[pdal-commits] [PDAL/PDAL] b10bf2: Update package script.
Howard Butler noreply at github.com
Mon Oct 5 09:14:42 PDT 2020
  Branch: refs/heads/filters/relaxation-dart-throwing
  Home:   https://github.com/PDAL/PDAL
  Commit: b10bf2a102d972c00dac71ddf0d5d06cd6131070
      https://github.com/PDAL/PDAL/commit/b10bf2a102d972c00dac71ddf0d5d06cd6131070
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2020-08-24 (Mon, 24 Aug 2020)
  Changed paths:
    M package.sh
  Log Message:
  Commit: 0f811fde59042093e7aae4b7456fdf83f2d3c018
      https://github.com/PDAL/PDAL/commit/0f811fde59042093e7aae4b7456fdf83f2d3c018
  Changed paths:
    M filters/FaceRasterFilter.cpp
    M filters/FaceRasterFilter.hpp
    M io/EptAddonWriter.hpp
    M io/EptReader.cpp
    M io/EptReader.hpp
    M kernels/GroundKernel.cpp
    M kernels/GroundKernel.hpp
    M pdal/PointView.cpp
    M pdal/PointView.hpp
    M test/unit/filters/FaceRasterTest.cpp
  Log Message:
  Remove private headers from .hpp files.
  Commit: 797f5946193538e966141cf74427c219d31f15c0
      https://github.com/PDAL/PDAL/commit/797f5946193538e966141cf74427c219d31f15c0
  Date:   2020-08-25 (Tue, 25 Aug 2020)
  Changed paths:
    M filters/IterativeClosestPoint.cpp
    M vendor/arbiter/arbiter.cpp
  Log Message:
  Fixes for clang 10.
  Commit: 293c7d3968ab42bd98b629cf8d9cf9261da7ea56
      https://github.com/PDAL/PDAL/commit/293c7d3968ab42bd98b629cf8d9cf9261da7ea56
  Author: trevorskaggs <skaggs.trevor at gmail.com>
  Date:   2020-08-26 (Wed, 26 Aug 2020)
  Changed paths:
    M doc/stages/readers.rst
  Log Message:
  Add HDF reader stage to readers page. (#3219)
  Commit: 36a848813d547c0244804ee2271edc7909407866
      https://github.com/PDAL/PDAL/commit/36a848813d547c0244804ee2271edc7909407866
  Author: Ryan Pals <ryan at hobu.co>
  Date:   2020-08-27 (Thu, 27 Aug 2020)
  Changed paths:
    M io/ObjReader.cpp
    M io/ObjReader.hpp
    M pdal/Dimension.json
    A test/data/obj/box_texture.obj
    A test/data/obj/hyper_box.obj
    M test/unit/io/ObjReaderTest.cpp
  Log Message:
  Obj texture fix -- simplified. (#3222)
* Texture 2 element fix
* Allow for 0-3 fields in texture and 3-4 fields in vertex position
* Rename texture dimensions, add W
* Allow all dimensions
* Allow more than 4 fields in vertex specification
* Remove unused
* Copy over tests
* Add W dimension
* Check vertex length
  Commit: 2e2247cac25b605919922ffc3298c1a3154c645d
      https://github.com/PDAL/PDAL/commit/2e2247cac25b605919922ffc3298c1a3154c645d
  Changed paths:
    M kernels/TranslateKernel.cpp
    M pdal/Scaling.cpp
    M vendor/eigen/Eigen/Core
    M vendor/eigen/Eigen/Geometry
    M vendor/eigen/Eigen/src/Core/AssignEvaluator.h
    M vendor/eigen/Eigen/src/Core/products/GeneralMatrixVector.h
    M vendor/kazhdan/Allocator.h
  Log Message:
  Fixes for clang10. (#3221)
  Commit: 1c110d9814d04939c50aaf23e247e491d7f8721f
      https://github.com/PDAL/PDAL/commit/1c110d9814d04939c50aaf23e247e491d7f8721f
  Date:   2020-08-28 (Fri, 28 Aug 2020)
  Changed paths:
    M .travis.yml
  Log Message:
  Change doc release branch.
  Commit: a7b10a72798668a51cfd7f18fc1f612fa041f0a4
      https://github.com/PDAL/PDAL/commit/a7b10a72798668a51cfd7f18fc1f612fa041f0a4
  Changed paths:
    M io/ObjReader.cpp
    M io/ObjReader.hpp
    M pdal/Scaling.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master'
  Commit: cbbb898fdf04a63df890104dee25993aadc94b44
      https://github.com/PDAL/PDAL/commit/cbbb898fdf04a63df890104dee25993aadc94b44
  Author: Bas Couwenberg <sebastic at xs4all.nl>
  Changed paths:
    M filters/private/expr/ConditionalExpression.cpp
    M filters/private/expr/Expression.cpp
    M filters/private/miniball/Seb_debug.h
    M io/private/ept/Addon.cpp
    M vendor/gtest/src/gtest-death-test.cc
    M vendor/pdalboost/boost/date_time/dst_rules.hpp
    M vendor/pdalboost/boost/detail/utf8_codecvt_facet.hpp
    M vendor/pdalboost/boost/iostreams/detail/optional.hpp
    M vendor/pdalboost/boost/type_index.hpp
  Log Message:
  Fix spelling errors. (#3223)
* assigment      -> assignment
 * evalutes       -> evaluates
 * lenght         -> length
 * retun          -> return
 * specificiation -> specification
  Commit: b0c4f8d07ba151237919b73d8b624b6f0d72b6ad
      https://github.com/PDAL/PDAL/commit/b0c4f8d07ba151237919b73d8b624b6f0d72b6ad
  Author: Pierre Abbat <phma at bezitopo.org>
  Date:   2020-08-30 (Sun, 30 Aug 2020)
  Changed paths:
    A test/data/las/garbage_nVariableLength.las
  Log Message:
  Add test file garbage_nVariableLength.las
This file has a floating-point number in nVariableLength, which should
be the integer 0, since there are no variable-length records. It's a
test file to find out why a program I'm writing, which reads a point cloud
and builds an octree, loses points. The code to write LAS files wasn't
working right yet. I read this file into CloudCompare, which allocated
all RAM and was killed; I reported the bug to CloudCompare, but was told
that the bug is in PDAL.
