[pgrouting-dev] APSP Implementation
Stephen Woodbridge woodbri at swoodbridge.com
Sun Dec 19 19:47:21 EST 2010
Hi Jay,
I have not done this myself, so you might have to wait for Anton. But
you might check out:
http://www.google.com/#q=postgresql+server+debug
I believe that you need to runt postgresql in single user mode to start
with. Beyond that I think a quick look at the postgresql docs should
indicate how to run this in gdb so you can catch the error.
-Steve
On 12/19/2010 5:07 PM, Jay Mahadeokar wrote:
> Hi Stephen,
> Thanks for the quick reply.
> I did as you said, and now I can see the function when I do \df.
> Now, Im getting following msg:
> server closed the connection unexpectedly
> This probably means the server terminated abnormally
> before or while processing the request.
> The connection to the server was lost. Attempting reset: Failed.
> How can I print the errors/ stack traces that are going on in
> background?  (I am sorry if this is too naive, but I am doing this kind
> of debugging for the first time) Any online documentation/manuals in
> this regard would really help.
> On Mon, Dec 20, 2010 at 3:12 AM, Stephen Woodbridge
> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>     Hi Jay,
>     It sounds like you have the correct approach as outlined. I think
>     the only step that you missed is that you have to load you wrapper
>     function into the database.
>     psql mydatabase
>       CREATE OR REPLACE FUNCTION all_pairs_shortest_path(sql text, directed
>       boolean, has_reverse_cost boolean)
>               RETURNS SETOF apsp_result
>               AS '$libdir/librouting'
>               LANGUAGE 'C' IMMUTABLE STRICT;
>       -- now run your query
>     The wrappers get loaded because they are in the sql files like:
>      > -- Up-to-date: /usr/share/postlbs/routing_core_wrappers.sql
>     You could create a new file like:
>     routing_extra_wrappers.sql  or
>     routing_apsp_wrappers.sql
>     And have cmake install them, or manually install them like above.
>     If you areadly did that and you can see you function in the list of
>     functions in psql like:
>     \df+ all_pairs_shortest_path
>     Then try adding a cast TEXT as shown below:
>     SELECT * from  all_pairs_shortest_path(
>     'SELECT gid as id,source::integer,target::integer,
>          length::double precision as cost from ways'::TEXT,
>          false,false);
>     -Steve
>     On 12/19/2010 3:54 PM, Jay Mahadeokar wrote:
>         Hi,
>         *I am currently trying to implement apsp as follows: *
>         directed
>         Now, I think my boost_apsp() function is working for small input
>         data,
>         and I want to test if the overall query is working. I have coded
>         apsp.c
>         accordingly.
>         I have modified /core/cMakeLists.txt so as to just build apsp and
>         dijkstra for now:
>         "ADD_LIBRARY(routing SHARED dijkstra.c apsp.c boost_wrapper.cpp
>         apsp_boost_wrapper.cpp)"
>         Here is the output after I run "cmake -DWITH_DD=ON", and then
>         "make":
>         jay at jay-HP-Compaq-6720s:~/Desktop/pgRouting/pgRouting-pgrouting-7b07040$
>         make
>         [ 50%] Built target routing_dd
>         Scanning dependencies of target routing
>         [ 62%] Building C object core/src/CMakeFiles/routing.dir/apsp.o
>         Linking CXX shared library ../../lib/librouting.so
>         [100%] Built target routing
>         sudo make install
>         [sudo] password for jay:
>         Install the project...
>         -- Install configuration: ""
>         -- Installing: /usr/lib/postgresql/8.4/lib/librouting.so
>         -- Installing: /usr/share/postlbs/routing_core.sql
>         -- Up-to-date: /usr/share/postlbs/routing_topology.sql
>         -- Up-to-date: /usr/share/postlbs/matching.sql
>         -- Installing: /usr/lib/postgresql/8.4/lib/librouting_dd.so
>         -- Installing: /usr/share/postlbs/routing_dd.sql
>         -- Installing: /usr/share/postlbs/routing_dd_wrappers.sql
>         I think there were no compilation errors while compiling apsp files.
>         Now, when i log into postgres and query for shortest_path() on
>         pgrouting-workshop database, I get the correct results.
>         *But, query on all_pairs_shortest_path() gives this: *SELECT * from
>         all_pairs_shortest_path('SELECT gid as
>         id,source::integer,target::integer,length::double precision as
>         cost from
>         ways',false,false);
>         ERROR:  function all_pairs_shortest_path(unknown, boolean,
>         boolean) does
>         not exist
>         LINE 1: SELECT * from all_pairs_shortest_path('SELECT gid as
>         id,sour...
>         HINT:  No function matches the given name and argument types.
>         You might
>         need to add explicit type casts.
>         I tried restarting the postgres server too.
>         *Questions:*
>         1. For testing the new function, am I following correct approach?
>         2. I will try to learn some git commands and upload my source
>         code in
>         the repository that I have forked here:
>         https://github.com/jay-mahadeokar/pgrouting, I guess it would be
>         easier
>         for you guys to provide help and see what is actually going on
>         that way,
>         right?
