[pdal-commits] [PDAL/PDAL] a5796b: filters.icp: output centroid to metadata (#2962)
Jules Robichaud-Gagnon noreply at github.com
Tue Mar 17 08:44:48 PDT 2020
  Branch: refs/heads/2.1-maintenance
  Home:   https://github.com/PDAL/PDAL
  Commit: a5796bc16e0c96bca195d978cb19ed69fe461aed
      https://github.com/PDAL/PDAL/commit/a5796bc16e0c96bca195d978cb19ed69fe461aed
  Author: Jim Klassen <klassen.js at gmail.com>
  Date:   2020-03-17 (Tue, 17 Mar 2020)
  Changed paths:
    M doc/stages/filters.icp.rst
    M filters/IterativeClosestPoint.cpp
  Log Message:
This is needed to apply the same transformation to a different set
of points using filters.transform. (#2939)
  Commit: 0012aa7cfd3809db82235158dbb6717389e1e41a
      https://github.com/PDAL/PDAL/commit/0012aa7cfd3809db82235158dbb6717389e1e41a
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Changed paths:
    M kernels/TileKernel.cpp
  Log Message:
  Call setSpatialReference() on the table when we switch stages. (#2980)
  Commit: 88acdb7ae6cf0ad16465b8744f910878b4bf9b8f
      https://github.com/PDAL/PDAL/commit/88acdb7ae6cf0ad16465b8744f910878b4bf9b8f
  Changed paths:
    M CMakeLists.txt
  Log Message:
  Add interface includes for PDAL library target. (#2981)
* Specify interface includes for downstream PDAL projects.
* Fix include directory.
* Update library target.
* Add pdal_util, just in case.
  Commit: b494c82e02847464f5a28d25f73ea9f97e94ba01
      https://github.com/PDAL/PDAL/commit/b494c82e02847464f5a28d25f73ea9f97e94ba01
  Author: Jules Robichaud-Gagnon <j.robichaudg at gmail.com>
  Changed paths:
    M doc/stages/writers.text.rst
  Log Message:
  Add useful missing undocumented parameter for writers.text (#2983)
https://github.com/PDAL/PDAL/blob/c4cc229023b5f0ef742893f7bc73b6de43b7da66/io/TextWriter.cpp#L106
Compare: https://github.com/PDAL/PDAL/compare/030d72e9d124...b494c82e0284
More information about the pdal-commits mailing list
