[pgrouting-dev] APSP Implementation
Stephen Woodbridge woodbri at swoodbridge.com
Wed Dec 1 19:32:06 EST 2010
Jay,
Sounds like you have a good handle on all the pieces to this problem.
What do you need to get started :)
-Steve
On 12/1/2010 6:21 PM, Jay Mahadeokar wrote:
> When (v^2 log n) > n^2 we can use Warshall algo. Extracting paths will
>         be complicated task.
>             I think some thought needs to go into:
>             1. what are the results? just a V^2 table of costs?
>             2. can we extract the paths? In pgRouting, this has some
>         additional
>             implications beyond is it physically possible to extract
>         paths from
>             the algorithm.
>               a. typically queries do not store results, they only
>         return sets
>               b. extracting paths, implies computing assembling a graph,
>             computing the results and holding the results for additional
>         queries
>             against them to extract paths.
>               c. while this is potentially possible using temp tables,
>         we do not
>             currently do that
>         I did not properly understand point b above.
>     OK, I will try to explain. Typically the process of running a
>     pgRouting query follows something along this pseudo code:
>     1. select a subset of all node that we think will be enough to solve
>     our problem. This is done via a bounding box of the start and end
>     nodes inw question and expanded somewhat in case the route wanders
>     out of the bounding box.
>     2. these nodes and the edges connected to them are built into a
>     boost graph
>     3. the boost graph is solved
>     4. the results are return to the SQL caller as a set of database
>     records.
>     5. the boost graph is destroyed
>     So basically one input, one process, one output. Nothing is saved.
>     If on the other hand we had a process like:
>     1. build graph
>     2. solve graph
>     3. return matrix of distances
>     4. hold onto graph because these might be addition requests the need
>     the matrix
>     5. request path A-B from graph
>     6. request path D-H from graph
>     7. request ...
>     8. we are done with the graph so destroy it
>     Which is my assumption that we would need to do to extract paths,
>     then we do not have a paradigm for this in SQL.
>     Now we may not need to do that, but I was assuming that there was
>     information in the graph that was easy to extract about the paths
>     that gave the distance returned in the distance matrix.
> Hey.. Again, during  step 3 above, if we build the path matrix along
> with the distance matrix for Warshall Algo, we can use that to extract
> all paths, we will not need any more queries to database. We also need
> not hold on to the graph! And the overall time is still O(n^3)  :)
>         I am not sure if the boost implementation of Warshall returns a path
>         matrix,
>         http://www.boost.org/doc/libs/1_45_0/libs/graph/doc/floyd_warshall_shortest.html
>         says that it will just return the distance matrix.
>         In theory, we can simultaneously create a n^2 path matrix along
>         with the
>         distance matrix and use that to extract paths. Pseudo code is
>         present
>         here:
>         http://en.wikipedia.org/wiki/Floyd%E2%80%93Warshall_algorithm. So,
>         if we want to build the path matrix, we need to code Warshall from
>         scratch, using maybe boost data structures.
>     I guess this is up to the use cases for this and maybe we should ask
>     others to chime in based on their needs.
>     I think this really depends on the number of nodes that a user needs
>     to work with. If you assume asymmetric directed graph, the you need
>     to compute n^2 distances. for small say n<20 that is 400 routes and
>     if at 1 sec per route it takes 6.67 minutes; n=100 it takes about
>     2.78 hours.
> I guess assuming 1 sec per route is too slow for modern processors! If
> you are including the database query latency, then again Path Matrix
> will make sure we need to query database only once, so the rest of the
> work should be fast.
>     My use case would be to feed the results into TSP solver to order
>     the nodes, then to extract the routes between the ordered nodes. I
>     have used simulated annealing to solve TSP very fast.
>     http://imaptools.com/cgi-bin/tsp.cgi
>     Copy and paste the cities into the text area and compute the TSP.
>     This demo application geocodes all the cities and comput the
>     straight line distance between them and then solves the TSP problem.
>     It would really be grate to compute the network paths before solving
>     the TSP.
>     I know pgRouting has a TSP solver, but it requires the CGAL package
>     I think which is hard to find and build on many systems.
> Nice Application! I am not sure what is complexity of your algorithm.
> But if you want to compute actual paths before feeding the algo, I guess
> the number of nodes in the path will increase by a big factor which will
> slow down APSP significantly. (You may just consider Highways to get
> around this, could discuss this on a separate topic!)
>         If we have vertex ids of whole graph, the path matrix is
>         sufficient to
>         extract all paths (extracting one path will take O(n) time), and
>         I think
>         there is no need for additional queries to database.
>     I saw the path extraction code in the wiki page , but I need to go
>     back over it in more detail.
>     Best regards,
>       -Steve W
>         Please correct me if I am missing something.
>             Anyway, these are some things to start a discussion and
>         provoke some
>             thoughts. I do not want to grow the scope of this project to the
>             point that it is problematic, so we should focus on what can
>         be done
>             and plan for future additions if they are needed.
>             I look forward to working with you. Thank you for your
>         interest in
>             pgRouting.
>             Best regards,
>               -Steve W
>             _______________________________________________
>             pgrouting-dev mailing list
>         pgrouting-dev at lists.osgeo.org
>         <mailto:pgrouting-dev at lists.osgeo.org>
>         <mailto:pgrouting-dev at lists.osgeo.org>>
>         http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>         Regards,
>         -Jay Mahadeokar
>         pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
> Regards,
> -Jay Mahadeokar
More information about the pgrouting-dev mailing list
