[pdal-commits] [PDAL/PDAL] 6a8296: Ignore points indicated by classbit, do not toss t...
Andrew Bell noreply at github.com
Tue May 26 06:47:40 PDT 2020
  Branch: refs/heads/2.1-maintenance
  Home:   https://github.com/PDAL/PDAL
  Commit: 6a82968bb7e8dd401b3b13895a0348aed557f61d
      https://github.com/PDAL/PDAL/commit/6a82968bb7e8dd401b3b13895a0348aed557f61d
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2020-05-26 (Tue, 26 May 2020)
  Changed paths:
    M doc/stages/filters.smrf.rst
    M filters/SMRFilter.cpp
  Log Message:
  Ignore points indicated by classbit, do not toss them. Add (#3055)
documentation.
  Commit: d4c031d05c325499b29cb195cdc48957cb07158b
      https://github.com/PDAL/PDAL/commit/d4c031d05c325499b29cb195cdc48957cb07158b
  Author: zerotohero <zerotohero at users.noreply.github.com>
  Changed paths:
    M doc/tutorial/iowa-entwine.rst
  Log Message:
  Quick grammatical update (#3063)
Might as well keep it as professional as possible.
  Commit: 0e9dc4a2ed527ba6d7b24093a16f4ae822a880cd
      https://github.com/PDAL/PDAL/commit/0e9dc4a2ed527ba6d7b24093a16f4ae822a880cd
  Author: jedfrechette <jedfrechette at gmail.com>
  Changed paths:
    M doc/stages/readers.pcd.rst
    M doc/stages/writers.pcd.rst
  Log Message:
  PCD doc fix (#3065)
* Fix format link in reader.pcd docs
* Fix format link in writer.pcd docs
  Commit: 9e00fde7d544c33b5a6707530ce01592ee5065a0
      https://github.com/PDAL/PDAL/commit/9e00fde7d544c33b5a6707530ce01592ee5065a0
  Changed paths:
  Log Message:
  Fix row/column calculation. (#3070)
Close #3069
  Commit: ea30f6b6d9cfb1f275e162a87580414d2799eb57
      https://github.com/PDAL/PDAL/commit/ea30f6b6d9cfb1f275e162a87580414d2799eb57
  Changed paths:
    M filters/SMRFilter.hpp
  Log Message:
  Use neighbors() instead of knnSearch() to get only valid neighbors. (#3072)
* Use neighbors() instead of knnSearch() to get only valid neighbors.
Compute filled vector in place.
* Merge fix.
  Commit: 569410dc53fda31c36a619bf0f46d2c7c8deb6af
      https://github.com/PDAL/PDAL/commit/569410dc53fda31c36a619bf0f46d2c7c8deb6af
  Changed paths:
    M filters/private/delaunator.cpp
  Log Message:
  Don't store distances in the comparator. (#3080)
* Don't store distances in the comparator.
* Remove header.
  Commit: 14ee30c28ac680f6d2b7c1b0f48718a839988a28
      https://github.com/PDAL/PDAL/commit/14ee30c28ac680f6d2b7c1b0f48718a839988a28
  Changed paths:
    M CMakeLists.txt
    M HOWTORELEASE.txt
  Log Message:
  Implement SOVERSION naming rules and document behavior  (#3096)
* Perhaps foolproof lib numbering.
* Update release instructions
Co-authored-by: Andrew Bell <andrew.bell.ia at gmail.com>
  Commit: 06e00f66bcfeeb67d1575b1c911f200a1c7d8c0f
      https://github.com/PDAL/PDAL/commit/06e00f66bcfeeb67d1575b1c911f200a1c7d8c0f
  Changed paths:
    M io/LasReader.cpp
    M test/unit/io/LasReaderTest.cpp
  Log Message:
  Don't add ClassFlags/ScanChannel unless we're processing pointformat 6-10. (#3095)
Compare: https://github.com/PDAL/PDAL/compare/d8d8547fed2b...06e00f66bcfe
More information about the pdal-commits mailing list