  Commit: 66c8d133f7fadd5b66ec28dc61e2c22496ca3359
      https://github.com/PDAL/PDAL/commit/66c8d133f7fadd5b66ec28dc61e2c22496ca3359
  Date:   2020-09-01 (Tue, 01 Sep 2020)
  Changed paths:
    M doc/stages/expression.rst
    M doc/stages/filter_opts.rst
  Log Message:
  Doc updates for "where" (#3229)
* Add "where" option support to documentation.
* More examples.
* Filter where documentation updates.
  Commit: ca907d4a304d808941ef85770d4d6d50299d6716
      https://github.com/PDAL/PDAL/commit/ca907d4a304d808941ef85770d4d6d50299d6716
  Author: David Bitner <bitner at dbspatial.com>
  Changed paths:
    M io/TextWriter.cpp
    A test/data/text/utm17_1.geojson
    M test/unit/io/TextWriterTest.cpp
  Log Message:
  Fix for #3204, Issues with Commas in writers.text GeoJSON output. (#3227)
* fix for commas in geojson output
* Add Tests
  Commit: 8bcc6f69df88b09eb9b5706a195212121e79bc77
      https://github.com/PDAL/PDAL/commit/8bcc6f69df88b09eb9b5706a195212121e79bc77
  Changed paths:
    M doc/stages/stages.rst
    A doc/stages/writers.raster.rst
    M doc/stages/writers.rst
    M io/GDALWriter.cpp
    M io/GDALWriter.hpp
    A io/RasterWriter.cpp
    A io/RasterWriter.hpp
    M io/private/GDALGrid.cpp
    M io/private/GDALGrid.hpp
    M pdal/private/Raster.hpp
    M plugins/oci/io/OciReader.cpp
    M test/unit/io/GDALWriterTest.cpp
  Log Message:
  RasterWriter (#3230)
* FaceRasterFilter.
* Have GDALWriter use Raster.
* Updates to face raster tests.
* Documentation and such.
* Add RasterWriter.
* Remove dead test.
* Doc updates.
  Commit: e5a58f804a3a9e485bc1a7fdfb49cd1070875338
      https://github.com/PDAL/PDAL/commit/e5a58f804a3a9e485bc1a7fdfb49cd1070875338
  Changed paths:
    M io/GDALWriter.cpp
    M io/GDALWriter.hpp
    M io/TextWriter.cpp
  Log Message:
  Commit: 556e128d0434591eb546099cb7d3578f52c457e3
      https://github.com/PDAL/PDAL/commit/556e128d0434591eb546099cb7d3578f52c457e3
  Changed paths:
    M doc/stages/readers.oci.rst
    M doc/stages/writers.oci.rst
  Log Message:
  Deprecate OCI support.
  Commit: b1953968ad01486c613941fe152d127e1500b291
      https://github.com/PDAL/PDAL/commit/b1953968ad01486c613941fe152d127e1500b291
  Changed paths:
    M RELEASENOTES.txt
    A doc/development/release-notes/2.2.0.md
  Log Message:
  Update release notes.
