
    M test/unit/filters/SkewnessFilterTest.cpp
    M test/unit/io/EptAddonWriterTest.cpp
    M test/unit/io/TerrasolidReaderTest.cpp
    M tools/lasdump/Header.cpp
    M tools/nitfwrap/NitfWrap.cpp
    M vendor/eigen/Eigen/src/Core/ArrayWrapper.h
    M vendor/eigen/Eigen/src/Core/util/XprHelper.h
    M vendor/pdalboost/boost/iostreams/detail/adapter/concept_adapter.hpp
    M vendor/pdalboost/boost/iostreams/detail/functional.hpp
  Log Message:
  Merge branch 'master' of https://github.com/PDAL/PDAL into hdf
  Commit: 87a02862436116b5bc4f07f00471e9242e4a1946
      https://github.com/PDAL/PDAL/commit/87a02862436116b5bc4f07f00471e9242e4a1946
  Date:   2020-02-12 (Wed, 12 Feb 2020)
  Changed paths:
  Log Message:
  Works for multiple dims
  Commit: 91323316a1a8d811e4c305ac9ba85ef2de42017f
      https://github.com/PDAL/PDAL/commit/91323316a1a8d811e4c305ac9ba85ef2de42017f
  Changed paths:
  Log Message:
  Use proper loggers
  Commit: 6f43b31f85a5b62f5661f1f566fade1b16cad7cd
      https://github.com/PDAL/PDAL/commit/6f43b31f85a5b62f5661f1f566fade1b16cad7cd
  Author: Howard Butler <howard at hobu.co>
  Changed paths:
    A test/data/hdf/autzen.h5
  Log Message:
  add simple readers.hdf test based on autzen
Compare: https://github.com/PDAL/PDAL/compare/655403687383%5E...6f43b31f85a5
More information about the pdal-commits mailing list
