[pdal-commits] [PDAL/PDAL] ec26a6: doc updates
Andrew Bell noreply at github.com
Tue Mar 10 13:29:34 PDT 2020
  Branch: refs/heads/wkt1
  Home:   https://github.com/PDAL/PDAL
  Commit: ec26a6788976247f0ad916cd6898a888bab8bc74
      https://github.com/PDAL/PDAL/commit/ec26a6788976247f0ad916cd6898a888bab8bc74
  Author: Howard Butler <howard at hobu.co>
  Date:   2020-02-21 (Fri, 21 Feb 2020)
  Changed paths:
    M doc/stages/readers.hdf.rst
  Log Message:
  doc updates
  Commit: 44c7d910b45fa494586bef63719e0f73958bcdb4
      https://github.com/PDAL/PDAL/commit/44c7d910b45fa494586bef63719e0f73958bcdb4
  Author: Norman Barker <norman at tiledb.io>
  Changed paths:
    M doc/stages/writers.tiledb.rst
    M plugins/tiledb/io/TileDBWriter.cpp
    M plugins/tiledb/test/TileDBWriterTest.cpp
  Log Message:
  tiledb: add defaults for attribute filters (#2903)
* tiledb: add defaults for attribute filters
* default options for attributes
  Commit: 6ec91b837a9fca59683f979539ff6c47333475e0
      https://github.com/PDAL/PDAL/commit/6ec91b837a9fca59683f979539ff6c47333475e0
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2020-02-24 (Mon, 24 Feb 2020)
  Changed paths:
    M filters/HeadFilter.hpp
    M filters/RandomizeFilter.hpp
    M filters/SkewnessBalancingFilter.cpp
    M filters/SortFilter.cpp
    M filters/SortFilter.hpp
    M filters/TailFilter.hpp
    M pdal/PointContainer.hpp
    M pdal/PointRef.hpp
    M pdal/PointView.cpp
    M pdal/PointView.hpp
    R pdal/PointViewIter.hpp
    M test/unit/PointViewTest.cpp
    M test/unit/filters/SortFilterTest.cpp
    M test/unit/filters/VoxelDownsizeFilterTest.cpp
    M test/unit/io/EptReaderTest.cpp
  Log Message:
  Support range-based for loops on PointView with PointRef as reference type (#2944)
* Working checkpoint.
* Update.
* Working update.
* Real tests for voxel downsize.
* Remove unused code.
* Fix windows build issues.
* Use unsigned for type in test comparison.
* Use better compare function.
  Commit: eefca8c092daa2d76cf38f4864e1ae48a7d3e726
      https://github.com/PDAL/PDAL/commit/eefca8c092daa2d76cf38f4864e1ae48a7d3e726
  Date:   2020-02-25 (Tue, 25 Feb 2020)
  Changed paths:
    M kernels/InfoKernel.cpp
  Log Message:
  Make file_size conditional in info call (#2947)
  Commit: 5be7c48b3501a6092aef70fc35ee9d75f11a61f4
      https://github.com/PDAL/PDAL/commit/5be7c48b3501a6092aef70fc35ee9d75f11a61f4
  Date:   2020-02-27 (Thu, 27 Feb 2020)
  Changed paths:
    M plugins/tiledb/CMakeLists.txt
    M plugins/tiledb/io/TileDBReader.cpp
    M plugins/tiledb/io/TileDBWriter.hpp
    M plugins/tiledb/test/TileDBReaderTest.cpp
    M test/data/tiledb/array/pdal.json
  Log Message:
  tiledb: use internal array metadata for pipeline serialization (#2838)
* tiledb: use internal array metadata for pipeline serialization
* tiledb: added srs support
* removed unused sidecar reference in reader test
* fixed tests for PR
* include stage metadata
* added json prop check if metadata is an empty array
* fix bug with m_arrayName and TileDB lt 1.7
* tiledb: Fix irrelevant comment
* enable tiledb tests
  Commit: 36fd7fc37c21888ea04ff2895c4a6973bfe6656b
      https://github.com/PDAL/PDAL/commit/36fd7fc37c21888ea04ff2895c4a6973bfe6656b
  Author: Jules Robichaud-Gagnon <j.robichaudg at gmail.com>
  Date:   2020-02-29 (Sat, 29 Feb 2020)
  Changed paths:
    M doc/stages/filters.python.rst
  Log Message:
  Document filters.python feature to use equal for type (#2948)
https://github.com/PDAL/python/blob/80eea96fada65f734ed4dd26a08681d1c2d5c415/pdal/filters/PythonFilter.cpp#L97-L114
  Commit: c15d2416096b25a283c97700b6ccc20c256bb340
      https://github.com/PDAL/PDAL/commit/c15d2416096b25a283c97700b6ccc20c256bb340
  Author: Even Rouault <even.rouault at spatialys.com>
  Changed paths:
    M io/TextReader.cpp
  Log Message:
  TextReader::initialize(): fix memleak if parseHeader() throws exception (#2952)
