[pdal-commits] [PDAL/PDAL] cf2d03: Rework EPT reader and addons to properly handle bo...
Andrew Bell noreply at github.com
Thu May 28 06:16:45 PDT 2020
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: cf2d031796910497173a54a31bc9400089c33448
      https://github.com/PDAL/PDAL/commit/cf2d031796910497173a54a31bc9400089c33448
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2020-05-28 (Thu, 28 May 2020)
  Changed paths:
    M cmake/gtest.cmake
    M io/EptAddonWriter.cpp
    M io/EptAddonWriter.hpp
    M io/EptReader.cpp
    M io/EptReader.hpp
    R io/private/EptSupport.cpp
    R io/private/EptSupport.hpp
    A io/private/ept/Addon.cpp
    A io/private/ept/Addon.hpp
    A io/private/ept/Connector.cpp
    A io/private/ept/Connector.hpp
    A io/private/ept/EptArtifact.hpp
    A io/private/ept/EptInfo.cpp
    A io/private/ept/EptInfo.hpp
    A io/private/ept/EptSupport.hpp
    A io/private/ept/FixedPointLayout.cpp
    A io/private/ept/FixedPointLayout.hpp
    A io/private/ept/Key.hpp
    A io/private/ept/Overlap.hpp
    A io/private/ept/Pool.cpp
    A io/private/ept/Pool.hpp
    A io/private/ept/TileContents.cpp
    A io/private/ept/TileContents.hpp
    A io/private/ept/VectorPointTable.hpp
    M pdal/PointTable.hpp
    M pdal/PointView.cpp
    M pdal/StageFactory.cpp
    M pdal/Writer.cpp
    M pdal/Writer.hpp
    M test/unit/io/EptAddonWriterTest.cpp
    M test/unit/io/EptReaderTest.cpp
    M vendor/arbiter/arbiter.cpp
    M vendor/arbiter/arbiter.hpp
  Log Message:
  Rework EPT reader and addons to properly handle bounds (#3064)
* EPT update.
* Fix pointId number.
* Stop reading tasks if we've read enough points.
* Temporary check-in.
* Working-ish add-on writer.
* Working reader/writer.
* Add header.
* Add missed func.
* Fix poly intersection.
* Remove debug from nanoflann.
* Const iterator usage.
* Don't redeclare variable.
* Change name of dimension ID variables to hopefully improve clarity.
* Don't use view for table access when we're not inserting and we KNOW that
we can scan all points in order.
* Remove ept:// as protocol.
Add test.
* Remove dead code.
* Remove more dead code.
* Updates based on review. (#3106)
There are still private headers in EptReader.
* Simplify assignment of headers/query a bit.
More information about the pdal-commits mailing list
