[pdal-commits] [PDAL/PDAL] b40acc: Always register X/Y/Z as doubles (#2932)
Andrew Bell noreply at github.com
Thu Feb 13 11:45:56 PST 2020
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: b40acc700fb5b666b44e7f7b949b0c03b5b53cf3
      https://github.com/PDAL/PDAL/commit/b40acc700fb5b666b44e7f7b949b0c03b5b53cf3
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2020-02-13 (Thu, 13 Feb 2020)
  Changed paths:
    M io/BpfReader.cpp
    M io/EptReader.cpp
    M io/MemoryViewReader.cpp
    M io/private/EptSupport.cpp
    M io/private/EptSupport.hpp
    M pdal/DbReader.cpp
    M pdal/PointLayout.cpp
    M plugins/mrsid/io/MrsidReader.cpp
    M test/unit/PointTableTest.cpp
  Log Message:
* Always create XYZ as doubles.
* Fix EPT reader now that XYZ are forced to be doubles (#2926)
* Initial commit of DBSCAN clustering
* Begin playing around with n-dimensional KDIndex
* Finishing KDFlexIndex
* Initialize bbox properly
* Implicit deletes and move ctor to CPP
* Remove the explicit KDNormalIndex as it can be replicated with KDFlexIndex
* Move KDFlexIndex from DBSCANFilter to KDIndex
* Add note about dimensions in the docs
* Default dimensions to X,Y,Z
* Clarification on dimensions when setting min_points
* Add a new n-dimensional index called KDFlexIndex to KDIndex
* Add a test for the ELM filter (#2869)
* Add simple test for ELM filter.
* Add a second test.
* bump version to 2.1.0 to eliminate confusion with 2.0.0 builds when using master
* Python filter doc (#2879)
* Add a warning to remember numpy needs to be installed
* Use appropriate key for file name
* Fix some code indent issues
* NitfWrap: Fix compilation error 'pdal::Log::Log(const string&, const string&, bool) is private within this context' (#2877)
* Gdal utils doc (#2884)
* Update docs for GDALUtils.
Fix leaks and such in getPolygons().
* Move dialect declaration.
* Register ClusterID dimension in filters.cluster (#2887)
* Make ClusterID a built-in dimension.
* Make sure cluster dimension gets registered.
* Support passing a reference to a .py script to readers.numpy along with function/module/args options that reference a function that returns a Numpy array (#2867)
* support passing a reference to a .py script to readers.numpy along with function/module/args options that reference a function that returns a Numpy array
* make sure to add nlohman includes
* address review comments in #2867
* increment PDAL version to 2.1 to avoid collision
* remove unused reference to nlohman
* [WIP] Add little description on transformation filter (#2747)
* add graphics and first description
* fix styling
* fix styling
* add description for more tranformations
* fix wrong order for z-axis rotation, add more description about figures
* fix typo
* refine text
* refine text
* Add versionadded
* Force X/Y/Z to 64 bit. (#2893)
* require C++17 #2890 (#2896)
* remove SQLite drivers #2646 (#2897)
* remove CMake for sqlite
* update to next OSX azp image (#2901)
* Fix compilation on newer clang.
* RDB windows build tweaks (#2909)
* tiledb and e57 config
* rdb building on windows
* rdb win64.bat
* move Python to https://github.com/PDAL/python (#2895)
* adjust azp scripts for python removal
* remove travis python config
* remove more python cruft
* Don't do memcpy (#2910)
* Don't do memcpy.
* Pair is value-initialized (0'd).  No need to memset.
* Gcc9.2 fixes (#2913)
* GCC 9.2 fixes.
* Explicitly delete undefined assignment operators so that we actually
generate copy ctors that we need.
* Eigen fixes for GCC 9.2.
* Implement a Linux build based on Conda with a pinned GDAL dependency (#2911)
* add Linux/Conda build
* fix job name
* conda junk
* set uid/gid
* set uid:gid
* conda user stuff again
* more usermod
* clobber /opt/conda perms
* clobber user to vsts_azpcontainer
* use azp conda
* fix syntax
* remove manual env setting
* conda init
* LD_FLAGS
* no pin
* another swing
* selectively shut off tiledb tests with BUILD_TILEDB_TESTS
* try pinning gdal
* use correct GDAL pin
* Add reader, now, and file_size keys to pdal info output (#2900)
* scratch
* add now, file_size, and reader to 'pdal info' output
* add debug lint
* update test output
* output comparison information when we fail a pdal info test
* fix up comparison test
* Simplify E57 build and fix warnings. (#2914)
* Refined wording of transformation filter documentation (#2915)
* pdal-config on windows
* Windows updates (#2917)
* Updates for VS 2017
* Use constexpr function call for Uuid size.
* make AzP/Windows use GDAL 3 (#2918)
* E57 changes for GCC 9.2.
* add AzP/docs build (#2919)
* try uploading doc builds to s3
* rejigger variables
* remove extraneous ninja command
* variable settings
* variable quoting
* more variable churn
* more variable churns
* one more time
* azp variable churning some more
* build PDF too
* output URLs
* condition doc upload for only PullRequest
* yaml is whitespace sensitive
* --quiet aws sync
* try var subst again
* quiet file upload
* try quoting var
* reenable the rest of CI
* Revert #2890 – use C++11 as standard instead of C++17
* Check for empty PointView in ELM filter (#2924)
* Add method to EPT's FixedPointLayout to allow it to contain non-double XYZs to match a remote buffer layout.
Co-authored-by: chambbj <brad.chambers at gmail.com>
Co-authored-by: Andrew Bell <andrew.bell.ia at gmail.com>
Co-authored-by: Howard Butler <howard at hobu.co>
Co-authored-by: Jules Robichaud-Gagnon <j.robichaudg at gmail.com>
Co-authored-by: Nick M Cummins <nickmcummins at gmail.com>
Co-authored-by: vvmruder <vvmruder at users.noreply.github.com>
Co-authored-by: Connor Manning <connor at hobu.co>
More information about the pdal-commits mailing list
