[pdal-commits] [PDAL/PDAL] 212b9c: Make test base64 data valid (#2973)
Andrew Bell noreply at github.com
Wed Mar 11 15:08:47 PDT 2020
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 212b9c915c2511c2af90c9533e2821d502730ebc
      https://github.com/PDAL/PDAL/commit/212b9c915c2511c2af90c9533e2821d502730ebc
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2020-03-11 (Wed, 11 Mar 2020)
  Changed paths:
    M test/data/pipeline/issue2937.json.in
  Log Message:
* Make user VLR handling robust.
* Cleanup.
* Remove dead header.
* Make things with with Ext VLRs.
* Add more test.
* One more test.
* Remove unnecessary cast.
* Add a real test for the original problem.
* Cleaner logic.
* Make valid base64-encoded value.
* Remove merge conflict.
* Missed a character.
More information about the pdal-commits mailing list
