[pgrouting-dev] Cannot create topology
Daniel Kastl daniel at georepublic.de
Tue Feb 22 02:37:14 EST 2011
2011/2/22 Stephanos Charalambous <stephanos_ch at yahoo.gr>
> Mr Daniel,
> Sorry for bothering you again.
> I also try to build topology on a WGS84 shapefile with no result
> This could be a problem with my geometry data?
Hi Stephanos,
I'm sorry to hear that your so much struggling with this.
As this function seems to work for the majority of users, it could be a
problem with your data as you said.
Have you tried to look at the workshop? The data there is in WGS84
projection, but there is a data.tar.gz file with sample data with and
without topology. You could try it once and compare it with your data.
You can download the sample data from here:
http://download.osgeo.org/pgrouting/foss4g2010/workshop/
Daniel
> --- Στις *Σάβ., 19/02/11, ο/η Daniel Kastl <daniel at georepublic.de>*έγραψε:
> Από: Daniel Kastl <daniel at georepublic.de>
> Θέμα: Re: [pgrouting-dev] Cannot create topology
> Προς: "pgRouting developers mailing list" <pgrouting-dev at lists.osgeo.org>
> Κοιν.: "Stephanos Charalambous" <stephanos_ch at yahoo.gr>
> Ημερομηνία: Σάββατο, 19 Φεβρουάριος 2011, 4:00
> 2011/2/18 Stephanos Charalambous <stephanos_ch at yahoo.gr<http://mc/compose?to=stephanos_ch@yahoo.gr>
> Thank you Sirs.
> I tried the thinks that you have told me.
> 1. As Daniel suggested, I ran the command: psql gis
> "C:\Users\User\Desktop\900913.sql" in the psql shell and when I checked the
> file "spatial_ref_sys.sql", the entry 900913 is in the table.
> 2. As Stephen suggested, I edited the epsg file in the "proj" folder and
> added the Spherical Mercator projection entry.
> 3. I changed the assign_vertex_id command to:
>   SELECT assign_vertex_id('testNic', 1.0, 'the_geom', 'gid')
> 4. Restart Computer
> THE RESULT: The same error occurs.
> Where did I do wrong?
> That's not clear to me. Would you be able to use a newer version of
> PostGIS? I think they contain 900913 projection.
> Or you could try to reproject your geometry once to WGS84 and then try
> again and see if this makes a difference.
> Daniel
> Thanks,
> Stephanos
> --- Στις Πέμ., 17/02/11, ο/η Stephen Woodbridge <woodbri at swoodbridge.com<http://mc/compose?to=woodbri@swoodbridge.com>>
> έγραψε:
> > Από: Stephen Woodbridge <woodbri at swoodbridge.com<http://mc/compose?to=woodbri@swoodbridge.com>
> > Προς: pgrouting-dev at lists.osgeo.org<http://mc/compose?to=pgrouting-dev@lists.osgeo.org>
> > Ημερομηνία: Πέμπτη, 17 Φεβρουάριος 2011, 20:27
> > You might also need to add it to:
> > /usr/share/proj/epsg
> > # Spherical Mercator projection
> > <900913> +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0
> > +lon_0=0.0
> > +x_0=0.0 +y_0=0 +k=1.0 +units=m +over +nadgrids=@null
> > +no_defs  <>
> > Also, when you ran assign_vetrix_id() your tolerance was
> > something like
> > 0.000001 which is appropriate if your data is in degrees,
> > but this
> > Mercator projection is in meters so your tolerance should
> > be something
> > in a range like 5.0 - 0.5, maybe start with 1.0 and see how
> > that works.
> > if you rebuild you table and try different values for
> > tolerance, you can
> > look at the number of unique node numbers. When the number
> > suddenly gets
> > smaller you probably have it too large.
> > -Steve
> > On 2/17/2011 1:14 PM, Daniel Kastl wrote:
> > > I think SRID = 900913 is not in the spatial_ref_sys
> > table, if you're
> > > using an older version of PostGIS.
