[pgrouting-dev] Re: Network Layering support
Stephen Woodbridge woodbri at swoodbridge.com
Fri Feb 18 16:45:30 EST 2011
On 2/18/2011 3:53 PM, Jay Mahadeokar wrote:
> Hi Anton,
> On Fri, Feb 18, 2011 at 6:27 PM, Daniel Kastl <daniel at georepublic.de
> <mailto:daniel at georepublic.de>> wrote:
>     Hi Jay,
>     Thank you for taking a look at the source code!
>     I think Anton can answer better to your questions, so I actually
>     just want to send you two additional links I just found about now:
>         * http://routingdemo.geofabrik.de/
>         * http://sourceforge.net/projects/routed/
>     It uses contraction hierarchies algorithm.
> Thanks for the links. Are you certain that the above project uses
> contraction hierarchies algorithm by Robert Geisberger? I went thru the
> source, and they are using contraction, but I did not see where they
> have used the node ordering step as proposed in the CH paper. I did not
> find contraction hierarchies mentioned in their readme too:
> http://sourceforge.net/apps/trac/routed/wiki/ReadMe
It is possible that they read the paper and made their own
implementation to avoid the AGPL license. The paper is describes the
algorithms in great detail, so I'm sure this is possible.
> Anyways, they are using osm file as input and the output consists of two
> files 'file.osrm' and 'file.osrm.names'. Which is again preprocessed to
> generate  file.osrm.hsgr' 'file.osrm.nodes' which are then used for
> answering queries.
> Again, a method to keep the data pre-processed in order to speed up
> dijekstra.
>     Regarding the license (AGPL) and the one of pgRouting (GPL) we
>     probably need to make sure, that CH will become an optional component.
>      From my level of understanding I agree with Steve, that CH would
>     just provide another way of pre-processing the data than we do now.
>     If this is possible and how it works best within a database, that's
>     probably the big challenge.
> I agree. So, basically if we want to add CH to pgRouting we will need
> following components:
> Preprocessing*
>   Tool like osmtopgrouting_CH that would preprocess the osm files to
> postgres tables.
I think we need a general tool that can extract data from postgis tables
into the CH preprocessor. There are a lot of people that are not using
OSM data.
>      If we are using the code already made available thru AGPL (I dont
> understand the intricacies of different licences) by Robert
I think we need to read and understand the AGPL license and how it might
impact on the current license. These are tricky issues and it might
prohibit us from including their code directly.
If we wanted to do that we could still use the AGPL code to build test
model that would allow us to validate the our code was getting
reasonable results.
> Geisberger, then we can first have following:
>     A. Module that converts osm data to ddsg files.
>     B. Use the above code to convert ddsg files into .ch(contraction
> hierarchy) files
>     C. Convert the .ch file into postgres_ch database table.
This seems like a reasonable approach to start with. We might eventually
want to replace step A. with a stored procedure that does this step in
the database, but that would be more complicated and require
re-factoring the Geisberger code or designing and coding a new module
that does the same thing which might get around the licensing issues.
> *Quering*
> If you look at the CH algorithm, the main idea is to add shortcut edges
> using node ordering such that the overall new edges added justify the
> extra space used in terms of speed-up gained.
> The .ch file produced retains original edges, but also contains the
> added short-cut edges. Now, suppose we have converted this info into
> postgres table. According to my intuition, the original shortest path
> query should readily work on this table data and provide considerable
> speed up due to shortcuts.
Obviously, you need to be able to reconstruct the original path that the
short-cut edge represented.
> The CH paper also talks about various refinements in the shortest path
> algo which will enhance the speed even more. Techniques include the
> concept of searching on Upward and Downward graphs, pruning search space
> using stall-on-demand technique etc. (I have just had an overview and
> not understood the techniques in complete detail for now)
Sounds like more good stuff that needs to be understood. I read the
paper about a year ago, so it is not fresh in my mind, so I guess I need
to make some time to re-read it.
> So, this can be a completely different module :
> Shortest path query on the CH preprocessed table using the speed-up
> techniques mentioned in CH paper.
> I tried to put forward my understanding of the problem. Need to take a
> deeper look into source code as well as paper before the above points
> can be confirmed.
Sounds like you have made a great start already, keep up the good work
on this.
Best regards,
   -Steve
>     @Anton ... did you catch this conversation?
>     Daniel
>     2011/2/17 Stephen Woodbridge <woodbri at swoodbridge.com
>     <mailto:woodbri at swoodbridge.com>>
>         On 2/16/2011 10:17 PM, Jay Mahadeokar wrote:
>             Hi,
>             On Sat, Jan 29, 2011 at 6:13 AM, Stephen Woodbridge
>             <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>
>             <mailto:woodbri at swoodbridge.com>>> wrote:
>                 *Source Code *(Quote from their web-page)
>                     /The source code of our implementation of contraction
>                     hierarchies (CHs)
>                     is  now available under the terms of the AGPL. If
>             you are
>                     interested in
>                     getting the source code write an email to Robert
>             Geisberger
>             <http://algo2.iti.kit.edu/english/geisberger.php>.
>             I had requested Robert Geisberger for the source code of CH,
>             and I went
>             thru it (Grateful to him for making the source available
>             under AGPL). It
>             takes as input .ddsg files and produces contraction
>             hierarchies in .ch
>             file format.
