[pdal-commits] [PDAL/PDAL] 9c3c69: Make ClusterID a built-in dimension.
Andrew Bell noreply at github.com
Fri Jan 24 12:38:58 PST 2020
  Branch: refs/heads/issue-2852
  Home:   https://github.com/PDAL/PDAL
  Commit: 9c3c69e409b2d83d60cd7ea4cb8730c41827016a
      https://github.com/PDAL/PDAL/commit/9c3c69e409b2d83d60cd7ea4cb8730c41827016a
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2019-12-18 (Wed, 18 Dec 2019)
  Changed paths:
    M filters/ClusterFilter.cpp
    M filters/ClusterFilter.hpp
    M pdal/Dimension.json
  Log Message:
  Commit: dd77c95c5a070af74da45b111769a348fd5f1737
      https://github.com/PDAL/PDAL/commit/dd77c95c5a070af74da45b111769a348fd5f1737
  Date:   2020-01-24 (Fri, 24 Jan 2020)
  Changed paths:
    M CMakeLists.txt
    M cmake/gtest.cmake
    M doc/stages/filters.python.rst
    M doc/stages/readers.text.rst
    M doc/stages/writers.las.rst
    M examples/writing-reader/MyReader.cpp
    M filters/ELMFilter.cpp
    M filters/HAGFilter.cpp
    M filters/HexBinFilter.cpp
    M filters/OutlierFilter.cpp
    M filters/PMFFilter.cpp
    M filters/SMRFilter.cpp
    M filters/SkewnessBalancingFilter.cpp
    M filters/SkewnessBalancingFilter.hpp
    M filters/TransformationFilter.cpp
    M filters/private/delaunator.hpp
    M io/BpfCompressor.cpp
    M io/BpfReader.cpp
    M io/BpfReader.hpp
    M io/Ilvis2MetadataReader.cpp
    M io/LasWriter.cpp
    M io/OptechReader.cpp
    M io/PcdReader.cpp
    M io/PlyReader.cpp
    M io/TextReader.cpp
    M io/TextReader.hpp
    M kernels/TIndexKernel.cpp
    M pdal/GDALUtils.cpp
    M pdal/Geometry.cpp
    M pdal/Geometry.hpp
    M pdal/Polygon.cpp
    M pdal/Polygon.hpp
    M pdal/pdal_types.hpp
    M plugins/e57/CMakeLists.txt
    M plugins/e57/io/E57Reader.cpp
    M plugins/e57/io/E57Reader.hpp
    M plugins/e57/io/E57Writer.cpp
    M plugins/e57/io/E57Writer.hpp
    M plugins/e57/io/Scan.cpp
    M plugins/e57/io/Scan.hpp
    M plugins/e57/io/Utils.cpp
    M plugins/e57/io/Utils.hpp
    M plugins/e57/io/Uuid.cpp
    M plugins/e57/io/Uuid.hpp
    M plugins/e57/test/E57ReaderTest.cpp
    M plugins/e57/test/E57UtilsTest.cpp
    M plugins/e57/test/E57UuidTest.cpp
    M plugins/e57/test/E57WriterTest.cpp
    M plugins/e57/test/ScanTest.cpp
    M plugins/pgpointcloud/io/PgCommon.hpp
    M plugins/tiledb/io/TileDBReader.cpp
    M plugins/tiledb/io/TileDBReader.hpp
    M plugins/tiledb/io/TileDBWriter.cpp
    A test/data/e57/A_B_different_dims.e57
    A test/data/filters/elm1.txt
    A test/data/filters/elm2.txt
    A test/data/filters/transform-newlines.txt
    A test/data/filters/transform-oneline.txt
    A test/data/text/quoted.txt
    M test/unit/CMakeLists.txt
    M test/unit/PolygonTest.cpp
    M test/unit/apps/InfoTest.cpp
    M test/unit/filters/AssignFilterTest.cpp
    A test/unit/filters/ELMFilterTest.cpp
    M test/unit/filters/HAGFilterTest.cpp
    M test/unit/filters/OverlayFilterTest.cpp
    M test/unit/filters/SMRFilterTest.cpp
    A test/unit/filters/SkewnessFilterTest.cpp
    M test/unit/filters/TransformationFilterTest.cpp
    M test/unit/io/EptAddonWriterTest.cpp
    M test/unit/io/Ilvis2MetadataReaderTest.cpp
    M test/unit/io/TerrasolidReaderTest.cpp
    M test/unit/io/TextReaderTest.cpp
    M tools/nitfwrap/NitfWrap.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into issue-2852
  Commit: 36909081511dd8661dc181aeecc023de734416cd
      https://github.com/PDAL/PDAL/commit/36909081511dd8661dc181aeecc023de734416cd
  Changed paths:
  Log Message:
  Make sure cluster dimension gets registered.
Compare: https://github.com/PDAL/PDAL/compare/9c3c69e409b2%5E...36909081511d
More information about the pdal-commits mailing list