  Commit: 806489c5a8faaf8e9e959911af24163327ce2d96
      https://github.com/PDAL/PDAL/commit/806489c5a8faaf8e9e959911af24163327ce2d96
  Date:   2020-03-01 (Sun, 01 Mar 2020)
  Changed paths:
    M io/LasVLR.cpp
  Log Message:
  io/LasVLR.cpp: fix '[...] casts away qualifiers' warning (#2951)
  Commit: 962709071d66b2c7eda9ecacdae264810564e58d
      https://github.com/PDAL/PDAL/commit/962709071d66b2c7eda9ecacdae264810564e58d
  Date:   2020-03-02 (Mon, 02 Mar 2020)
  Changed paths:
    M cmake/gtest.cmake
    M vendor/gtest/CMakeLists.txt
    M vendor/gtest/README.md
    M vendor/gtest/cmake/gtest.pc.in
    M vendor/gtest/cmake/gtest_main.pc.in
    M vendor/gtest/cmake/internal_utils.cmake
    M vendor/gtest/docs/Pkgconfig.md
    M vendor/gtest/docs/advanced.md
    M vendor/gtest/docs/faq.md
    M vendor/gtest/docs/primer.md
    M vendor/gtest/docs/samples.md
    M vendor/gtest/include/gtest/gtest-death-test.h
    A vendor/gtest/include/gtest/gtest-matchers.h
    M vendor/gtest/include/gtest/gtest-message.h
    M vendor/gtest/include/gtest/gtest-param-test.h
    M vendor/gtest/include/gtest/gtest-printers.h
    M vendor/gtest/include/gtest/gtest-spi.h
    M vendor/gtest/include/gtest/gtest-test-part.h
    M vendor/gtest/include/gtest/gtest-typed-test.h
    M vendor/gtest/include/gtest/gtest.h
    M vendor/gtest/include/gtest/gtest_pred_impl.h
    M vendor/gtest/include/gtest/internal/gtest-death-test-internal.h
    M vendor/gtest/include/gtest/internal/gtest-filepath.h
    M vendor/gtest/include/gtest/internal/gtest-internal.h
    M vendor/gtest/include/gtest/internal/gtest-param-util.h
    M vendor/gtest/include/gtest/internal/gtest-port-arch.h
    M vendor/gtest/include/gtest/internal/gtest-port.h
    M vendor/gtest/include/gtest/internal/gtest-string.h
    M vendor/gtest/include/gtest/internal/gtest-type-util.h
    M vendor/gtest/include/gtest/internal/gtest-type-util.h.pump
    M vendor/gtest/samples/prime_tables.h
    M vendor/gtest/samples/sample1.cc
    M vendor/gtest/samples/sample1.h
    M vendor/gtest/samples/sample10_unittest.cc
    M vendor/gtest/samples/sample2.cc
    M vendor/gtest/samples/sample2.h
    M vendor/gtest/samples/sample2_unittest.cc
    M vendor/gtest/samples/sample3-inl.h
    M vendor/gtest/samples/sample3_unittest.cc
    M vendor/gtest/samples/sample5_unittest.cc
    M vendor/gtest/samples/sample6_unittest.cc
    M vendor/gtest/samples/sample7_unittest.cc
    M vendor/gtest/samples/sample8_unittest.cc
    M vendor/gtest/samples/sample9_unittest.cc
    M vendor/gtest/src/gtest-all.cc
    M vendor/gtest/src/gtest-death-test.cc
    M vendor/gtest/src/gtest-filepath.cc
    M vendor/gtest/src/gtest-internal-inl.h
    A vendor/gtest/src/gtest-matchers.cc
    M vendor/gtest/src/gtest-port.cc
    M vendor/gtest/src/gtest-printers.cc
    M vendor/gtest/src/gtest-test-part.cc
    M vendor/gtest/src/gtest-typed-test.cc
    M vendor/gtest/src/gtest.cc
    M vendor/gtest/src/gtest_main.cc
    M vendor/gtest/test/BUILD.bazel
    M vendor/gtest/test/googletest-catch-exceptions-test.py
    M vendor/gtest/test/googletest-catch-exceptions-test_.cc
    M vendor/gtest/test/googletest-death-test-test.cc
    M vendor/gtest/test/googletest-death-test_ex_test.cc
    M vendor/gtest/test/googletest-env-var-test.py
    M vendor/gtest/test/googletest-filepath-test.cc
    M vendor/gtest/test/googletest-filter-unittest.py
    M vendor/gtest/test/googletest-filter-unittest_.cc
    M vendor/gtest/test/googletest-json-outfiles-test.py
    M vendor/gtest/test/googletest-json-output-unittest.py
    M vendor/gtest/test/googletest-list-tests-unittest_.cc
    M vendor/gtest/test/googletest-listener-test.cc
    M vendor/gtest/test/googletest-message-test.cc
    M vendor/gtest/test/googletest-options-test.cc
    M vendor/gtest/test/googletest-output-test-golden-lin.txt
    M vendor/gtest/test/googletest-output-test.py
    M vendor/gtest/test/googletest-output-test_.cc
