[pgrouting-dev] Cannot create topology
Stephanos Charalambous stephanos_ch at yahoo.gr
Thu Feb 17 08:46:58 EST 2011
Hello,
I am kind of new in using pgrouting and I would really like your help.
I have imported a road network, called "testNic" (from shapefile) into a PostgreSQL database using QGIS and pgAdmin. Then, I added the necessary columns, source, target and cost, and created the geom_idx. The problem that I am facing is that I cannot create the topology using the query:
SELECT assign_vertex_id('testNic', 0.00001, 'the_geom', 'gid');
I get the following error, and i can't locate where the mistake is.
NOTICE:  CREATE TABLE will create implicit sequence "vertices_tmp_id_seq" for serial column "vertices_tmp.id"
CONTEXT:  SQL statement "CREATE TABLE vertices_tmp (id serial)"
PL/pgSQL function "assign_vertex_id" line 14 at EXECUTE statement
ERROR:  find_srid() - couldnt find the corresponding SRID - is the geometry registered in the GEOMETRY_COLUMNS table?  Is there an uppercase/lowercase missmatch?
CONTEXT:  PL/pgSQL function "assign_vertex_id" line 20 at assignment
********** Error **********
SQL state: P0001
Context: PL/pgSQL function "assign_vertex_id" line 20 at assignment
Any help would be really appreciated.
Regards
More information about the pgrouting-dev mailing list