>             *.DDSG* *File Format:*
>                 * a /text/-file, whitespace-separated;
>                 * starts with single letter 'd';
>                 * followed by the number of nodes /n/ and the number of
>             edges /m/
>                 * for each of the /m/ edges, we have
>                       o source node ID /s/, an unsigned 32-bit integer,
>             0 <= /s/ < /n/;
>                       o target node ID /t/, an unsigned 32-bit integer,
>             0 <= /t/ < /n/;Quering
>                       o edge weight /w/, an unsigned 32-bit integer;
>             note that the
>                         length of the longest shortest path must fit
>             into a 32-bit
>                         integer
>                       o the direction /d/: //
>                             + //0 = open in both directions //
>                             + //1 = open only in forward direction (from
>             /s/ to /t/) //
>                             + //2 = open only in backward direction
>             (from /t/ to /s/) //
>                             + //3 = closed //
>                         //Note that specifying an edge (s,t,w,1) is
>             equivalent to
>                         specifying an edge (t,s,w,2). It does not matter
>             which form
>                         is used. In the current implementation, 3 is
>             interpreted as
>                         0, i.e., closed roads are used in both
>             directions. If you
>                         really want to completely close a road, just
>             leave it away. //
>         So this seems to define the minial requirements of the "ways"
>         table in that we need to easily be able to extract this data and
>         pass it to the pre-processor. And maybe the results need to be
>         able to fetch some of this data.
>             *CH File Format:*
>                 * a /binary/ file, 32-bit-interger organized
>                 * layout:
>                       o "|CH\r\n|" (|0x32 0x48 0x0d 0x0a|)
>                       o unsigned int: version (currently "|1|", shold be
>             |==| compared)
>                       o unsigned int: number of nodes (= n)
>                       o unsigned int: number of original edges (= m_1 )
>                       o unsigned int: number of shortcut edges (= m_2 )
>                       o n times, for each node 0..(n-1):
>                             + unsigned int: level
>                       o m_1 times, original edges:
>                             + unsigned int: source node
>                             + unsigned int: target node
>                             + unsigned int: weight
>                             + unsigned int: flags
>                       o m_2 times, shortcut edges:
>                             + unsigned int: shortcut middle node
>                       o unsigned int: |0x12345678| as terminator
>                 * possible (bit) flags are:
>                       o |1| = forward edge
>                       o |2| = backward edge
>                       o |4| = shortcut edge
>                       o Note that not all edges of the original graph
>             are listed as
>                         original edges. Edges that are not on any
>             shortest path may
>                         be removed or replaced by shortcuts.
>         Seem like this data could be put in tables or blob(s) depending
>         on how much there. Obviously get data in/out of the database
>         instead of these files will have an impact on the code, but
>         hopefully that is manageable.
>             *Few queries:*
>             1. If pgRouting has to support the routing using contraction
>             hierarchies, what exactly is the idea? The postgres database
>             table like
>             "ways" will be taken as input and the output would be
>             another postgres
>             database table that will include data in form of contraction
>             hierarchies?
>         I would envision that we take a table like "ways" as input. I
>         could see additional columns or tables that might contain other
>         data like turn restrictions, or whatever might be needed for
>         input. But to keep it simple something similar to the current
>         table which has edges, geometry, costs, etc. I might have nodes
>         assigned or not if you process did that.
>         Today we prep the "ways" table by creating the "source" and
>         "target" node number columns and run assign_node_id() process to
>         create nodes for each edge. I see some kind of process the reads
>         this data and creates the contraction hierarchies data that then
>         gets stored back into the database however you deem appropriate.
>             2. The queries will be same like shortest_path() just that
>             at backend
>             the contraction hierarchies pre-processed data be used?
>         Correct. The input might change because the requirements for
>         contraction hierarchies might be different, but a route request
>         would be started by a call to a stored procedure. The result
>         should be a record set where each represents traversing a single
>         segment in the original "ways" table. For example the results
>         might be simply a list of gid in the order of traversal or
>         something more. Some example results might be:
>         Each of these represents a set of record:
>         1. gid
>         2. gid, cost
>         3. gid, reversed, cost
>         etc
>         gid  - unique edge id from the "ways" table
>         cost - cumlative cost to get to the end of this segment along
>         the path
>         reversed - Y|N flag to indicate if traversed backwards or forwards
>             3. What should be the exact format for representing data for
>             contraction
>             hierarchies?
>         I'm not sure what you are asking here. If this is the internal
>         contraction hierarchies data created by the preprocessing step,
>         then I think this is up to you. You might want to store it as a
>         blob, if data can be spatially organized so you can fetch it as
>         needed, then some brainstorming on how to do that might be
>         appropriate.
>         To some extent, performance of this process in the database will
>         probably be limited to how efficiently you can access the data
>         need to process the request.
>         In the current process, we give a bounding box for the data we
>         need, because we have to read that data and then build a boost
>         graph structure and then solve that graph. Since the data is
>         preprocessed, I'm not sure that is need for this so we might
>         just have something like:
>         select start_node from CH_pnt_to_node(start_point);
>         select end_node from CH_pnt_to_node(end_point);
>         select * from CH_solve("table", start_node, end_node);
>         or something like that. Basically if there are helper function
>         needed then that is appropriate.
>         Best regards,
>           -Steve
>                 Right, but there are also a few other implementations of the
>                 contraction hierarchies in the wild that might not be
>             based on their
>                 code, like the MONAV implementation, which is released
>             on GPLv3, and
>                 at least one person was looking at it in conjunction
>             with Boost
>                 (google: contraction hierarchies boost)
>             Regards,
>             -Jay Mahadeokar
>             _______________________________________________
>             pgrouting-dev mailing list
>             pgrouting-dev at lists.osgeo.org
>             <mailto:pgrouting-dev at lists.osgeo.org>
>             http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>         pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
>     Georepublic UG & Georepublic Japan
>     eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl at georepublic.de>
>     Web: http://georepublic.de <http://georepublic.de/>
> Regards,
> -Jay Mahadeokar
More information about the pgrouting-dev mailing list
