[pdal-commits] [PDAL/PDAL] f6ed2d: Add "where" support for skipping points (#3177)
Andrew Bell noreply at github.com
Mon Jul 27 10:02:07 PDT 2020
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: f6ed2d3d1f1262edc0890084e61acd30d9ca3548
      https://github.com/PDAL/PDAL/commit/f6ed2d3d1f1262edc0890084e61acd30d9ca3548
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2020-07-27 (Mon, 27 Jul 2020)
  Changed paths:
    A filters/private/expr/Expression.cpp
    A filters/private/expr/Expression.hpp
    A filters/private/expr/Lexer.cpp
    A filters/private/expr/Lexer.hpp
    A filters/private/expr/Parser.cpp
    A filters/private/expr/Parser.hpp
    A filters/private/expr/Token.hpp
    M pdal/DimUtil.hpp
    A pdal/Filter.cpp
    M pdal/Filter.hpp
    M pdal/FlexWriter.hpp
    M pdal/Reader.cpp
    M pdal/Reader.hpp
    M pdal/Stage.cpp
    M pdal/Stage.hpp
    M pdal/Streamable.cpp
    M pdal/Writer.cpp
    M pdal/Writer.hpp
    A pdal/private/StageRunner.cpp
    M pdal/private/StageRunner.hpp
    M test/unit/CMakeLists.txt
    A test/unit/WhereTest.cpp
  Log Message:
* Initial commit with parser.
* Working parser.
* Move stuff around a bit.
* Hook up 'where' expression to filter argument.
* Prepare statements based on registered dimensions.
* Better separation of value/logical.
* Working where for standard mode.
* Streaming support for "where".
* Remove debug.
Accept stage names containing digits.
* Include header.
* Add header.
* What's up with Stage on windows?
* Remove dead code.
* Change "undefined" to be an explicitly deleted function.
* Add where-merge option.
* Add missed file.
* Move all skip processing to StageRunner.
Remove bad m_whereMerge from Filter.
* Add Where test.
* export operators on merge mode.
* Don't accept '/' in dimension names.
More information about the pdal-commits mailing list