  Commit: 4cea4f09918bef12ae3869f21f715cf8f006e92f
      https://github.com/PDAL/PDAL/commit/4cea4f09918bef12ae3869f21f715cf8f006e92f
  Date:   2020-09-03 (Thu, 03 Sep 2020)
  Changed paths:
    M plugins/tiledb/io/TileDBReader.cpp
    M plugins/tiledb/io/TileDBWriter.cpp
    M plugins/tiledb/io/TileDBWriter.hpp
    M plugins/tiledb/test/TileDBReaderTest.cpp
  Log Message:
  TileDB 2.0 (#3030)
  Commit: 93fc55a4ef4e09481af56937aaf3cc87ece4c049
      https://github.com/PDAL/PDAL/commit/93fc55a4ef4e09481af56937aaf3cc87ece4c049
  Changed paths:
    R test/data/tiledb/array/__20c2cf6f2bf546adbc7fe83cb44f180b_1554218258459/OffsetTime.tdb
    R test/data/tiledb/array/__20c2cf6f2bf546adbc7fe83cb44f180b_1554218258459/__coords.tdb
    R test/data/tiledb/array/__20c2cf6f2bf546adbc7fe83cb44f180b_1554218258459/__fragment_metadata.tdb
    R test/data/tiledb/array/__array_schema.tdb
    R test/data/tiledb/array/__lock.tdb
    R test/data/tiledb/array/pdal.json
  Log Message:
  TileDB stats and read split buffers (#3045)
* refactor tiledb stats to include opening
* Use split coordinates on read
  Commit: 1b7fc36e48db5ec5cbf23b7efd88c64ff9519dd7
      https://github.com/PDAL/PDAL/commit/1b7fc36e48db5ec5cbf23b7efd88c64ff9519dd7
  Changed paths:
    M plugins/tiledb/test/TileDBWriterTest.cpp
  Log Message:
  tiledb: support duplicate coordinate values (#3047)
  Commit: 13d68ef1d7ff61ba5b9192c0f09298f029ea3c46
      https://github.com/PDAL/PDAL/commit/13d68ef1d7ff61ba5b9192c0f09298f029ea3c46
  Date:   2020-09-04 (Fri, 04 Sep 2020)
  Changed paths:
    M RELEASENOTES.txt
    M doc/development/release-notes/2.2.0.md
  Log Message:
  Commit: 24a8e9e160c218001ec79654904d1509a1447610
      https://github.com/PDAL/PDAL/commit/24a8e9e160c218001ec79654904d1509a1447610
  Author: chambbj <brad.chambers at gmail.com>
  Date:   2020-09-10 (Thu, 10 Sep 2020)
  Changed paths:
    R vendor/eigen/Eigen/Array
    M vendor/eigen/Eigen/Cholesky
    R vendor/eigen/Eigen/Eigen2Support
    M vendor/eigen/Eigen/Eigenvalues
    M vendor/eigen/Eigen/LU
    R vendor/eigen/Eigen/LeastSquares
    M vendor/eigen/Eigen/PardisoSupport
    M vendor/eigen/Eigen/QR
    M vendor/eigen/Eigen/QtAlignedMalloc
    M vendor/eigen/Eigen/SVD
    R vendor/eigen/Eigen/src/CMakeLists.txt
    R vendor/eigen/Eigen/src/Cholesky/CMakeLists.txt
    M vendor/eigen/Eigen/src/Cholesky/LDLT.h
    M vendor/eigen/Eigen/src/Cholesky/LLT.h
    R vendor/eigen/Eigen/src/Cholesky/LLT_MKL.h
    R vendor/eigen/Eigen/src/CholmodSupport/CMakeLists.txt
    M vendor/eigen/Eigen/src/Core/Array.h
    M vendor/eigen/Eigen/src/Core/ArrayWrapper.h
    M vendor/eigen/Eigen/src/Core/Assign_MKL.h
    M vendor/eigen/Eigen/src/Core/Block.h
    R vendor/eigen/Eigen/src/Core/CMakeLists.txt
    M vendor/eigen/Eigen/src/Core/ConditionEstimator.h
    M vendor/eigen/Eigen/src/Core/CoreEvaluators.h
    M vendor/eigen/Eigen/src/Core/Diagonal.h
    M vendor/eigen/Eigen/src/Core/Dot.h
    R vendor/eigen/Eigen/src/Core/Flagged.h
    R vendor/eigen/Eigen/src/Core/Functors.h
    M vendor/eigen/Eigen/src/Core/GeneralProduct.h
    M vendor/eigen/Eigen/src/Core/Map.h
    M vendor/eigen/Eigen/src/Core/MapBase.h
    M vendor/eigen/Eigen/src/Core/MathFunctions.h
    M vendor/eigen/Eigen/src/Core/MathFunctionsImpl.h
    M vendor/eigen/Eigen/src/Core/Matrix.h
    M vendor/eigen/Eigen/src/Core/MatrixBase.h
    M vendor/eigen/Eigen/src/Core/PlainObjectBase.h
    M vendor/eigen/Eigen/src/Core/Product.h
    R vendor/eigen/Eigen/src/Core/ProductBase.h
    M vendor/eigen/Eigen/src/Core/ProductEvaluators.h
    M vendor/eigen/Eigen/src/Core/Redux.h
    M vendor/eigen/Eigen/src/Core/Ref.h
    M vendor/eigen/Eigen/src/Core/SelfAdjointView.h
    M vendor/eigen/Eigen/src/Core/SelfCwiseBinaryOp.h
    M vendor/eigen/Eigen/src/Core/SolveTriangular.h
    M vendor/eigen/Eigen/src/Core/StableNorm.h
    M vendor/eigen/Eigen/src/Core/Transpose.h
    M vendor/eigen/Eigen/src/Core/Transpositions.h
    M vendor/eigen/Eigen/src/Core/TriangularMatrix.h
    M vendor/eigen/Eigen/src/Core/arch/AVX/Complex.h
    M vendor/eigen/Eigen/src/Core/arch/AVX/PacketMath.h
    M vendor/eigen/Eigen/src/Core/arch/AVX512/MathFunctions.h
    M vendor/eigen/Eigen/src/Core/arch/AVX512/PacketMath.h
