[pdal-commits] [PDAL/PDAL] 613b6f: reset depthEnd in initialize() (#3140)
Andrew Bell noreply at github.com
Tue Jul 7 10:56:20 PDT 2020
  Branch: refs/heads/esri-obb
  Home:   https://github.com/PDAL/PDAL
  Commit: 613b6f7a0485f1ae01e781d1a0f716f30de953c5
      https://github.com/PDAL/PDAL/commit/613b6f7a0485f1ae01e781d1a0f716f30de953c5
  Author: Guilhem <guilhem.villemin at gmail.com>
  Date:   2020-06-20 (Sat, 20 Jun 2020)
  Changed paths:
    M io/EptReader.cpp
  Log Message:
  Commit: 80cbc5741a227a101e19ed9fa26bf79dcd330955
      https://github.com/PDAL/PDAL/commit/80cbc5741a227a101e19ed9fa26bf79dcd330955
  Author: Michael D. Smith <michael.smith at usace.army.mil>
  Date:   2020-06-22 (Mon, 22 Jun 2020)
  Changed paths:
    M scripts/docker/alpine/Dockerfile.2.0
    M scripts/docker/ubuntu/Dockerfile
  Log Message:
  Docker images missing certificates (#3141)
* add the certificates for https calls
* update alpine as well
  Commit: dba1484ea326c233b75bee38e1fffeb0738b8ccd
      https://github.com/PDAL/PDAL/commit/dba1484ea326c233b75bee38e1fffeb0738b8ccd
  Author: chambbj <brad.chambers at gmail.com>
  Changed paths:
    M filters/EigenvaluesFilter.cpp
    M filters/EigenvaluesFilter.hpp
  Log Message:
  Enhance eigenvalues filter with radius and stride options for defining neighborhood (#3132)
* Enhance eigenvalues filter with radius and stride options for defining
neighborhood
* addressing PR feedback
  Commit: ce597ec272decb0dc3a5bf399cebe593a843df57
      https://github.com/PDAL/PDAL/commit/ce597ec272decb0dc3a5bf399cebe593a843df57
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2020-06-23 (Tue, 23 Jun 2020)
  Changed paths:
    M test/unit/CMakeLists.txt
  Log Message:
  Makefile (#3144)
  Commit: c4ae95de84f2a6b12bc7c44e600c11092afc4b8b
      https://github.com/PDAL/PDAL/commit/c4ae95de84f2a6b12bc7c44e600c11092afc4b8b
  Date:   2020-06-24 (Wed, 24 Jun 2020)
  Changed paths:
    M io/TIndexReader.cpp
    M kernels/TIndexKernel.cpp
    M kernels/private/density/OGR.cpp
    M kernels/private/density/OGR.hpp
    M pdal/GDALUtils.cpp
    M pdal/GDALUtils.hpp
    A pdal/private/gdal/SpatialRef.cpp
    A pdal/private/gdal/SpatialRef.hpp
  Log Message:
  Move spatial ref to private. (#3145)
  Commit: 49dfc143215fd7bc30ed76b8c2329f9a2c4afe61
      https://github.com/PDAL/PDAL/commit/49dfc143215fd7bc30ed76b8c2329f9a2c4afe61
  Changed paths:
    A doc/stages/filters.litree.rst
    A filters/LiTreeFilter.cpp
    A filters/LiTreeFilter.hpp
  Log Message:
  Add LiTreeFilter to segment individual trees (#3111)
  Commit: 341fe1ba12abc771102edef168946a73b998edce
      https://github.com/PDAL/PDAL/commit/341fe1ba12abc771102edef168946a73b998edce
  Changed paths:
    M filters/SMRFilter.cpp
  Log Message:
  Report final number of ground/non-ground points (#3131)
* Report final number of ground/non-ground points
* addressing PR comments
  Commit: 2aa7c149cba19afd0560c36221b4d8b9970bab7c
      https://github.com/PDAL/PDAL/commit/2aa7c149cba19afd0560c36221b4d8b9970bab7c
  Changed paths:
    M pdal/util/FileUtils.cpp
    M pdal/util/FileUtils.hpp
    M plugins/hdf/io/Hdf5Handler.cpp
  Log Message:
  Add basic file mapping support. (#3148)
* Add basic file mapping support.
