[pgrouting-dev] Re: Network Layering support
Daniel Kastl daniel at georepublic.de
Fri Feb 18 07:57:25 EST 2011
Hi Jay,
Thank you for taking a look at the source code!
I think Anton can answer better to your questions, so I actually just want
to send you two additional links I just found about now:
   - http://routingdemo.geofabrik.de/
   - http://sourceforge.net/projects/routed/
It uses contraction hierarchies algorithm.
Regarding the license (AGPL) and the one of pgRouting (GPL) we probably need
to make sure, that CH will become an optional component.
>From my level of understanding I agree with Steve, that CH would just
provide another way of pre-processing the data than we do now. If this is
possible and how it works best within a database, that's probably the big
challenge.
@Anton ... did you catch this conversation?
Daniel
2011/2/17 Stephen Woodbridge <woodbri at swoodbridge.com>
> On 2/16/2011 10:17 PM, Jay Mahadeokar wrote:
>> Hi,
>> On Sat, Jan 29, 2011 at 6:13 AM, Stephen Woodbridge
>> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>>    *Source Code *(Quote from their web-page)
>>        /The source code of our implementation of contraction
>>        hierarchies (CHs)
>>        is  now available under the terms of the AGPL. If you are
>>        interested in
>>        getting the source code write an email to Robert Geisberger
>>        <http://algo2.iti.kit.edu/english/geisberger.php>.
>> I had requested Robert Geisberger for the source code of CH, and I went
>> thru it (Grateful to him for making the source available under AGPL). It
>> takes as input .ddsg files and produces contraction hierarchies in .ch
>> file format.
>> *.DDSG* *File Format:*
>>    * a /text/-file, whitespace-separated;
>>    * starts with single letter 'd';
>>    * followed by the number of nodes /n/ and the number of edges /m/
>>    * for each of the /m/ edges, we have
>>          o source node ID /s/, an unsigned 32-bit integer, 0 <= /s/ < /n/;
>>          o target node ID /t/, an unsigned 32-bit integer, 0 <= /t/ < /n/;
>>          o edge weight /w/, an unsigned 32-bit integer; note that the
>>            length of the longest shortest path must fit into a 32-bit
>>            integer
>>          o the direction /d/: //
>>                + //0 = open in both directions //
>>                + //1 = open only in forward direction (from /s/ to /t/) //
>>                + //2 = open only in backward direction (from /t/ to /s/)
>>                + //3 = closed //
>>            //Note that specifying an edge (s,t,w,1) is equivalent to
>>            specifying an edge (t,s,w,2). It does not matter which form
>>            is used. In the current implementation, 3 is interpreted as
>>            0, i.e., closed roads are used in both directions. If you
>>            really want to completely close a road, just leave it away. //
> So this seems to define the minial requirements of the "ways" table in that
> we need to easily be able to extract this data and pass it to the
> pre-processor. And maybe the results need to be able to fetch some of this
> data.
>  *CH File Format:*
>>    * a /binary/ file, 32-bit-interger organized
>>    * layout:
>>          o "|CH\r\n|" (|0x32 0x48 0x0d 0x0a|)
>>          o unsigned int: version (currently "|1|", shold be |==| compared)
>>          o unsigned int: number of nodes (= n)
>>          o unsigned int: number of original edges (= m_1 )
>>          o unsigned int: number of shortcut edges (= m_2 )
>>          o n times, for each node 0..(n-1):
>>                + unsigned int: level
>>          o m_1 times, original edges:
>>                + unsigned int: source node
>>                + unsigned int: target node
>>                + unsigned int: weight
>>                + unsigned int: flags
>>          o m_2 times, shortcut edges:
>>                + unsigned int: shortcut middle node
>>          o unsigned int: |0x12345678| as terminator
>>    * possible (bit) flags are:
>>          o |1| = forward edge
>>          o |2| = backward edge
>>          o |4| = shortcut edge
>>          o Note that not all edges of the original graph are listed as
>>            original edges. Edges that are not on any shortest path may
>>            be removed or replaced by shortcuts.
> Seem like this data could be put in tables or blob(s) depending on how much
> there. Obviously get data in/out of the database instead of these files will
> have an impact on the code, but hopefully that is manageable.
>  *Few queries:*
>> 1. If pgRouting has to support the routing using contraction
>> hierarchies, what exactly is the idea? The postgres database table like
>> "ways" will be taken as input and the output would be another postgres
>> database table that will include data in form of contraction hierarchies?
> I would envision that we take a table like "ways" as input. I could see
> additional columns or tables that might contain other data like turn
> restrictions, or whatever might be needed for input. But to keep it simple
> something similar to the current table which has edges, geometry, costs,
> etc. I might have nodes assigned or not if you process did that.
> Today we prep the "ways" table by creating the "source" and "target" node
> number columns and run assign_node_id() process to create nodes for each
> edge. I see some kind of process the reads this data and creates the
> contraction hierarchies data that then gets stored back into the database
> however you deem appropriate.
>  2. The queries will be same like shortest_path() just that at backend
>> the contraction hierarchies pre-processed data be used?
> Correct. The input might change because the requirements for contraction
> hierarchies might be different, but a route request would be started by a
> call to a stored procedure. The result should be a record set where each
> represents traversing a single segment in the original "ways" table. For
> example the results might be simply a list of gid in the order of traversal
> or something more. Some example results might be:
> Each of these represents a set of record:
> 1. gid
> 2. gid, cost
> 3. gid, reversed, cost
> etc
> gid  - unique edge id from the "ways" table
> cost - cumlative cost to get to the end of this segment along the path
> reversed - Y|N flag to indicate if traversed backwards or forwards
>  3. What should be the exact format for representing data for contraction
>> hierarchies?
> I'm not sure what you are asking here. If this is the internal contraction
> hierarchies data created by the preprocessing step, then I think this is up
> to you. You might want to store it as a blob, if data can be spatially
> organized so you can fetch it as needed, then some brainstorming on how to
> do that might be appropriate.
> To some extent, performance of this process in the database will probably
> be limited to how efficiently you can access the data need to process the
> request.
> In the current process, we give a bounding box for the data we need,
> because we have to read that data and then build a boost graph structure and
> then solve that graph. Since the data is preprocessed, I'm not sure that is
> need for this so we might just have something like:
> select start_node from CH_pnt_to_node(start_point);
> select end_node from CH_pnt_to_node(end_point);
> select * from CH_solve("table", start_node, end_node);
> or something like that. Basically if there are helper function needed then
> that is appropriate.
> Best regards,
>  -Steve
>>    Right, but there are also a few other implementations of the
>>    contraction hierarchies in the wild that might not be based on their
>>    code, like the MONAV implementation, which is released on GPLv3, and
>>    at least one person was looking at it in conjunction with Boost
>>    (google: contraction hierarchies boost)
>> Regards,
>> -Jay Mahadeokar
>> pgrouting-dev mailing list
>> pgrouting-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20110218/a5747dfc/attachment-0001.html
More information about the pgrouting-dev mailing list
