[pgrouting-dev] General question for understanding
Daniel Kastl daniel at georepublic.de
Fri Feb 11 09:37:53 EST 2011
2011/2/11 Hens,Markus M. <m.hens at student.fontys.nl>
> Hey Daniel,
> you mean its only possible for ways instead of nodes?
Yes. If you have attributes as part of nodes, you need to model your network
in a way, that it takes these attributes into account. The shortest path
algorithms require road links with "costs". If you think this is not
possible, just make your "bridge" point a road link ... in reality it's
rather a linestring than a point anyway.
Daniel
> Markus
> ________________________________________
> Von: pgrouting-dev-bounces at lists.osgeo.org [
> pgrouting-dev-bounces at lists.osgeo.org] im Auftrag von Daniel Kastl [
> daniel at georepublic.de]
> Gesendet: Freitag, 11. Februar 2011 15:17
> An: pgRouting developers mailing list
> Betreff: Re: [pgrouting-dev] General question for understanding
> Hi Markus.
> It's only possible for nodes. But as somehow the vehicle that needs to pass
> this node also must pass one or more ways to this node, you could add the
> hight limitation as an attribute to the ways, right?
> In you SQL query you could exclude all road links that contain a node that
> has a height limitation for example.
> Daniel
> 2011/2/11 Hens,Markus M. <m.hens at student.fontys.nl<mailto:
> m.hens at student.fontys.nl>>
> Hi Daniel,
> thank you for the information. I understand these informations but I have
> one more question.
> If I have a node for example a bridge with an attribute for height and my
> vehicle is higher I would like to set the cost very high for the node.
> My question is if it is possible to set cost for nodes or only for ways.
> Markus
> Von: pgrouting-dev-bounces at lists.osgeo.org<mailto:
> pgrouting-dev-bounces at lists.osgeo.org> [
> pgrouting-dev-bounces at lists.osgeo.org>] im Auftrag von Daniel Kastl [
> daniel at georepublic.de<mailto:daniel at georepublic.de>]
> Gesendet: Freitag, 11. Februar 2011 14:47
> Hi Markus,
> Now it worked ;-)
> m.hens at student.fontys.nl><mailto:m.hens at student.fontys.nl<mailto:
> m.hens at student.fontys.nl>>>
> Hey all,
> I am new to pgRouting and I have a general question.
> When I have imported my osm data to pgRouting database and calculate a
> route via A* from x to y does the result contains any information about
> where it is allowed to drive?
> The route shouldn't contain any roads in the result you're not allowed to
> drive at. It should instead return you another way instead.
> For example would the result route me in an oneway street where I am not
> allowed to drive?
> The "cost" attribute for a road link is the cost from start to end node,
> the "reverse_cost" attribute is the cost in the opposite direction:
> http://www.pgrouting.org/docs/1.x/astar.html
> So a oneway street has very high cost in one of these two cost attributes.
> If this cost is very high it will always try to find another way ... except
> there is no other way. But you could easily check this if the result returns
> very high "cost"
> Does the result really contains only the shortest path with no information
> about prohibitions or am I wrong?
> Yes. You have to model your network that it reflects these prohibitions.
> Daniel
> Best regards,
> Markus Hens_______________________________________________
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org<mailto:pgrouting-dev at lists.osgeo.org
> ><mailto:pgrouting-dev at lists.osgeo.org<mailto:
> pgrouting-dev at lists.osgeo.org>>
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de<mailto:daniel.kastl at georepublic.de
> ><mailto:daniel.kastl at georepublic.de<mailto:daniel.kastl at georepublic.de>>
> Web: http://georepublic.de<http://georepublic.de/>
> pgrouting-dev at lists.osgeo.org<mailto:pgrouting-dev at lists.osgeo.org>
> eMail: daniel.kastl at georepublic.de<mailto:daniel.kastl at georepublic.de>
URL: http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20110211/6d67a123/attachment-0001.html
More information about the pgrouting-dev mailing list