* std::min guard.
  Commit: 638f48feeec67abc8669f350f2cdc5eeb3cbb445
      https://github.com/PDAL/PDAL/commit/638f48feeec67abc8669f350f2cdc5eeb3cbb445
  Changed paths:
    M plugins/nitf/io/NitfWriter.cpp
  Log Message:
  Eliminate explicit ctor call.
  Commit: f902bc89c9d7c7f9e6f3982f289704b292570502
      https://github.com/PDAL/PDAL/commit/f902bc89c9d7c7f9e6f3982f289704b292570502
  Author: Rebecca Clarke <rclarke at linz.govt.nz>
  Date:   2020-06-25 (Thu, 25 Jun 2020)
  Changed paths:
    A doc/images/nz_formulas.png
    A doc/images/nz_lds_screenshot.png
    A doc/images/nz_lvd.png
    A doc/images/nz_relationships.png
    A doc/tutorial/grid-shift.rst
    A doc/tutorial/lvd_to_nzvd2016.py
    A doc/tutorial/nz_reproject.json
  Log Message:
  docs: add grid-shift tutorial (#3150)
  Commit: 9bc7105e15a952b742661e78b253dc6a0925af26
      https://github.com/PDAL/PDAL/commit/9bc7105e15a952b742661e78b253dc6a0925af26
  Author: Howard Butler <howard at hobu.co>
  Changed paths:
    M doc/stages/writers.las.rst
    M io/LasVLR.cpp
    A test/data/las/vlr-43.bin
    M test/unit/io/LasWriterTest.cpp
  Log Message:
  Support 'filename' to specify VLR content when adding VLRs using writers.las (#3149)
* Support filename key for data source of VLRs
* document and add test
* document 'filename' for VLR
* check VLR data values when adding via 'filename'
Co-authored-by: Andrew Bell <andrew.bell.ia at gmail.com>
  Commit: 0373375812be3918de0878cf5f7a59a367a39424
      https://github.com/PDAL/PDAL/commit/0373375812be3918de0878cf5f7a59a367a39424
  Date:   2020-06-26 (Fri, 26 Jun 2020)
  Changed paths:
    M doc/stages/filters.transformation.rst
    M filters/TransformationFilter.cpp
    M filters/TransformationFilter.hpp
    M test/unit/filters/TransformationFilterTest.cpp
  Log Message:
  Provide option to apply inverse transformation matrix (#3151)
* Add option to apply the inverse of the provided transformation
* Add a test to invert rotation
* formatting
* Update docs for invert option
* Use Eigen Affine3d instead
* Invert is NOT the default behavior
* Add inverse translation test
* whitespace normalization
  Commit: 95be31eb320f6af0eb4d605cbbe33e50fcdfc770
      https://github.com/PDAL/PDAL/commit/95be31eb320f6af0eb4d605cbbe33e50fcdfc770
  Changed paths:
    M apps/pdal.cpp
    M filters/ColorinterpFilter.cpp
    M filters/ColorizationFilter.cpp
    M filters/CropFilter.cpp
    M filters/DEMFilter.cpp
    M filters/HagDemFilter.cpp
    M filters/OverlayFilter.cpp
    M io/EptReader.cpp
    M io/GDALReader.cpp
    M io/GDALWriter.cpp
    M io/Ilvis2MetadataReader.cpp
    M io/OGRWriter.cpp
    M kernels/DensityKernel.cpp
    M pdal/EigenUtils.cpp
    R pdal/GDALUtils.cpp
    R pdal/GDALUtils.hpp
    M pdal/Geometry.cpp
    M pdal/Polygon.cpp
    M pdal/Stage.cpp
    A pdal/private/gdal/BaseBand.cpp
    A pdal/private/gdal/ErrorHandler.cpp
    A pdal/private/gdal/ErrorHandler.hpp
    A pdal/private/gdal/GDALError.hpp
    A pdal/private/gdal/GDALUtils.cpp
    A pdal/private/gdal/GDALUtils.hpp
    A pdal/private/gdal/Raster.cpp
    A pdal/private/gdal/Raster.hpp
    M test/unit/filters/CropFilterTest.cpp
    M test/unit/io/EptReaderTest.cpp
    M test/unit/io/GDALWriterTest.cpp
  Log Message:
  Gdal utils raster (#3153)
* Move Raster to private space.