    R vendor/eigen/Eigen/src/Core/arch/AltiVec/CMakeLists.txt
    M vendor/eigen/Eigen/src/Core/arch/AltiVec/Complex.h
    M vendor/eigen/Eigen/src/Core/arch/AltiVec/PacketMath.h
    R vendor/eigen/Eigen/src/Core/arch/CMakeLists.txt
    M vendor/eigen/Eigen/src/Core/arch/CUDA/Half.h
    M vendor/eigen/Eigen/src/Core/arch/CUDA/PacketMathHalf.h
    R vendor/eigen/Eigen/src/Core/arch/Default/CMakeLists.txt
    A vendor/eigen/Eigen/src/Core/arch/Default/ConjHelper.h
    R vendor/eigen/Eigen/src/Core/arch/NEON/CMakeLists.txt
    M vendor/eigen/Eigen/src/Core/arch/NEON/Complex.h
    M vendor/eigen/Eigen/src/Core/arch/NEON/PacketMath.h
    R vendor/eigen/Eigen/src/Core/arch/SSE/CMakeLists.txt
    M vendor/eigen/Eigen/src/Core/arch/SSE/Complex.h
    M vendor/eigen/Eigen/src/Core/arch/SSE/PacketMath.h
    M vendor/eigen/Eigen/src/Core/arch/SSE/TypeCasting.h
    M vendor/eigen/Eigen/src/Core/arch/ZVector/Complex.h
    M vendor/eigen/Eigen/src/Core/functors/BinaryFunctors.h
    M vendor/eigen/Eigen/src/Core/functors/StlFunctors.h
    R vendor/eigen/Eigen/src/Core/products/CMakeLists.txt
    R vendor/eigen/Eigen/src/Core/products/CoeffBasedProduct.h
    M vendor/eigen/Eigen/src/Core/products/GeneralBlockPanelKernel.h
    M vendor/eigen/Eigen/src/Core/products/GeneralMatrixMatrixTriangular_BLAS.h
    R vendor/eigen/Eigen/src/Core/products/GeneralMatrixMatrixTriangular_MKL.h
    M vendor/eigen/Eigen/src/Core/products/GeneralMatrixMatrix_BLAS.h
    R vendor/eigen/Eigen/src/Core/products/GeneralMatrixMatrix_MKL.h
    M vendor/eigen/Eigen/src/Core/products/GeneralMatrixVector_BLAS.h
    R vendor/eigen/Eigen/src/Core/products/GeneralMatrixVector_MKL.h
    M vendor/eigen/Eigen/src/Core/products/SelfadjointMatrixMatrix_BLAS.h
    R vendor/eigen/Eigen/src/Core/products/SelfadjointMatrixMatrix_MKL.h
    M vendor/eigen/Eigen/src/Core/products/SelfadjointMatrixVector_BLAS.h
    R vendor/eigen/Eigen/src/Core/products/SelfadjointMatrixVector_MKL.h
    M vendor/eigen/Eigen/src/Core/products/TriangularMatrixMatrix.h
    M vendor/eigen/Eigen/src/Core/products/TriangularMatrixMatrix_BLAS.h
    R vendor/eigen/Eigen/src/Core/products/TriangularMatrixMatrix_MKL.h
    M vendor/eigen/Eigen/src/Core/products/TriangularMatrixVector.h
    M vendor/eigen/Eigen/src/Core/products/TriangularMatrixVector_BLAS.h
    R vendor/eigen/Eigen/src/Core/products/TriangularMatrixVector_MKL.h
    M vendor/eigen/Eigen/src/Core/products/TriangularSolverMatrix_BLAS.h
    R vendor/eigen/Eigen/src/Core/products/TriangularSolverMatrix_MKL.h
    M vendor/eigen/Eigen/src/Core/util/BlasUtil.h
    R vendor/eigen/Eigen/src/Core/util/CMakeLists.txt
    M vendor/eigen/Eigen/src/Core/util/DisableStupidWarnings.h
    M vendor/eigen/Eigen/src/Core/util/MKL_support.h
    M vendor/eigen/Eigen/src/Core/util/Macros.h
    M vendor/eigen/Eigen/src/Core/util/Memory.h
    M vendor/eigen/Eigen/src/Core/util/Meta.h
    M vendor/eigen/Eigen/src/Core/util/ReenableStupidWarnings.h
    M vendor/eigen/Eigen/src/Core/util/StaticAssert.h
    M vendor/eigen/Eigen/src/Core/util/XprHelper.h
    R vendor/eigen/Eigen/src/Eigen2Support/Block.h
    R vendor/eigen/Eigen/src/Eigen2Support/CMakeLists.txt
    R vendor/eigen/Eigen/src/Eigen2Support/Cwise.h
    R vendor/eigen/Eigen/src/Eigen2Support/CwiseOperators.h
    R vendor/eigen/Eigen/src/Eigen2Support/Geometry/AlignedBox.h
    R vendor/eigen/Eigen/src/Eigen2Support/Geometry/All.h
    R vendor/eigen/Eigen/src/Eigen2Support/Geometry/AngleAxis.h
    R vendor/eigen/Eigen/src/Eigen2Support/Geometry/CMakeLists.txt
    R vendor/eigen/Eigen/src/Eigen2Support/Geometry/Hyperplane.h
    R vendor/eigen/Eigen/src/Eigen2Support/Geometry/ParametrizedLine.h
    R vendor/eigen/Eigen/src/Eigen2Support/Geometry/Quaternion.h
    R vendor/eigen/Eigen/src/Eigen2Support/Geometry/Rotation2D.h
    R vendor/eigen/Eigen/src/Eigen2Support/Geometry/RotationBase.h
    R vendor/eigen/Eigen/src/Eigen2Support/Geometry/Scaling.h
    R vendor/eigen/Eigen/src/Eigen2Support/Geometry/Transform.h
    R vendor/eigen/Eigen/src/Eigen2Support/Geometry/Translation.h
    R vendor/eigen/Eigen/src/Eigen2Support/LU.h
    R vendor/eigen/Eigen/src/Eigen2Support/Lazy.h
    R vendor/eigen/Eigen/src/Eigen2Support/LeastSquares.h
    R vendor/eigen/Eigen/src/Eigen2Support/Macros.h