    M vendor/gtest/test/googletest-param-test-invalid-name1-test_.cc
    M vendor/gtest/test/googletest-param-test-invalid-name2-test_.cc
    M vendor/gtest/test/googletest-param-test-test.cc
    M vendor/gtest/test/googletest-param-test-test.h
    M vendor/gtest/test/googletest-param-test2-test.cc
    M vendor/gtest/test/googletest-port-test.cc
    M vendor/gtest/test/googletest-printers-test.cc
    M vendor/gtest/test/googletest-shuffle-test_.cc
    M vendor/gtest/test/googletest-test-part-test.cc
    M vendor/gtest/test/googletest-test2_test.cc
    M vendor/gtest/test/googletest-throw-on-failure-test.py
    M vendor/gtest/test/googletest-throw-on-failure-test_.cc
    M vendor/gtest/test/googletest-uninitialized-test.py
    M vendor/gtest/test/gtest-typed-test2_test.cc
    M vendor/gtest/test/gtest-typed-test_test.cc
    M vendor/gtest/test/gtest-typed-test_test.h
    M vendor/gtest/test/gtest-unittest-api_test.cc
    M vendor/gtest/test/gtest_all_test.cc
    M vendor/gtest/test/gtest_assert_by_exception_test.cc
    M vendor/gtest/test/gtest_environment_test.cc
    M vendor/gtest/test/gtest_pred_impl_unittest.cc
    M vendor/gtest/test/gtest_premature_exit_test.cc
    M vendor/gtest/test/gtest_repeat_test.cc
    A vendor/gtest/test/gtest_skip_environment_check_output_test.py
    A vendor/gtest/test/gtest_skip_in_environment_setup_test.cc
    A vendor/gtest/test/gtest_skip_test.cc
    M vendor/gtest/test/gtest_stress_test.cc
    M vendor/gtest/test/gtest_test_utils.py
    M vendor/gtest/test/gtest_throw_on_failure_ex_test.cc
    M vendor/gtest/test/gtest_unittest.cc
    M vendor/gtest/test/gtest_xml_outfile1_test_.cc
    M vendor/gtest/test/gtest_xml_outfile2_test_.cc
    M vendor/gtest/test/gtest_xml_outfiles_test.py
    M vendor/gtest/test/gtest_xml_output_unittest.py
    M vendor/gtest/test/gtest_xml_output_unittest_.cc
    M vendor/gtest/test/gtest_xml_test_utils.py
  Log Message:
  Update vendored GoogleTest to 1.10.0 (#2946)
* update to gtest 1.10.0
* update gtest cmake
  Commit: 04caecbed8969fac3a5e5237e4e377c12647a840
      https://github.com/PDAL/PDAL/commit/04caecbed8969fac3a5e5237e4e377c12647a840
  Author: chambbj <brad.chambers at gmail.com>
  Changed paths:
    M doc/stages/filters.normal.rst
    M filters/NormalFilter.cpp
    M filters/NormalFilter.hpp
    M test/unit/CMakeLists.txt
    A test/unit/filters/NormalFilterTest.cpp
  Log Message:
  Add normal refinement via minimum spanning tree propagation (#2860)
* Add normal refinement via minimum spanning tree propagation
* Documentation updates for NormalFilter
* Cite both CloudCompare and the Hoppe paper that introduced the method
* List the new option in the NormalFilter documentation
* Add simple tests for NormalFilter
True planes in each of XY, XZ, and YZ
* Add inclined plane test
* Responding to PR comments
* More PR comment rework
* Use PointView iterator after rebasing with master
  Commit: 7ba37c2da1599a75e0d059b888e7f74690075ad2
      https://github.com/PDAL/PDAL/commit/7ba37c2da1599a75e0d059b888e7f74690075ad2
  Author: Grigory <gr.pomadchin at gmail.com>
  Date:   2020-03-04 (Wed, 04 Mar 2020)
  Changed paths:
    M doc/index.rst
    A doc/java.rst
  Log Message:
  Add PDAL JNI docs (#2954)
  Commit: b089eb2ce98ba4f8f34a6d52713b9c54eb246839
      https://github.com/PDAL/PDAL/commit/b089eb2ce98ba4f8f34a6d52713b9c54eb246839
  Date:   2020-03-05 (Thu, 05 Mar 2020)
  Changed paths:
    M io/EptReader.cpp
    M io/EptReader.hpp
    M vendor/arbiter/arbiter.cpp
    M vendor/arbiter/arbiter.hpp
  Log Message:
  Update arbiter bundle for removal of homedir logging, copyable endpoints, and simpler namespacing. (#2958)
  Commit: 6090ac8e82d7a9946af82003f85e9d85633104d2
      https://github.com/PDAL/PDAL/commit/6090ac8e82d7a9946af82003f85e9d85633104d2
  Changed paths:
    M io/LasWriter.cpp
  Log Message:
  Fix setting of SRS when we're not using LAZperf for LASzip.
