[pdal-commits] [PDAL/PDAL] 072659: Add Cloth Simulation Filter (CSF) (#2766)
Andrew Bell noreply at github.com
Fri Feb 21 11:45:15 PST 2020
  Branch: refs/heads/issue-2560
  Home:   https://github.com/PDAL/PDAL
  Commit: 072659a4bfe286e6cd89ae67f35c59df0dd76bee
      https://github.com/PDAL/PDAL/commit/072659a4bfe286e6cd89ae67f35c59df0dd76bee
  Author: chambbj <brad.chambers at gmail.com>
  Date:   2020-02-20 (Thu, 20 Feb 2020)
  Changed paths:
    M doc/references.rst
    A doc/stages/filters.csf.rst
    M doc/stages/filters.rst
    A filters/CSFilter.cpp
    A filters/CSFilter.hpp
    A filters/private/csf/CSF.cpp
    A filters/private/csf/CSF.h
    A filters/private/csf/Cloth.cpp
    A filters/private/csf/Cloth.h
    A filters/private/csf/Constraint.cpp
    A filters/private/csf/Constraint.h
    A filters/private/csf/Particle.cpp
    A filters/private/csf/Particle.h
    A filters/private/csf/Rasterization.cpp
    A filters/private/csf/Rasterization.h
    A filters/private/csf/Vec3.h
    A filters/private/csf/XYZReader.cpp
    A filters/private/csf/XYZReader.h
    A filters/private/csf/c2cdist.cpp
    A filters/private/csf/c2cdist.h
    A filters/private/csf/point_cloud.cpp
    A filters/private/csf/point_cloud.h
    M test/unit/CMakeLists.txt
    A test/unit/filters/CSFilterTest.cpp
  Log Message:
* Add Cloth Simulation Filter (CSF)
* OpenMP intentionally left out for now
* Address PR recommendation to add try-catch block
  Commit: afbe6f7794bfe40394f27f46b2a6da0da3f1afb2
      https://github.com/PDAL/PDAL/commit/afbe6f7794bfe40394f27f46b2a6da0da3f1afb2
  Changed paths:
    M filters/SMRFilter.cpp
    M filters/private/Segmentation.cpp
    M filters/private/Segmentation.hpp
    M pdal/pdal_types.hpp
    A test/data/las/synthetic_test.las
    M test/unit/io/LasReaderTest.cpp
    M test/unit/io/LasWriterTest.cpp
  Log Message:
  Add some initial support for handling synthetic points (#2925)
* Add some initial support for handling synthetic points
* Add tests for LasReader and LasWriter
* Add method to Segmentation.cpp to separate PointViews into synthetic
  and real points
* Add arguments to SMRF to allow/ignore synthetic points during
  processing
* Add Synthetic to the list of ClassLabels (though this doesn't exactly
  hold for LAS1.4)
* Alter options to allow ignoring of any combination of class bits
  Commit: 227855a35532b7e978245a6e1a1072aa00bfd36a
      https://github.com/PDAL/PDAL/commit/227855a35532b7e978245a6e1a1072aa00bfd36a
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2020-02-21 (Fri, 21 Feb 2020)
  Changed paths:
    M filters/private/csf/Cloth.cpp
    M filters/private/csf/Cloth.h
    M filters/private/csf/Constraint.h
  Log Message:
  Eliminate unused variables.
  Commit: b56e84b7ab144ecf35fbfe980b1bfa3fc720dc0c
      https://github.com/PDAL/PDAL/commit/b56e84b7ab144ecf35fbfe980b1bfa3fc720dc0c
  Changed paths:
    M io/LasVLR.cpp
    M io/LasVLR.hpp
    M io/LasWriter.cpp
    M io/LasWriter.hpp
    M pdal/PipelineReaderJSON.cpp
    A test/data/pipeline/issue2937.json.in
  Log Message:
  Handle VLRs as pipeline arguments in writers.las (#2942)
* Make user VLR handling robust.
* Cleanup.
* Remove dead header.
* Make things with with Ext VLRs.
* Add more test.
* One more test.
* Remove unnecessary cast.
* Add a real test for the original problem.
* Cleaner logic.
  Commit: b199b905646f1f16fee688b51c8d940c7e21fefb
      https://github.com/PDAL/PDAL/commit/b199b905646f1f16fee688b51c8d940c7e21fefb
  Changed paths:
    M doc/stages/filters.voxeldownsize.rst
    M filters/VoxelDownsizeFilter.cpp
    M filters/VoxelDownsizeFilter.hpp
    M test/unit/filters/VoxelDownsizeFilterTest.cpp
  Log Message:
  Fix tests for voxel filter. (#2941)
* Fix voxel downsize filter/tests.