    R vendor/eigen/Eigen/src/Eigen2Support/MathFunctions.h
    R vendor/eigen/Eigen/src/Eigen2Support/Memory.h
    R vendor/eigen/Eigen/src/Eigen2Support/Meta.h
    R vendor/eigen/Eigen/src/Eigen2Support/Minor.h
    R vendor/eigen/Eigen/src/Eigen2Support/QR.h
    R vendor/eigen/Eigen/src/Eigen2Support/SVD.h
    R vendor/eigen/Eigen/src/Eigen2Support/TriangularSolver.h
    R vendor/eigen/Eigen/src/Eigen2Support/VectorBlock.h
    R vendor/eigen/Eigen/src/Eigenvalues/CMakeLists.txt
    R vendor/eigen/Eigen/src/Eigenvalues/ComplexSchur_MKL.h
    M vendor/eigen/Eigen/src/Eigenvalues/GeneralizedEigenSolver.h
    M vendor/eigen/Eigen/src/Eigenvalues/MatrixBaseEigenvalues.h
    M vendor/eigen/Eigen/src/Eigenvalues/RealSchur.h
    R vendor/eigen/Eigen/src/Eigenvalues/RealSchur_MKL.h
    M vendor/eigen/Eigen/src/Eigenvalues/SelfAdjointEigenSolver_LAPACKE.h
    R vendor/eigen/Eigen/src/Eigenvalues/SelfAdjointEigenSolver_MKL.h
    M vendor/eigen/Eigen/src/Geometry/AngleAxis.h
    R vendor/eigen/Eigen/src/Geometry/CMakeLists.txt
    M vendor/eigen/Eigen/src/Geometry/Quaternion.h
    M vendor/eigen/Eigen/src/Geometry/Scaling.h
    R vendor/eigen/Eigen/src/Geometry/arch/CMakeLists.txt
    R vendor/eigen/Eigen/src/Householder/CMakeLists.txt
    M vendor/eigen/Eigen/src/IterativeLinearSolvers/BasicPreconditioners.h
    R vendor/eigen/Eigen/src/IterativeLinearSolvers/CMakeLists.txt
    M vendor/eigen/Eigen/src/IterativeLinearSolvers/ConjugateGradient.h
    R vendor/eigen/Eigen/src/Jacobi/CMakeLists.txt
    M vendor/eigen/Eigen/src/Jacobi/Jacobi.h
    R vendor/eigen/Eigen/src/LU/CMakeLists.txt
    R vendor/eigen/Eigen/src/LU/Inverse.h
    M vendor/eigen/Eigen/src/LU/InverseImpl.h
    R vendor/eigen/Eigen/src/LU/PartialPivLU_MKL.h
    R vendor/eigen/Eigen/src/LU/arch/CMakeLists.txt
    M vendor/eigen/Eigen/src/LU/arch/Inverse_SSE.h
    R vendor/eigen/Eigen/src/MetisSupport/CMakeLists.txt
    A vendor/eigen/Eigen/src/OrderingMethods/Amd.h
    R vendor/eigen/Eigen/src/OrderingMethods/CMakeLists.txt
    R vendor/eigen/Eigen/src/PaStiXSupport/CMakeLists.txt
    M vendor/eigen/Eigen/src/PaStiXSupport/PaStiXSupport.h
    R vendor/eigen/Eigen/src/PardisoSupport/CMakeLists.txt
    R vendor/eigen/Eigen/src/QR/CMakeLists.txt
    R vendor/eigen/Eigen/src/QR/ColPivHouseholderQR_MKL.h
    R vendor/eigen/Eigen/src/QR/HouseholderQR_MKL.h
    R vendor/eigen/Eigen/src/SPQRSupport/CMakeLists.txt
    M vendor/eigen/Eigen/src/SVD/BDCSVD.h
    R vendor/eigen/Eigen/src/SVD/CMakeLists.txt
    M vendor/eigen/Eigen/src/SVD/JacobiSVD_LAPACKE.h
    R vendor/eigen/Eigen/src/SVD/JacobiSVD_MKL.h
    M vendor/eigen/Eigen/src/SVD/SVDBase.h
    R vendor/eigen/Eigen/src/SparseCholesky/CMakeLists.txt
    A vendor/eigen/Eigen/src/SparseCholesky/SimplicialCholesky.h
    A vendor/eigen/Eigen/src/SparseCholesky/SimplicialCholesky_impl.h
    M vendor/eigen/Eigen/src/SparseCore/AmbiVector.h
    R vendor/eigen/Eigen/src/SparseCore/CMakeLists.txt
    M vendor/eigen/Eigen/src/SparseCore/ConservativeSparseSparseProduct.h
    M vendor/eigen/Eigen/src/SparseCore/SparseMatrix.h
    M vendor/eigen/Eigen/src/SparseCore/SparseSelfAdjointView.h
    M vendor/eigen/Eigen/src/SparseCore/SparseSparseProductWithPruning.h
    R vendor/eigen/Eigen/src/SparseLU/CMakeLists.txt
    M vendor/eigen/Eigen/src/SparseLU/SparseLU.h
    R vendor/eigen/Eigen/src/SparseQR/CMakeLists.txt
    M vendor/eigen/Eigen/src/SparseQR/SparseQR.h
    R vendor/eigen/Eigen/src/StlSupport/CMakeLists.txt
    R vendor/eigen/Eigen/src/SuperLUSupport/CMakeLists.txt
    M vendor/eigen/Eigen/src/SuperLUSupport/SuperLUSupport.h
    R vendor/eigen/Eigen/src/UmfPackSupport/CMakeLists.txt
    R vendor/eigen/Eigen/src/misc/CMakeLists.txt
    R vendor/eigen/Eigen/src/misc/Solve.h
    R vendor/eigen/Eigen/src/misc/SparseSolve.h
    R vendor/eigen/Eigen/src/plugins/CMakeLists.txt
  Log Message:
  Bump eigen to 3.3.7 (#3206)
Co-authored-by: Andrew Bell <andrew.bell.ia at gmail.com>
  Commit: 34f8161eee7fbd50a1eef20180a9fd0d5beff8c2
      https://github.com/PDAL/PDAL/commit/34f8161eee7fbd50a1eef20180a9fd0d5beff8c2
  Changed paths:
    R vendor/eigen/Eigen/src/IterativeLinearSolvers/IncompleteLUT.h
    R vendor/eigen/Eigen/src/SparseCholesky/SimplicialCholesky_impl.h
  Log Message:
  Remove LGPL code.
