[pdal-commits] [PDAL/PDAL] 83cde6: use png for java badge
Andrew Bell noreply at github.com
Tue Mar 10 06:59:51 PDT 2020
  Branch: refs/heads/2.1-maintenance
  Home:   https://github.com/PDAL/PDAL
  Commit: 83cde606940ec726d5fb4d80a9ad485f36e6f43d
      https://github.com/PDAL/PDAL/commit/83cde606940ec726d5fb4d80a9ad485f36e6f43d
  Author: Howard Butler <howard at hobu.co>
  Date:   2020-03-10 (Tue, 10 Mar 2020)
  Changed paths:
    M doc/java.rst
  Log Message:
  Commit: 8cee231854fe5e2d3da89465cb39cedfc8534a4b
      https://github.com/PDAL/PDAL/commit/8cee231854fe5e2d3da89465cb39cedfc8534a4b
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Changed paths:
    M scripts/azp/linux.yml
    M scripts/docker/ubuntu/Dockerfile
    A scripts/docker/ubuntu/Dockerfile.dependencies
    R scripts/docker/ubuntu/dependencies/Dockerfile
  Log Message:
  Update docker/CI to support tiledb and use conda base (#2964)
* Updates to support building TileDb
* Destdir for tiledb.
* Add xerces.
* Working dockerfile and dependencies
* We're using conda.
* Force build.
* Force build.
* More conda cruft.
* New CI
* Force build.
* Working Dockerfile.
* Move grid shift files to dependencies.
  Commit: ae1046491c54fe0f6365903e97259d0506ae13dc
      https://github.com/PDAL/PDAL/commit/ae1046491c54fe0f6365903e97259d0506ae13dc
  Changed paths:
    M vendor/arbiter/arbiter.cpp
    M vendor/arbiter/arbiter.hpp
  Log Message:
  Fix S3 usage with KMS-managed server-side encryption enabled. (#2965)
Co-authored-by: Connor Manning <connor at hobu.co>
Compare: https://github.com/PDAL/PDAL/compare/5c2f883e09e4...ae1046491c54
More information about the pdal-commits mailing list
