[pdal-commits] [PDAL/PDAL] bafded: Howard windows updates (#2953)
Andrew Bell
noreply at github.com
Fri Mar 13 04:33:03 PDT 2020
Branch: refs/heads/2.1-maintenance
Home: https://github.com/PDAL/PDAL
Commit: bafded2c87f93e68f3be7e1cf46e4119985921e4
https://github.com/PDAL/PDAL/commit/bafded2c87f93e68f3be7e1cf46e4119985921e4
Author: Howard Butler <howard at hobu.co>
Date: 2020-03-13 (Fri, 13 Mar 2020)
Changed paths:
M filters/StatsFilter.hpp
M plugins/e57/libE57Format/CMakeLists.txt
M plugins/icebridge/io/Hdf5Handler.hpp
M scripts/conda/win64.bat
Log Message:
* update my win conda config
* we need <stdexcept>
* cast away some silly warnings
* ignore conversion warnings in e57 library on windows
* condition e57 ignoration
Commit: 6ed4ce0430aefc2e222d86acd6d5798fbe3d3f8f
https://github.com/PDAL/PDAL/commit/6ed4ce0430aefc2e222d86acd6d5798fbe3d3f8f
Author: Andrew Bell <andrew.bell.ia at gmail.com>
Changed paths:
M test/data/pipeline/issue2937.json.in
Log Message:
Make test base64 data valid (#2973)
* Make user VLR handling robust.
* Cleanup.
* Remove dead header.
* Make things with with Ext VLRs.
* Add more test.
* One more test.
* Remove unnecessary cast.
* Add a real test for the original problem.
* Cleaner logic.
* Make valid base64-encoded value.
* Remove merge conflict.
* Missed a character.
Commit: 6da8d2bf91909f8550a24b433c17c6705da15b96
https://github.com/PDAL/PDAL/commit/6da8d2bf91909f8550a24b433c17c6705da15b96
Changed paths:
M pdal/SpatialReference.cpp
Log Message:
Fix capitalization (#2971)
* ensure WKTv1 writing for LAS 1.4
* adjust as suggested
* Simplify logic.
* Throw an exception is we can't convert an SRS to WKT1.
* Move comment.
* Correct capitalization.
Co-authored-by: Howard Butler <howard at hobu.co>
Commit: e132a25e8db8840cae6827c273cfc5f8a60fd344
https://github.com/PDAL/PDAL/commit/e132a25e8db8840cae6827c273cfc5f8a60fd344
Changed paths:
M doc/stages/filters.hag.rst
A doc/stages/filters.hag_delaunay.rst
A doc/stages/filters.hag_dem.rst
A doc/stages/filters.hag_nn.rst
M doc/stages/filters.rst
M doc/stages/images/autzen-elevation.png
A doc/stages/images/autzen-hag-delaunay.png
A doc/stages/images/autzen-hag-dem.png
A doc/stages/images/autzen-hag-nn.png
M filters/DEMFilter.cpp
A filters/HagDelaunayFilter.cpp
A filters/HagDelaunayFilter.hpp
A filters/HagDemFilter.cpp
A filters/HagDemFilter.hpp
A filters/HagNnFilter.cpp
A filters/HagNnFilter.hpp
M test/unit/filters/HAGFilterTest.cpp
Log Message:
Split HAG filter into three (#2927)
* Updates.
* Add filters.hag_dem
* make filters.hag_dem streamable, improve docs
* update copyright info
* Make raster a positional argument in HAGDEMFilter
* Break HAG into pieces.
* Fix validation error message for invalid band parameter
* Formatting changes. Remove "static" in processOne()..
* Review changes.
* Update documentation with new graphics and proper refs
* Add back HAG filter for now.
* Fix spelling.
Co-authored-by: Julian Fell <hi at jtfell.com>
Co-authored-by: Bradley J Chambers <brad.chambers at gmail.com>
Commit: 5d3a0343e305d2b1c14233ac19988c8ebf4eb247
https://github.com/PDAL/PDAL/commit/5d3a0343e305d2b1c14233ac19988c8ebf4eb247
Changed paths:
M doc/stages/writers.ply.rst
M io/PlyWriter.hpp
Log Message:
Remove support for the "default" option in writers.ply. (#2977)
Commit: 030d72e9d124e9efbcf2948ad0f32a5e2e02dbc2
https://github.com/PDAL/PDAL/commit/030d72e9d124e9efbcf2948ad0f32a5e2e02dbc2
Changed paths:
M io/LasVLR.cpp
M pdal/util/Utils.cpp
M test/unit/UtilsTest.cpp
Log Message:
Fix potential inf. loop (#2979)
* Cleanup.
* Add more test.
* One more test.
* Cleaner logic.
* Fix potential inf. loop in parsing VLR.
Trap error in bad base64 decoding.
Compare: https://github.com/PDAL/PDAL/compare/2c5435bd8bf2...030d72e9d124
More information about the pdal-commits