Correct a cast.
  Commit: 4b156f14b6120e270105b42fe7d29969ab01b976
      https://github.com/PDAL/PDAL/commit/4b156f14b6120e270105b42fe7d29969ab01b976
  Changed paths:
    R doc/presentations/location_tech_8_30_12/css/main.css
    R doc/presentations/location_tech_8_30_12/css/print/paper.css
    R doc/presentations/location_tech_8_30_12/css/print/pdf.css
    R doc/presentations/location_tech_8_30_12/css/theme/beige.css
    R doc/presentations/location_tech_8_30_12/css/theme/default.css
    R doc/presentations/location_tech_8_30_12/css/theme/simple.css
    R doc/presentations/location_tech_8_30_12/images/Untitled.png
    R doc/presentations/location_tech_8_30_12/images/autzen-lasview.png
    R doc/presentations/location_tech_8_30_12/images/basic-pipeline.png
    R doc/presentations/location_tech_8_30_12/images/complex-pipeline.png
    R doc/presentations/location_tech_8_30_12/images/nero1.jpg
    R doc/presentations/location_tech_8_30_12/images/reader-writer.png
    R doc/presentations/location_tech_8_30_12/index.html
    R doc/presentations/location_tech_8_30_12/js/reveal.js
    R doc/presentations/location_tech_8_30_12/js/reveal.min.js
    R doc/presentations/location_tech_8_30_12/lib/css/zenburn.css
    R doc/presentations/location_tech_8_30_12/lib/font/league_gothic-webfont.eot
    R doc/presentations/location_tech_8_30_12/lib/font/league_gothic-webfont.svg
    R doc/presentations/location_tech_8_30_12/lib/font/league_gothic-webfont.ttf
    R doc/presentations/location_tech_8_30_12/lib/font/league_gothic-webfont.woff
    R doc/presentations/location_tech_8_30_12/lib/font/league_gothic_license
    R doc/presentations/location_tech_8_30_12/lib/js/classList.js
    R doc/presentations/location_tech_8_30_12/lib/js/data-markdown.js
    R doc/presentations/location_tech_8_30_12/lib/js/head.min.js
    R doc/presentations/location_tech_8_30_12/lib/js/highlight.js
    R doc/presentations/location_tech_8_30_12/lib/js/html5shiv.js
    R doc/presentations/location_tech_8_30_12/lib/js/showdown.js
  Log Message:
  Remove presentations (dated and showdown.js as security risk).
