[pdal-commits] [PDAL/PDAL] 6c2899: Fix CI for Conda (#3453)
Andrew Bell noreply at github.com
Fri May 14 09:49:08 PDT 2021
  Branch: refs/heads/issue-3387
  Home:   https://github.com/PDAL/PDAL
  Commit: 6c289930894bc71cf6a895b13b8249434a0a6fdf
      https://github.com/PDAL/PDAL/commit/6c289930894bc71cf6a895b13b8249434a0a6fdf
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2021-05-13 (Thu, 13 May 2021)
  Changed paths:
    M .github/workflows/conda.yml
    M scripts/ci/conda/compile.sh
    M scripts/ci/conda/examples.sh
    M scripts/ci/conda/upload.sh
    M scripts/ci/osx/setup.sh
    M scripts/ci/win/setup.sh
  Log Message:
* force
* lammly
* v1
* rename env var.
  Commit: bd636f8185fa295eeb66b78525407df983c09174
      https://github.com/PDAL/PDAL/commit/bd636f8185fa295eeb66b78525407df983c09174
  Author: chambbj <brad.chambers at gmail.com>
  Changed paths:
    M filters/FarthestPointSamplingFilter.cpp
  Log Message:
  Return all points when a PointView does not have count points (#3454)
Fix #3447
  Commit: f008aa8ef0e522d8aa7d76afb1f423d7bb9738e1
      https://github.com/PDAL/PDAL/commit/f008aa8ef0e522d8aa7d76afb1f423d7bb9738e1
  Changed paths:
    M plugins/teaser/filters/TeaserFilter.cpp
    M plugins/teaser/filters/TeaserFilter.hpp
    R plugins/teaser/filters/registration.h
  Log Message:
  Fix teaser issue with make_unique (#3451)
  Commit: 3448207184a822789b5c481185a51608892cfaa0
      https://github.com/PDAL/PDAL/commit/3448207184a822789b5c481185a51608892cfaa0
  Changed paths:
    M filters/HeadFilter.cpp
  Log Message:
  Set index to zero within run() s.t. we can handle multiple PointViews correctly (#3449)
* Set index to zero within run() s.t. we can handle multiple PointViews
correctly
Fix #3448
* Add ready() back for streaming support
  Commit: b172d831b74b37c1dbdeaa5f805239a2cb36d83c
      https://github.com/PDAL/PDAL/commit/b172d831b74b37c1dbdeaa5f805239a2cb36d83c
  Author: Norman Barker <norman at tiledb.io>
  Date:   2021-05-14 (Fri, 14 May 2021)
  Changed paths:
    M plugins/tiledb/io/TileDBWriter.cpp
    M plugins/tiledb/test/TileDBReaderTest.cpp
    M plugins/tiledb/test/TileDBWriterTest.cpp
  Log Message:
  Add TileDB Hilbert configuration (#3445)
* Add TileDB Hilbert configuration
* Added test for setting TileDB tile sizes
* Fix tests for sfcurve with TileDB 1.7
Co-authored-by: normanb <norman at tiledb.com>
  Commit: a91f7a5eedb22580d429356716eb51a4d5d25adc
      https://github.com/PDAL/PDAL/commit/a91f7a5eedb22580d429356716eb51a4d5d25adc
  Changed paths:
  Log Message:
  Merge remote-tracking branch 'origin/master' into issue-3387
Compare: https://github.com/PDAL/PDAL/compare/01379e7d7870...a91f7a5eedb2
More information about the pdal-commits mailing list
