[pdal-commits] [PDAL/PDAL] 66243a: More cleanup of skewness filter (#2866)
Andrew Bell noreply at github.com
Fri Jan 10 10:06:25 PST 2020
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 66243ab90364972ef60fe581e75eb8fc0bf1c831
      https://github.com/PDAL/PDAL/commit/66243ab90364972ef60fe581e75eb8fc0bf1c831
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2020-01-10 (Fri, 10 Jan 2020)
  Changed paths:
    M filters/SkewnessBalancingFilter.cpp
    M filters/SkewnessBalancingFilter.hpp
    M test/unit/CMakeLists.txt
    M test/unit/apps/InfoTest.cpp
    A test/unit/filters/SkewnessFilterTest.cpp
  Log Message:
* Hope this addresses the issue Even brought up.  We need a test.
* Change the processing a bit to simplify and eliminate array OOB problem.
* Compilation fixes.
* Rework to make more clear (hopefully) and eliminate potential OOB situations.
* Missed test file.
* Update arg names from begin/end to first/last.
Set class to non-ground.
* Find build error.
* More test.
More information about the pdal-commits mailing list
