[pdal-commits] [PDAL/PDAL] 043e2f: Minor updates to several filters
chambbj noreply at github.com
Wed Oct 21 07:04:49 PDT 2020
  Branch: refs/heads/filter-dimensions-cleanup
  Home:   https://github.com/PDAL/PDAL
  Commit: 043e2f34d70a6729a6e6891649e72a973e5d388a
      https://github.com/PDAL/PDAL/commit/043e2f34d70a6729a6e6891649e72a973e5d388a
  Author: Bradley J Chambers <brad.chambers at gmail.com>
  Date:   2020-10-21 (Wed, 21 Oct 2020)
  Changed paths:
    M doc/stages/filters.litree.rst
    M doc/stages/filters.lof.rst
    M filters/ApproximateCoplanarFilter.cpp
    M filters/ApproximateCoplanarFilter.hpp
    M filters/EigenvaluesFilter.cpp
    M filters/EigenvaluesFilter.hpp
    M filters/EstimateRankFilter.cpp
    M filters/EstimateRankFilter.hpp
    M filters/LOFFilter.cpp
    M filters/LOFFilter.hpp
    M filters/LiTreeFilter.cpp
    M filters/LiTreeFilter.hpp
    M filters/MiniballFilter.cpp
    M filters/MiniballFilter.hpp
    M filters/OptimalNeighborhoodFilter.cpp
    M filters/OptimalNeighborhoodFilter.hpp
    M filters/PlaneFitFilter.cpp
    M filters/PlaneFitFilter.hpp
    M filters/RadialDensityFilter.cpp
    M filters/RadialDensityFilter.hpp
    M filters/ReciprocityFilter.cpp
    M filters/ReciprocityFilter.hpp
    M pdal/Dimension.json
  Log Message:
Initial focus is on updating static filters to always register official
Dimensions.
* LiTreeFilter now registers existing ClusterID instead of custom
  TreeID.
* LOFFilter now registers existing NNDistance instead of custom
  KDistance.
* OptimalNeighborhoodFilter now registers existing OptimalRadius and
  OptimalKNN.
* Register the following as "official" Dimensions: Coplanar,
  Eigenvalue0, Eigenvalue1, Eigenvalue2, LocalOutlierFactor,
  LocalReachabilityDistance, Miniball, PlaneFit, RadialDensity, Rank,
  Reciprocity
While updating Dimensions, also took the opportunity to:
* Be more explicit about datatypes, instead of relying on auto, to
  improve readability.
* Use PointView range-based for loops where it make sense. Generally
  makes code a little more succint.
* Do not pass KDIndex as frequently, when it can typically be grabbed
  off the view at no cost.
More information about the pdal-commits mailing list
