[pdal-commits] [PDAL/PDAL] 5e22e7: default to using the file's SRS info, not the tile...
Howard Butler noreply at github.com
Tue May 26 18:15:24 PDT 2020
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: 5e22e7b6121990489f25e66592a3d6ca220e6f14
      https://github.com/PDAL/PDAL/commit/5e22e7b6121990489f25e66592a3d6ca220e6f14
  Author: Howard Butler <howard at hobu.co>
  Date:   2020-05-26 (Tue, 26 May 2020)
  Changed paths:
    M io/TIndexReader.cpp
  Log Message:
  default to using the file's SRS info, not the tile index column, unless the user overrides with the explicit 'srs_column' option (#3102)
* default to using the file's SRS info, not the tile index column, unless the user overrides with the explicit 'srs_column' option
* compilation fixes
More information about the pdal-commits mailing list
