[pdal-commits] [PDAL/PDAL] f0acbe: Use signed int for clustering/grouping
chambbj noreply at github.com
Thu May 21 06:03:52 PDT 2020
  Branch: refs/heads/issue-3079
  Home:   https://github.com/PDAL/PDAL
  Commit: f0acbe531b24953e0757cf056fda50fe8ce96470
      https://github.com/PDAL/PDAL/commit/f0acbe531b24953e0757cf056fda50fe8ce96470
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Date:   2020-05-21 (Thu, 21 May 2020)
  Changed paths:
    M filters/DBSCANFilter.cpp
    M filters/DBSCANFilter.hpp
    M filters/GroupByFilter.cpp
    M pdal/Dimension.json
  Log Message:
Modify DBSCAN to use the standard ClusterID dimension, which is now
defined as int64. The Groupby filter is similarly instructed to evaluate
int64. This allows clustering algorithms like DBSCAN to use -1 to
indicate noise.
More information about the pdal-commits mailing list