* Improve language.
* Enhance warning text.
* Fix mode names in doc and mode name output.
  Commit: 366bd3b78249ad8734e6f245780f7c6a8aedb514
      https://github.com/PDAL/PDAL/commit/366bd3b78249ad8734e6f245780f7c6a8aedb514
  Author: Ryan Pals <ryan at hobu.co>
  Changed paths:
    M cmake/options.cmake
    A doc/stages/readers.hdf.rst
    M plugins/CMakeLists.txt
    A plugins/hdf/CMakeLists.txt
    A plugins/hdf/io/Hdf5Handler.cpp
    A plugins/hdf/io/Hdf5Handler.hpp
    A plugins/hdf/io/HdfReader.cpp
    A plugins/hdf/io/HdfReader.hpp
    A plugins/hdf/test/HdfReadertest.cpp
    M scripts/azp/linux-conda.yml
    M scripts/azp/linux.yml
    M scripts/azp/osx.yml
    M scripts/azp/win.yml
    M scripts/conda/osx.sh
    A test/data/hdf/autzen.h5
  Log Message:
  HDF Reader (#2934)
* Copy icebridge files over to hdf plugin
* WIP
Print out info from hard-coded autzen. remove test points in test file. iterate over dimensions and print size, offset, type and endianness
* Remove unused
* Compiles!
* Reads!
* Fix offset calculation
* Fix hard coded struct size
* Fix hard coded number of points
* Remove hard coded dataset name, add dataset selection from stage options
* Add case for non-compound datatypes
* Fix compound case
* Remove code for compound types
* Add ability to name dataset
* Cleanup
* Fix type bug
* Reads one chunk - wip
* WIP
* No longer segfaults - wip
* Reads an entire array
* Add JSON
* Read dataset and dims from JSON map
* WIP
* Remove unused
* Cleanup
* Fix key-value misordering
* Works for multiple dims
* Use proper loggers
* add simple readers.hdf test based on autzen
* Make chunkSize a property of dimension, rather than file
* Clean up loop
* Fix indexing bug
* Init buffers in prepare() instead of read()
* Streams!!!
* Fix sign-compare warning
* Add json validation
* Check that all datasets are the same length
* Update test data file with metadata
* Add HDF Reader docs WIP
* Add check for null map
* Add HDF plugin to AZP
* Connor's changes
* Stuff WIP
* Review changes
* Feedback
* Address feedback
* Add more test cases
* random chunk sizes, check GPSTime
* CMake feedback: Cleanup, remove LibXML2
* Get rid of compiler warnings
* Address doc feedback
* Cleanup
* Step 1
* Step 2
* Remove BufferInfo; return pointer to val instead of pointer to bufer
* Remove unused
* Get rid of m_buffers
* Style
* Get rid of all parallel vectors
* Don't open dataset on each point. Fixes 20x performance regression introduced by last commit
* Use range based for-loops
* Remove unused
* Move Handler class into hdf5 namespace
* Fix outdated error
* Sepearte initialization code into constructor
* Cleanup
* Make getValue a method of DimInfo instead of Handler
* Styling
* Remove unused
* Use fewer auto types
* Change shared_ptr to unique_ptr
* Fix macOS compiler warning
Co-authored-by: Howard Butler <howard at hobu.co>
  Commit: 9777bf04c39ce80d7cb896b26b99dfc5b60c4506
      https://github.com/PDAL/PDAL/commit/9777bf04c39ce80d7cb896b26b99dfc5b60c4506
  Changed paths:
    M io/LasVLR.cpp
    M io/LasVLR.hpp
    M io/LasWriter.cpp
    M io/LasWriter.hpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into issue-2560
  Commit: 52b3d2a2a51fc12719d8aee7f6692ca88b1139c1
      https://github.com/PDAL/PDAL/commit/52b3d2a2a51fc12719d8aee7f6692ca88b1139c1
  Changed paths:
    M pdal/PointView.hpp
  Log Message:
  Merge remote-tracking branch 'origin/issue-2560' into issue-2560
Compare: https://github.com/PDAL/PDAL/compare/e0e3f556dbb8...52b3d2a2a51f
More information about the pdal-commits mailing list