> > > You can take it from here:
> http://trac.openstreetmap.org/browser/applications/utils/export/osm2pgsql/900913.sql
> >Daniel
> > > <mailto:stephanos_ch at yahoo.gr<http://mc/compose?to=stephanos_ch@yahoo.gr>
> > >     Thanks Daniel for the quick
> > response.
> > >     The shapefile which i imported
> > was in google web mercator, so during
> > >     the import I set the SRID =
> > 900913. The geom constraint has the same
> > >     value too.
> > >     How can I do the necessary
> > checks?
> > >     With Regards,
> > >     On 17 Φεβ 2011, at 16:58,
> > Daniel Kastl <daniel at georepublic.de<http://mc/compose?to=daniel@georepublic.de>
> > >     <mailto:daniel at georepublic.de<http://mc/compose?to=daniel@georepublic.de>
> > wrote:
> > >>     Hello Stephanos,
> > >>     As the error says, there
> > seems to be something wrong with your
> > >>     SRID. You should check if
> > the constraint on "the_geom" and the
> > >>     entry in the
> > "geometry_columns" table are OK? Does it have an SRID
> > >>     or is it set -1?
> > >>     Daniel
> > >>     2011/2/17 Stephanos
> > Charalambous
> > >>     <<mailto:stephanos_ch at yahoo.gr<http://mc/compose?to=stephanos_ch@yahoo.gr>
> >stephanos_ch at yahoo.gr <http://mc/compose?to=stephanos_ch@yahoo.gr>
> > >>         Hello,
> > >>         I am kind of
> > new in using pgrouting and I would really like
> > >>         your help.
> > >>         I have
> > imported a road network, called "testNic" (from
> > >>         shapefile)
> > into a PostgreSQL database using QGIS and pgAdmin.
> > >>         Then, I
> > added the necessary columns, source, target and cost,
> > >>         and created
> > the geom_idx. The problem that I am facing is that
> > >>         I cannot
> > create the topology using the query:
> > >>         SELECT
> > assign_vertex_id('testNic', 0.00001, 'the_geom', 'gid');
> > >>         I get the
> > following error, and i can't locate where the
> > >>         mistake is.
> >    NOTICE:  CREATE TABLE will create
> > implicit sequence
> >    "vertices_tmp_id_seq" for serial column
> > "vertices_tmp.id
> > >>         <http://vertices_tmp.id>"
> >    CONTEXT:  SQL statement "CREATE TABLE
> > vertices_tmp (id serial)"
> > >>         PL/pgSQL
> > function "assign_vertex_id" line 14 at EXECUTE statement
> > >>         ERROR:
> > find_srid() - couldnt find the corresponding SRID - is
> > >>         the geometry
> > registered in the GEOMETRY_COLUMNS table?  Is
> > >>         there an
> > uppercase/lowercase missmatch?
> >    CONTEXT:  PL/pgSQL function
> > "assign_vertex_id" line 20 at
> > >>         assignment
> > Error **********
> > >>         ERROR:
> > >>         the geometry
> > >>         there an
> > >>         SQL state:
> > P0001
> > >>         Context:
> > PL/pgSQL function "assign_vertex_id" line 20 at
> > >>         assignment
> > >>         Any help
> > would be really appreciated.
> > >>         Regards
> > >>         Stephanos
> > Charalambous
> >    _______________________________________________
> >    pgrouting-dev mailing list
> >    <mailto:pgrouting-dev at lists.osgeo.org<http://mc/compose?to=pgrouting-dev@lists.osgeo.org>
> > >>         <http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
> > >>     Georepublic UG &
> > Georepublic Japan
> > >>     eMail:
> > >>     <mailto:daniel.kastl at georepublic.de<http://mc/compose?to=daniel.kastl@georepublic.de>
> > >>     Web: <http://georepublic.de/>http://georepublic.de
> > list
> > > Georepublic UG & Georepublic Japan
> > > eMail: daniel.kastl at georepublic.de<http://mc/compose?to=daniel.kastl@georepublic.de>
> > > Web: http://georepublic.de <http://georepublic.de/>
URL: http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20110222/73b23592/attachment-0001.html
More information about the pgrouting-dev mailing list