>         On Fri, Dec 17, 2010 at 4:48 PM, Daniel Kastl
>         <daniel at georepublic.de <mailto:daniel at georepublic.de>
>         <mailto:daniel at georepublic.de <mailto:daniel at georepublic.de>>>
>         wrote:
>             Hi Jay,
>             Thank you for giving us some updates!
>             Anton traveled to freezing cold Siberia yesterday and it
>         could take
>             some days for him to defrost ;-)
>             So maybe it will a while until he can answer.
>             I will try to take a look the next days and see if I can
>         give some
>             advice, but probably it's better to hear Anton.
>             Daniel
>                 *Some Questions:*
>                 Now, I need to code apsp.c which will retrieve the edges
>         / nodes
>                 from postgres database and call the above function. The
>         result
>                 will be returned as apsp_result.
>                 For dijkestra, we have the following query format:
>                 SELECT gid, source, target, cost FROM edge_table
>                 For, apsp will the query format remain same?
>                 Or do we take the vertices(in form of points) as input
>                 separately, in some other format? One application of
>         this might
>                 be when a user will select a set of points on map and
>         call apsp
>                 on those points.
>                 On Wed, Dec 8, 2010 at 2:12 PM, Daniel Kastl
>         wrote:
>                         For now, can we go ahead and implement the above
>         algo in
>                         pgRouting? I am thinking of a warshall_wrapper class
>                         that would call the above function, and the actuall
>                         warshall apsp would return distances in form of
>         rows,
>                         each row having three columns:
>                         source, target, distance. (We will have nC2 such
>         rows
>                         for now..)
>                     As Anton mentioned, this can get confusing
>         sometimes. Too
>                     many sources and targets, can be the ones of an edge
>         or of a
>                     route.
>                     Any good idea how define names in an easy to
>         understand and
>                     clear way is welcome. This is probably going to
>         become more
>                     of an issue as more pgRouting grows.
>                     @Anton: maybe we should somewhere define a dictionary of
>                     terms we use and what we use them for.
>                     Other thing, I didn't really get your answer how to
>         prevent
>                     mixing source/target ... was there a "not" missing? It
>                     wasn't clear to me
>                         Some queries:
>                         1. I have not yet tried modifying the pgRouting
>         source
>                         code, and compiling other files together with the
>                         existing ones. I am completely new to cmake and
>         will try
>                         and learn how to work with that. From what I have
>                         understood, every new algorithm that we add to
>         existing
>                         set will have a similar flow and similar files
>         etc. Is
>                         there any doc which can guide as to what
>         configuration
>                         changes would be needed for adding a new algo (For
>                         example we would usually add following files:
>         algo.h,
>                         algo.cpp, algo.sql, algo_boost_wrapper.cpp etc).  (I
>                         hope my query is clear)
>                     If I find some time I want to study the CMake
>         manual, too,
>                     and see if we can make some improvements here and
>         there. I
>                     think it was also new for Anton at the time of
>         writing the
>                     files, so if you find some possible improvements,
>         let me know.
>                     There are no "coding standards" defined yet, which
>         would be
>                     probably a good idea when more algorithm will be
>         implemented
>                     in the future.
>                     Same as above, if you have some idea, then you can share
>                     with us. We're open for criticism! Otherwise I
>         believe it's
>                     sometimes better to have a couple of algorithms
>         first and
>                     then see what could be "standardized" and define
>         them based
>                     on our experience.
>                     Btw., if you want to make use of GitHub, then you
>         can create
>                     an account and fork the pgRouting repository:
>         https://github.com/pgRouting/pgrouting
>                     It will be then easy to apply your changes.
>                     Anton, where will APSP go? To "core" or to "extras"?
>                     Seeing the number of extensions grow, does this
>         structure
>                     still work for us?
>                     How do we define what is "core" and what is "extra"?
>                     I think the initial main idea was to provide pgRouting
>                     without Gaul and CGAL dependencies.
>                         2. Are there any sample test cases/scripts,
>         which were
>                         used to test dijkstras algo (which can be useful
>         here too)?
>                     I think that pgRouting should have unit tests ... but we
>                     don't have so far, which is not so good ;-)
>                     Here is a ticket already:
>         https://github.com/pgRouting/pgrouting/issues#issue/20
>                     As usual it's a lack of time to work on this.
>                     It's probably better to have some generic testing
>         data than
>                     just take OSM data from the workshop, Anton.
>                     OSM data won't allow us to test all possible
>         functionality
>                     some functions provide.
>                     Daniel
>                     Georepublic UG & Georepublic Japan
>                     eMail: daniel.kastl at georepublic.de
>         <mailto:daniel.kastl at georepublic.de>
>         <mailto:daniel.kastl at georepublic.de>>
>                     Web: http://georepublic.de <http://georepublic.de/>
>                     _______________________________________________
>                     pgrouting-dev mailing list
>         pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
>         <mailto:pgrouting-dev at lists.osgeo.org>>
>         http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>                 Regards,
>                 -Jay Mahadeokar
>         Regards,
>         -Jay Mahadeokar
> Regards,
> -Jay Mahadeokar
More information about the pgrouting-dev mailing list
