[pdal-commits] [PDAL/PDAL] dfdf56: Make chunkSize a property of dimension, rather tha...
Howard Butler noreply at github.com
Sat Feb 15 14:08:12 PST 2020
  Branch: refs/heads/howard-hdf
  Home:   https://github.com/PDAL/PDAL
  Commit: dfdf56cf7100447c8befd82ec89e9e33378f979a
      https://github.com/PDAL/PDAL/commit/dfdf56cf7100447c8befd82ec89e9e33378f979a
  Author: Ryan Pals <ryan at hobu.co>
  Date:   2020-02-12 (Wed, 12 Feb 2020)
  Changed paths:
    M plugins/hdf/io/Hdf5Handler.cpp
    M plugins/hdf/io/Hdf5Handler.hpp
    M plugins/hdf/io/HdfReader.cpp
  Log Message:
  Make chunkSize a property of dimension, rather than file
  Commit: 78dbe8e3daf98169b5e932b8d460224ba87f964c
      https://github.com/PDAL/PDAL/commit/78dbe8e3daf98169b5e932b8d460224ba87f964c
  Changed paths:
    M plugins/hdf/io/HdfReader.hpp
  Log Message:
  Clean up loop
  Commit: 6cf5509fa6ad9eb5bf24b17554db6117ff75c5c3
      https://github.com/PDAL/PDAL/commit/6cf5509fa6ad9eb5bf24b17554db6117ff75c5c3
  Changed paths:
  Log Message:
  Fix indexing bug
  Commit: 4d7b26f7e51425fd906657086a5711219d77c77f
      https://github.com/PDAL/PDAL/commit/4d7b26f7e51425fd906657086a5711219d77c77f
  Changed paths:
  Log Message:
  Init buffers in prepare() instead of read()
  Commit: 53c47932eb8ad7280b9c381c35b02f6fc9ba9a94
      https://github.com/PDAL/PDAL/commit/53c47932eb8ad7280b9c381c35b02f6fc9ba9a94
  Changed paths:
  Log Message:
  Streams!!!
  Commit: a07c77a4c6f5e68ff3e25cdcc6d0fe4ac8439b97
      https://github.com/PDAL/PDAL/commit/a07c77a4c6f5e68ff3e25cdcc6d0fe4ac8439b97
  Changed paths:
    M plugins/hdf/CMakeLists.txt
    M plugins/hdf/test/HdfReadertest.cpp
    M scripts/conda/osx.sh
    A test/data/hdf/autzen.h5
  Log Message:
  Merge Howard's unit test
  Commit: 5cb7dc032bdc456f7a57150b90d62c75becf50ab
      https://github.com/PDAL/PDAL/commit/5cb7dc032bdc456f7a57150b90d62c75becf50ab
  Date:   2020-02-13 (Thu, 13 Feb 2020)
  Changed paths:
  Log Message:
  Fix sign-compare warning
  Commit: 6fb77d011145026c3201672ab1534643834a4720
      https://github.com/PDAL/PDAL/commit/6fb77d011145026c3201672ab1534643834a4720
  Changed paths:
  Log Message:
  Add json validation
  Commit: 40cd57ba58291d176bbe7c1c9e056b4557aab550
      https://github.com/PDAL/PDAL/commit/40cd57ba58291d176bbe7c1c9e056b4557aab550
  Changed paths:
  Log Message:
  Check that all datasets are the same length
  Commit: efe6f09c173f58a4b22e0a0cd3716f3755e6229b
      https://github.com/PDAL/PDAL/commit/efe6f09c173f58a4b22e0a0cd3716f3755e6229b
  Changed paths:
    M test/data/hdf/autzen.h5
  Log Message:
  Update test data file with metadata
  Commit: 8acff989cef51f47e2181b24ca98c563cfa857cc
      https://github.com/PDAL/PDAL/commit/8acff989cef51f47e2181b24ca98c563cfa857cc
  Changed paths:
    A doc/stages/readers.hdf.rst
  Log Message:
  Add HDF Reader docs WIP
  Commit: 28b856e200991d58ce65e1b8230524eb4c1e0f21
      https://github.com/PDAL/PDAL/commit/28b856e200991d58ce65e1b8230524eb4c1e0f21
  Changed paths:
  Log Message:
  Add check for null map
  Commit: 14060fb46335c82eb2d6990581885b8db836659b
      https://github.com/PDAL/PDAL/commit/14060fb46335c82eb2d6990581885b8db836659b
  Changed paths:
    M scripts/azp/linux-conda.yml
    M scripts/azp/linux.yml
    M scripts/azp/osx.yml
    M scripts/azp/win.yml
  Log Message:
  Add HDF plugin to AZP
  Commit: b0d17c2c8ff5be9f482a3d19313d53b764540c1a
      https://github.com/PDAL/PDAL/commit/b0d17c2c8ff5be9f482a3d19313d53b764540c1a
  Changed paths:
  Log Message:
  Connor's changes
  Commit: f62e6bbe3ed944eb671d9fd056765a6445f80232
      https://github.com/PDAL/PDAL/commit/f62e6bbe3ed944eb671d9fd056765a6445f80232
  Changed paths:
  Log Message:
  Stuff WIP
  Commit: 7984754cdf472ad400bf4d0bbf65d9e14b4ec654
      https://github.com/PDAL/PDAL/commit/7984754cdf472ad400bf4d0bbf65d9e14b4ec654
  Date:   2020-02-14 (Fri, 14 Feb 2020)
  Changed paths:
    M doc/stages/readers.hdf.rst
  Log Message:
  Review changes
  Commit: 3ca185d617066ed7e5bdb70004cb0a089eb77f7e
      https://github.com/PDAL/PDAL/commit/3ca185d617066ed7e5bdb70004cb0a089eb77f7e
  Changed paths:
  Log Message:
  Feedback
  Commit: 138ab4c7e087e70f6a4610ffe1cca5c0db4210b8
      https://github.com/PDAL/PDAL/commit/138ab4c7e087e70f6a4610ffe1cca5c0db4210b8
  Changed paths:
  Log Message:
  Address feedback
  Commit: 8d0acf57d05a2084627e3bd3a98931d7f9098536
      https://github.com/PDAL/PDAL/commit/8d0acf57d05a2084627e3bd3a98931d7f9098536
  Date:   2020-02-15 (Sat, 15 Feb 2020)
  Changed paths:
  Log Message:
  Add more test cases
  Commit: c4e65a261269a5efac12394ab8461a1da3c7b376
      https://github.com/PDAL/PDAL/commit/c4e65a261269a5efac12394ab8461a1da3c7b376
  Author: Howard Butler <howard at hobu.co>
  Changed paths:
  Log Message:
  random chunk sizes, check GPSTime
Compare: https://github.com/PDAL/PDAL/compare/dfdf56cf7100%5E...c4e65a261269
More information about the pdal-commits mailing list