  Commit: 4a9a92922ab1bd8b7ff55fc2ec59f20838bf0f81
      https://github.com/PDAL/PDAL/commit/4a9a92922ab1bd8b7ff55fc2ec59f20838bf0f81
  Date:   2020-09-15 (Tue, 15 Sep 2020)
  Changed paths:
    M pdal/Geometry.cpp
  Log Message:
  Clone the geometry being assigned. (#3236)
  Commit: f1a29294482fec963f68142cb9fbb5cfecd4a7fa
      https://github.com/PDAL/PDAL/commit/f1a29294482fec963f68142cb9fbb5cfecd4a7fa
  Changed paths:
    M README.md
  Log Message:
  Update Zenodo badge for 2.2 release
  Commit: 3755bd3fe9a8f6b773e783ccbd6e8041b380e0eb
      https://github.com/PDAL/PDAL/commit/3755bd3fe9a8f6b773e783ccbd6e8041b380e0eb
  Author: Howard Butler <howard at hobu.co>
  Date:   2020-09-17 (Thu, 17 Sep 2020)
  Changed paths:
    A .github/workflows/conda.yml
    M .github/workflows/docs.yml
    A .github/workflows/linux.yml
    A .github/workflows/osx.yml
    A .github/workflows/win.yml
    R .travis.yml
    M HOWTORELEASE.txt
    M README.md
    R azure-pipelines.yml
    M doc/project/docs.rst
    M doc/project/integration.rst
    M plugins/hdf/io/HdfReader.cpp
    R scripts/appveyor/conda/build.cmd
    R scripts/appveyor/conda/recipe/bld.bat
    R scripts/appveyor/conda/recipe/build.sh
    R scripts/appveyor/conda/recipe/meta.yaml
    R scripts/appveyor/conda/recipe/scripts/activate.bat
    R scripts/appveyor/conda/recipe/scripts/activate.sh
    R scripts/appveyor/conda/recipe/scripts/deactivate.bat
    R scripts/appveyor/conda/recipe/scripts/deactivate.sh
    R scripts/appveyor/config.cmd
    R scripts/appveyor/test/build.cmd
    R scripts/appveyor/test/test.cmd
    R scripts/azp/doc.yml
    R scripts/azp/linux-conda.yml
    R scripts/azp/linux.yml
    R scripts/azp/osx.yml
    R scripts/azp/win.yml
    R scripts/ci/add_deploy_key.sh
    R scripts/ci/after_success.sh
    R scripts/ci/build_docs.sh
    A scripts/ci/conda/compile.sh
    A scripts/ci/conda/examples.sh
    A scripts/ci/conda/setup.sh
    R scripts/ci/deploy_website.sh
    A scripts/ci/docs/deploy_website.sh
    A scripts/ci/linux/cmake.sh
    A scripts/ci/linux/compile.sh
    A scripts/ci/linux/examples.sh
    A scripts/ci/linux/setup.sh
    A scripts/ci/linux/test.sh
    A scripts/ci/osx/cmake.sh
    A scripts/ci/osx/compile.sh
    A scripts/ci/osx/examples.sh
    A scripts/ci/osx/setup.sh
    A scripts/ci/osx/test.sh
    R scripts/ci/pdaldocs-private.key.enc
    R scripts/ci/script.sh
    A scripts/ci/win/cmake.sh
    A scripts/ci/win/compile.sh
    A scripts/ci/win/examples.sh
    A scripts/ci/win/setup.sh
    A scripts/ci/win/test.sh
    R scripts/osgeo4w/config.cmd
  Log Message:
  Migrate from Azure Pipelines to Github Actions (#3192)
* Github Action for Linux/Conda build
* conda linux build
* syntax
* no CPD
* actually test
* add osx builder
* add windows build
* use cmd instead of bash
* syntax
* print cd
* build dir
* conda shell for win
* lint
* explicit activation
* call conda
* try using bash instead of cmd
* directory
* shell subs
* remove cmd continuations
* lint
* more lint
* line continuations
* quoting
* fetch explicit string for datasetName in readers.hdf
* CMAKE_BUILD_TYPE
* put each step into its own script
* directory paths
* source
* doc pushing
* doc deploy script
* trigger build
* syntax
* checkout into root dir
* doc push churn
* clone above root
* git directory name
* git checkout for docs
* documentation build/push
* executable bit for doc deploy_website
* deploy conditional
* syntax
* small layout tweaks
* doc deploy path
* split linux and osx workflows
* gdal-config lint
* remove conda strict
* typo'd install path
* update fixed conda config
* quit failing at logic
* install into CONDA_PREFIX for linux
* cleanups
* docs
* no md
* don't build svgs for latex
* remove AzP reference
* add win examples
* fixed/float build matrix for OSX and Windows
* correct path to win examples
* no gdal-config on win
* turn off abseil on win/osx
* export cl.exe
* remove conda-build usage
* start adding conda feedstock build/test loop
* clobber
* wipe sha256 and url params
* use https url for feedstock build fetch
* conda install
* dont build twice
* typo
* need ninja and compilers to do things
* artifact upload
* use local packages directory for install
* permute runs-on
* set CXX and CC variables for windows
* bump build number to 2112 so it doesn't clash
* use correct env var
* need msvc enabled if windows-latest
* reinstall compilers
  Commit: d1871a4bb851d2a2d2c355394741fca70e53c277
      https://github.com/PDAL/PDAL/commit/d1871a4bb851d2a2d2c355394741fca70e53c277
  Changed paths:
    M cmake/unix_compiler_options.cmake
  Log Message:
  No longer need to check cmake version.
  Commit: 49719854f6a118276174ca0633632b925d76d0f3
      https://github.com/PDAL/PDAL/commit/49719854f6a118276174ca0633632b925d76d0f3
  Changed paths:
    R .travis.yml
    M HOWTORELEASE.txt
    M README.md
    M pdal/Geometry.cpp
  Log Message:
  Commit: 176c4b257be49b77205974e3e05a47f8effe6fe4
      https://github.com/PDAL/PDAL/commit/176c4b257be49b77205974e3e05a47f8effe6fe4
  Date:   2020-09-18 (Fri, 18 Sep 2020)
  Changed paths:
    M filters/EigenvaluesFilter.cpp
  Log Message:
  Continue rather than return when min_k not met in EigenvaluesFilter (#3246)
  Commit: de893c684fec1a2165a1fcb68d68a427178028fd
      https://github.com/PDAL/PDAL/commit/de893c684fec1a2165a1fcb68d68a427178028fd
  Changed paths:
    M pdal/DimUtil.hpp
  Log Message:
  Make dimension array smaller.
