[pgrouting-dev] Cannot create topology
Daniel Kastl daniel at georepublic.de
Fri Feb 18 21:00:52 EST 2011
2011/2/18 Stephanos Charalambous <stephanos_ch at yahoo.gr>
> Thank you Sirs.
> I tried the thinks that you have told me.
> 1. As Daniel suggested, I ran the command: psql gis
> "C:\Users\User\Desktop\900913.sql" in the psql shell and when I checked the
> file "spatial_ref_sys.sql", the entry 900913 is in the table.
> 2. As Stephen suggested, I edited the epsg file in the "proj" folder and
> added the Spherical Mercator projection entry.
> 3. I changed the assign_vertex_id command to:
>   SELECT assign_vertex_id('testNic', 1.0, 'the_geom', 'gid')
> 4. Restart Computer
> THE RESULT: The same error occurs.
> Where did I do wrong?
That's not clear to me. Would you be able to use a newer version of PostGIS?
I think they contain 900913 projection.
Or you could try to reproject your geometry once to WGS84 and then try again
and see if this makes a difference.
Daniel
> Thanks,
> Stephanos
> --- Στις Πέμ., 17/02/11, ο/η Stephen Woodbridge <woodbri at swoodbridge.com>
> έγραψε:
> > Από: Stephen Woodbridge <woodbri at swoodbridge.com>
> > Θέμα: Re: [pgrouting-dev] Cannot create topology
> > Προς: pgrouting-dev at lists.osgeo.org
> > Ημερομηνία: Πέμπτη, 17 Φεβρουάριος 2011, 20:27
> > You might also need to add it to:
> > /usr/share/proj/epsg
> > # Spherical Mercator projection
> > <900913> +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0
> > +lon_0=0.0
> > +x_0=0.0 +y_0=0 +k=1.0 +units=m +over +nadgrids=@null
> > +no_defs  <>
> > Also, when you ran assign_vetrix_id() your tolerance was
> > something like
> > 0.000001 which is appropriate if your data is in degrees,
> > but this
> > Mercator projection is in meters so your tolerance should
> > be something
> > in a range like 5.0 - 0.5, maybe start with 1.0 and see how
> > that works.
> > if you rebuild you table and try different values for
> > tolerance, you can
> > look at the number of unique node numbers. When the number
> > suddenly gets
> > smaller you probably have it too large.
> > -Steve
> > On 2/17/2011 1:14 PM, Daniel Kastl wrote:
> > > I think SRID = 900913 is not in the spatial_ref_sys
> > table, if you're
> > > using an older version of PostGIS.
> > > You can take it from here:
> http://trac.openstreetmap.org/browser/applications/utils/export/osm2pgsql/900913.sql
> >Daniel
> > > <mailto:stephanos_ch at yahoo.gr>>
> > >     Thanks Daniel for the quick
> > response.
> > >     The shapefile which i imported
> > was in google web mercator, so during
> > >     the import I set the SRID =
> > 900913. The geom constraint has the same
> > >     value too.
> > >     How can I do the necessary
> > checks?
> > >     With Regards,
> > >     On 17 Φεβ 2011, at 16:58,
> > Daniel Kastl <daniel at georepublic.de
> > >     <mailto:daniel at georepublic.de>>
> > wrote:
> > >>     Hello Stephanos,
> > >>     As the error says, there
> > seems to be something wrong with your
> > >>     SRID. You should check if
> > the constraint on "the_geom" and the
> > >>     entry in the
> > "geometry_columns" table are OK? Does it have an SRID
> > >>     or is it set -1?
> > >>     Daniel
> > >>     2011/2/17 Stephanos
> > Charalambous
> > >>     <<mailto:stephanos_ch at yahoo.gr>stephanos_ch at yahoo.gr
> > >>         Hello,
> > >>         I am kind of
> > new in using pgrouting and I would really like
> > >>         your help.
> > >>         I have
> > imported a road network, called "testNic" (from
> > >>         shapefile)
> > into a PostgreSQL database using QGIS and pgAdmin.
> > >>         Then, I
> > added the necessary columns, source, target and cost,
> > >>         and created
> > the geom_idx. The problem that I am facing is that
> > >>         I cannot
> > create the topology using the query:
> > >>         SELECT
> > assign_vertex_id('testNic', 0.00001, 'the_geom', 'gid');
> > >>         I get the
> > following error, and i can't locate where the
> > >>         mistake is.
> >    NOTICE:  CREATE TABLE will create
> > implicit sequence
> >    "vertices_tmp_id_seq" for serial column
> > "vertices_tmp.id
> > >>         <http://vertices_tmp.id>"
> >    CONTEXT:  SQL statement "CREATE TABLE
> > vertices_tmp (id serial)"
> > >>         PL/pgSQL
> > function "assign_vertex_id" line 14 at EXECUTE statement
> > >>         ERROR:
> > find_srid() - couldnt find the corresponding SRID - is
> > >>         the geometry
> > registered in the GEOMETRY_COLUMNS table?  Is
> > >>         there an
> > uppercase/lowercase missmatch?
> >    CONTEXT:  PL/pgSQL function
> > "assign_vertex_id" line 20 at
> > >>         assignment
> > Error **********
> > >>         ERROR:
> > >>         the geometry
> > >>         there an
> > >>         SQL state:
> > P0001
> > >>         Context:
> > PL/pgSQL function "assign_vertex_id" line 20 at
> > >>         assignment
> > >>         Any help
> > would be really appreciated.
> > >>         Regards
> > >>         Stephanos
> > Charalambous
> >    _______________________________________________
> >    pgrouting-dev mailing list
> >    <mailto:pgrouting-dev at lists.osgeo.org>pgrouting-dev at lists.osgeo.org
> > >>         <http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
> > >>     Georepublic UG &
> > Georepublic Japan
> > >>     eMail:
> > >>     <mailto:daniel.kastl at georepublic.de>daniel.kastl at georepublic.de
> > >>     Web: <http://georepublic.de/>http://georepublic.de
> > list
> > > Georepublic UG & Georepublic Japan
> > > eMail: daniel.kastl at georepublic.de
> > > Web: http://georepublic.de <http://georepublic.de/>
URL: http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20110219/ee209029/attachment.html
More information about the pgrouting-dev mailing list