* Split up GDALUtils and move to private.
* Missed header.
* BaseBand.
* Move GDALUtils to private.
* Remove unnecessary file.
* Remove dead code.
  Commit: 2fb2e74641a3b38e407be97df4215bf59f46e41a
      https://github.com/PDAL/PDAL/commit/2fb2e74641a3b38e407be97df4215bf59f46e41a
  Date:   2020-06-29 (Mon, 29 Jun 2020)
  Changed paths:
    M filters/ApproximateCoplanarFilter.cpp
    M filters/CSFilter.cpp
    M filters/CovarianceFeaturesFilter.cpp
    M filters/ELMFilter.cpp
    M filters/EstimateRankFilter.cpp
    M filters/IterativeClosestPoint.cpp
    M filters/MortonOrderFilter.cpp
    M filters/NormalFilter.cpp
    M filters/PMFFilter.cpp
    M filters/PlaneFitFilter.cpp
    M filters/VoxelCentroidNearestNeighborFilter.cpp
    M io/GDALWriter.cpp
    M io/PcdHeader.hpp
    R pdal/EigenUtils.cpp
    R pdal/EigenUtils.hpp
    M pdal/PointView.cpp
    A pdal/private/MathUtils.cpp
    A pdal/private/MathUtils.hpp
    M plugins/cpd/filters/CpdFilter.cpp
    M plugins/cpd/test/CpdFilterTest.cpp
    M plugins/oci/io/OciReader.cpp
    M plugins/oci/io/OciWriter.cpp
    M test/unit/EigenTest.cpp
    M test/unit/PointViewTest.cpp
    M test/unit/filters/ChipperTest.cpp
    M test/unit/filters/IcpFilterTest.cpp
    M test/unit/filters/SplitterTest.cpp
  Log Message:
  Mathutils (#3156)
* Move EigenUtils to private/MathUtils.
* Remove unused header.
* Fix plugins.
  Commit: c2e6bbf2085f6a1656c5b158201161ba13a2ec11
      https://github.com/PDAL/PDAL/commit/c2e6bbf2085f6a1656c5b158201161ba13a2ec11
  Date:   2020-07-01 (Wed, 01 Jul 2020)
  Changed paths:
    M vendor/arbiter/arbiter.cpp
  Log Message:
  Fix windows slash handling. (#3160)
  Commit: b07f3716a1d0fc7d7b792cce717e9220b5fad8d5
      https://github.com/PDAL/PDAL/commit/b07f3716a1d0fc7d7b792cce717e9220b5fad8d5
  Date:   2020-07-07 (Tue, 07 Jul 2020)
  Changed paths:
    M apps/pdal.cpp
    M io/EptReader.cpp
    M io/GDALReader.cpp
    M io/GDALWriter.cpp
    M io/LasVLR.cpp
    M io/OGRWriter.cpp
    M io/PcdHeader.hpp
    M pdal/Geometry.cpp
    M pdal/Polygon.cpp
    M pdal/Stage.cpp
    M plugins/i3s/io/EsriReader.cpp
    M plugins/i3s/io/Obb.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into esri-obb
Compare: https://github.com/PDAL/PDAL/compare/5c7506272b1d...b07f3716a1d0
More information about the pdal-commits mailing list