  Commit: 0483db58b9f86129fae3500cba3c0f4bee21c7f2
      https://github.com/PDAL/PDAL/commit/0483db58b9f86129fae3500cba3c0f4bee21c7f2
  Changed paths:
  Log Message:
  Commit: 84e5d5a2d75548e43ff64b762c9856d32f56d193
      https://github.com/PDAL/PDAL/commit/84e5d5a2d75548e43ff64b762c9856d32f56d193
  Date:   2020-09-21 (Mon, 21 Sep 2020)
  Changed paths:
    M filters/LloydKMeansFilter.cpp
    M test/unit/CMakeLists.txt
    A test/unit/filters/LloydKMeansFilterTest.cpp
  Log Message:
  Add minimal test for LloydKMeans filter and switch back to RowPointTable (#3241)
* Add minimal test for LloydKMeans filter and switch back to RowPointTable
* Finalize layout rather than switch to RowPointTable
* Finalize the full point table, not just layout
  Commit: 1faf1fa06c5142535e9cf6ae9d251f87f23b6e45
      https://github.com/PDAL/PDAL/commit/1faf1fa06c5142535e9cf6ae9d251f87f23b6e45
  Changed paths:
    M doc/stages/writer_opts.rst
  Log Message:
  We don't do "where" on writers.
  Commit: 31473acf34dc4421e68ec2eb8923bce1912ebf9f
      https://github.com/PDAL/PDAL/commit/31473acf34dc4421e68ec2eb8923bce1912ebf9f
  Date:   2020-09-22 (Tue, 22 Sep 2020)
  Changed paths:
    M filters/CSFilter.cpp
  Log Message:
  Remove double loop in filters.csf (#3250)
  Commit: 8377e82e208fa5460784294129a0c31594f6c786
      https://github.com/PDAL/PDAL/commit/8377e82e208fa5460784294129a0c31594f6c786
  Changed paths:
    M plugins/rdb/CMakeLists.txt
  Log Message:
  Support stand alone plugin build for readers.rdb (#3247)
  Commit: 9eaa06d83625443944fe1cc4bca852b58d94aecc
      https://github.com/PDAL/PDAL/commit/9eaa06d83625443944fe1cc4bca852b58d94aecc
  Changed paths:
    A .github/workflows/alpine.yml
    A .github/workflows/docker.yml
    A scripts/ci/alpine/cmake.sh
    A scripts/ci/alpine/compile.sh
    A scripts/ci/alpine/examples.sh
    A scripts/ci/alpine/setup.sh
    A scripts/ci/alpine/test.sh
  Log Message:
  Add Alpine and Docker GHA builders (#3251)
* implement docker builder based on gh-action
* username for ghcr
* manual dispatch of docker action
* turn off push for now
* push  platforms: linux/amd64
* add Alpine test/build
  Commit: d46846c7d69efd7737da410cc0528897437e0079
      https://github.com/PDAL/PDAL/commit/d46846c7d69efd7737da410cc0528897437e0079
  Date:   2020-09-28 (Mon, 28 Sep 2020)
  Changed paths:
    M CMakeLists.txt
  Log Message:
  Update release number.
  Commit: 6cd29ee5bcac4fec21697595eed3d8f33824aeb4
      https://github.com/PDAL/PDAL/commit/6cd29ee5bcac4fec21697595eed3d8f33824aeb4
  Date:   2020-10-01 (Thu, 01 Oct 2020)
  Changed paths:
    M filters/private/expr/AssignStatement.hpp
    M scripts/ci/alpine/cmake.sh
  Log Message:
  Remove stder lint (#3257)
* don't print to stderr with every expression parse
* CI lint
  Commit: 4b594223a143f777bebdb9f916ec44288e109590
      https://github.com/PDAL/PDAL/commit/4b594223a143f777bebdb9f916ec44288e109590
  Date:   2020-10-05 (Mon, 05 Oct 2020)
  Changed paths:
    M io/LasHeader.cpp
    M io/LasHeader.hpp
    M io/LasReader.cpp
    M io/LasReader.hpp
    M io/LasVLR.cpp
    M io/LasVLR.hpp
    M test/unit/io/LasReaderTest.cpp
  Log Message:
  Check for bad LAS header values where possible. (#3237)
Co-authored-by: Howard Butler <howard at hobu.co>
  Commit: 97982f656060475740bf1582569909ec2e2735c4
      https://github.com/PDAL/PDAL/commit/97982f656060475740bf1582569909ec2e2735c4
  Changed paths:
    R .travis.yml
    M CMakeLists.txt
    M HOWTORELEASE.txt
    M README.md
    M RELEASENOTES.txt
    M io/EptReader.cpp
    M io/EptReader.hpp
    M io/GDALWriter.cpp
    M io/GDALWriter.hpp
    M io/LasHeader.cpp
    M io/LasHeader.hpp
    M io/LasReader.cpp
    M io/LasReader.hpp
    M io/LasVLR.cpp
    M io/LasVLR.hpp
    M io/ObjReader.cpp
    M io/ObjReader.hpp
    M io/TextWriter.cpp
    M package.sh
    M pdal/DimUtil.hpp
    M pdal/Geometry.cpp
    M pdal/Scaling.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master' into filters/relaxation-dart-throwing
Compare: https://github.com/PDAL/PDAL/compare/b3f9bd6ecd13...97982f656060
More information about the pdal-commits mailing list
