[pdal-commits] [PDAL/PDAL] 5be7c4: tiledb: use internal array metadata for pipeline s...
Norman Barker noreply at github.com
Thu Feb 27 11:43:37 PST 2020
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 5be7c48b3501a6092aef70fc35ee9d75f11a61f4
      https://github.com/PDAL/PDAL/commit/5be7c48b3501a6092aef70fc35ee9d75f11a61f4
  Author: Norman Barker <norman at tiledb.io>
  Date:   2020-02-27 (Thu, 27 Feb 2020)
  Changed paths:
    M plugins/tiledb/CMakeLists.txt
    M plugins/tiledb/io/TileDBReader.cpp
    M plugins/tiledb/io/TileDBWriter.cpp
    M plugins/tiledb/io/TileDBWriter.hpp
    M plugins/tiledb/test/TileDBReaderTest.cpp
    M plugins/tiledb/test/TileDBWriterTest.cpp
    M test/data/tiledb/array/pdal.json
  Log Message:
  tiledb: use internal array metadata for pipeline serialization (#2838)
* tiledb: use internal array metadata for pipeline serialization
* tiledb: added srs support
* removed unused sidecar reference in reader test
* fixed tests for PR
* include stage metadata
* added json prop check if metadata is an empty array
* fix bug with m_arrayName and TileDB lt 1.7
* tiledb: Fix irrelevant comment
* enable tiledb tests
More information about the pdal-commits mailing list
