[pdal-commits] [PDAL/PDAL] aeba5f: Squash windows warning
Andrew Bell noreply at github.com
Wed May 19 06:13:32 PDT 2021
  Branch: refs/heads/master
  Home:   https://github.com/PDAL/PDAL
  Commit: aeba5fa9359458af8e01289bfca75e1e16120891
      https://github.com/PDAL/PDAL/commit/aeba5fa9359458af8e01289bfca75e1e16120891
  Author: Andrew Bell <andrew.bell.ia at gmail.com>
  Date:   2021-05-19 (Wed, 19 May 2021)
  Changed paths:
    M CMakeLists.txt
    M plugins/i3s/io/EsriReader.cpp
  Log Message:
  Commit: 8ab45d93335a0bab4e208963b893333411fe75be
      https://github.com/PDAL/PDAL/commit/8ab45d93335a0bab4e208963b893333411fe75be
  Changed paths:
    M CMakeLists.txt
    M cmake/lazperf.cmake
    M doc/download.rst
    M doc/stages/readers.ept.rst
    M doc/workshop/conda.rst
    M doc/workshop/exercises/analysis/colorization/colorization.rst
    M doc/workshop/exercises/analysis/colorization/colorize.json
    M doc/workshop/exercises/analysis/rasterize/classification.json
    M doc/workshop/exercises/analysis/thinning/thinning.rst
    M doc/workshop/exercises/info/metadata.rst
    M doc/workshop/exercises/translation/entwine.json
    M io/EptReader.cpp
    M io/EptReader.hpp
    M io/LasHeader.cpp
    M io/LasHeader.hpp
    M io/LasReader.cpp
    M io/LasWriter.cpp
    M io/LasWriter.hpp
    R pdal/compression/LazPerfCompression.cpp
    R pdal/compression/LazPerfCompression.hpp
    M pdal/compression/LazPerfVlrCompression.cpp
    M pdal/compression/LazPerfVlrCompression.hpp
    M pdal/private/SrsTransform.cpp
    M pdal/private/SrsTransform.hpp
    M pdal/util/Bounds.cpp
    M pdal/util/Bounds.hpp
    M test/unit/BoundsTest.cpp
    M test/unit/io/EptReaderTest.cpp
    M test/unit/io/LasReaderTest.cpp
    M test/unit/io/LasWriterTest.cpp
  Log Message:
  Merge remote-tracking branch 'origin/master'
Compare: https://github.com/PDAL/PDAL/compare/dc856a0a79d4...8ab45d93335a
More information about the pdal-commits mailing list