  Commit: a5db1530f38600610f7bd06fb14f1294a89ec3e7
      https://github.com/PDAL/PDAL/commit/a5db1530f38600610f7bd06fb14f1294a89ec3e7
  Changed paths:
    M plugins/e57/io/E57Reader.cpp
  Log Message:
  Fix type change.
  Commit: 3acec652827bec5af17da02a1a89422696554146
      https://github.com/PDAL/PDAL/commit/3acec652827bec5af17da02a1a89422696554146
  Date:   2020-03-09 (Mon, 09 Mar 2020)
  Changed paths:
    M doc/java.rst
  Log Message:
  use png for java badge
  Commit: a78e98ff3ebba6d69d40edccdc4c10069228c499
      https://github.com/PDAL/PDAL/commit/a78e98ff3ebba6d69d40edccdc4c10069228c499
  Changed paths:
    M scripts/azp/linux.yml
    M scripts/docker/ubuntu/Dockerfile
    A scripts/docker/ubuntu/Dockerfile.dependencies
    R scripts/docker/ubuntu/dependencies/Dockerfile
  Log Message:
  Update docker/CI to support tiledb and use conda base (#2964)
* Updates to support building TileDb
* Destdir for tiledb.
* Add xerces.
* Working dockerfile and dependencies
* We're using conda.
* Force build.
* Force build.
* More conda cruft.
* New CI
* Force build.
* Working Dockerfile.
* Move grid shift files to dependencies.
  Commit: c05e76962beca2385b0390a28d7a5f880069857c
      https://github.com/PDAL/PDAL/commit/c05e76962beca2385b0390a28d7a5f880069857c
  Changed paths:
  Log Message:
  Fix S3 usage with KMS-managed server-side encryption enabled. (#2965)
Co-authored-by: Connor Manning <connor at hobu.co>
  Commit: 3c720fb853f29679239c23d9cf9b0e27e0be2ad3
      https://github.com/PDAL/PDAL/commit/3c720fb853f29679239c23d9cf9b0e27e0be2ad3
  Date:   2020-03-10 (Tue, 10 Mar 2020)
  Changed paths:
    M pdal/PointTable.hpp
  Log Message:
  Allow zero results from TileDB query (#2967)
  Commit: b8390e48825ad9fc8fd3738438a032a8220d79e5
      https://github.com/PDAL/PDAL/commit/b8390e48825ad9fc8fd3738438a032a8220d79e5
  Changed paths:
    M doc/stages/writers.gltf.rst
    M io/GltfWriter.cpp
  Log Message:
  Update documentation for .glb extension. (#2969)
  Commit: 93701afe7be2418911463335b7807afe699fbe80
      https://github.com/PDAL/PDAL/commit/93701afe7be2418911463335b7807afe699fbe80
  Changed paths:
    M cmake/gtest.cmake
    M doc/index.rst
    A doc/java.rst
    M io/EptReader.cpp
    M io/EptReader.hpp
    M io/GltfWriter.cpp
    M io/LasVLR.cpp
    M io/LasWriter.cpp
    M io/TextReader.cpp
    M pdal/PointRef.hpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into wkt1
Compare: https://github.com/PDAL/PDAL/compare/4df43a6ca398...93701afe7be2
More information about the pdal-commits mailing list
