[pgrouting-dev] Time dependent data and input format
Daniel Kastl daniel at georepublic.de
Tue Jul 19 00:08:23 EDT 2011
Hi Steve, Jay,
What you wrote I fully agree with. Can't write it better.
Generic is fine for the basic functions, but to make it usable with road
data for example, some custom wrappers are the best.
Such a wrapper can be also for OSM data only and just a certain use case.
The current wrapper functions are far from perfect, but they exist now for
many years already.
So just pick a few use cases. Those wrappers can evolve over time. They
should been seen as examples, that can be modified by users. And they can be
used for documentation and demo queries.
Daniel
On Tue, Jul 19, 2011 at 12:35 PM, Stephen Woodbridge <
woodbri at swoodbridge.com> wrote:
> Jay, Daniel,
> I think we need to get our heads around this or it will be very hard for
> Jay to complete this as a useful tool.
> Jay says:
>> What im not clear is, how do we package this in the overall
>> pgRouting project?
> This is exactly the problem. So here is my 2 rupees :) on this:
> I think the core algorithm needs to be generic so it works with any time
> frames that someone might want to use. Then we layer over that application
> implementations using wrappers or additional code. So since most people
> today are using pgRouting for vehicle routing applications I think we need
> to implement and easy to use wrapper that deals with vehicle applications of
> date and time of day dependencies. This does not preclude someone else
> coming in later and writing a new wrapper to deal with their application
> working in years or microsecond intervals.
> For this project we need a concrete implementation that allow someone to
> create a table of time based restrictions of some kind on edges and
> reasonable easy say generate a route start at X and use these time dependent
> restrictions.
> I do not think it needs to deal with every single possible case, but it
> should be a reason set of cases. We can always expand on this after GSoC. I
> think it would be good in the documentation, we add some notes about things
> we thought of be did not support and a short paragraph of our thoughts on
> how to support it in the future.
> You need to size this to the time you have available so you can be
> successful. I will let Daniel be the final arbiter on this as I will be out
> of town again later this week and my time here seems to on overload lately.
> The key idea here is layer of tasks, and structure. We need to bridge the
> gap between low-level generic code and higher level application specific
> presentation of which there my be many depending on the application in
> discussion.
> Best regards,
>  -Steve
> On 7/18/2011 11:03 PM, Jay Mahadeokar wrote:
>> On Mon, Jul 18, 2011 at 11:21 PM, Stephen Woodbridge
>> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.**com<woodbri at swoodbridge.com>>>
>> wrote:
>>    Hi Jay,
>>    I there are a few important points to this problem:
>>    1. the time based adjustments need to be stored in in real human
>>    terms, ie: similar to crontab time specification or similar to the
>>    Travel Time Analysis you found.
>>    2. the query to pass the appropriate time dependent info can easily
>>    be normalized to the the route start time by subtracting the route
>>    start time from the feature start and end times, except when it get
>>    complicated like rolling over from a week day schedule to a weekend
>>    schedule on a friday to saturday transition. Likewise for holiday
>>    and event schedules.
>>    This seems to be the hard part if there is a complicated schedule.
>>    So what we need is to define that are the inputs and outputs of this
>>    query, something like:
>>    INPUTS:
>>       Start date:
>>       Start time:
>>       Max duration time:
>>       Start location of route:
>>       Ending location of route:
>>    OUTPUTS:
>>       Segment id:
>>       time offset from:
>>       time offset to:
>>       avg speed:
>>       transit time:
>>       restriction:
>> Hi Steve,
>> Well, this was our initial plan, but we had not kept the query like this
>> since we wanted to keep the query general. I think you or Daniel had
>> pointed out that we should not restrict our query to time units like
>> date, hours etc since in some application, time interval could be
>> milliseconds or in some other application it could be years etc. So, I
>> think if we leave retrieval from time_dep_costs table as sql query
>> parameter, that would be more flexible as we had concluded earlier.
>>    3. I assume because your code only looks at an interval from the
>>    start, that it is not limited to an restricted time window like 12
>>    hr, or 24 hr, etc.
>>    more below ...
>>    On 7/18/2011 7:49 AM, Jay Mahadeokar wrote:
>>        Hi all,
>>        Hi, I am working on creating wrapper functions for tdsp,
>>        corresponding
>>        to the wrapper with and without bounding box as in
>>        dijkstra_shortest_paths.
>>        As discussed many times, the TDSP algorithm expects the
>>        start_time as 0
>>        and all times offset from start time. For the data I had
>>        created, I had
>>        taken time from 0 to 24, corresponding to 24 hours and assigned
>>        different travel_time for different time periods as per my
>>        intuition.
>>        If start time is say 23:30, our query for retrieving entries from
>>        time_dep_costs should properly do calculation such that travel
>>        times are
>>        taken cyclically.
>>    What to you mean by cyclically? I think the times should be linear
>>    and repeating if they are cyclical. Is this what you mean?
>> Yes.
>>    For example, a route starting Monday at 8AM and a segment has
>>    9AM-10AM restriction and the route max duration is 48hrs then we
>>    should see two records:
>>    ID, From, To,   MPH, ...
>>    27, 0900, 1000, 25, ...
>>    27, 3300, 3400, 25, ...
>> Instead of seeing keeping this as two records, we can add a parameter
>> called is_cyclic in query. If that is true, then once we run out of the
>> range, we can go back to zero.
>> That would need many modifications in current code, but I guess it is
>> manageable.
>> Would that be ok?
>>    I'm not even sure how I would compute this, I think this puts a lot
>>    of burden on the user to figure this out and get it correct. The
>>    obvious flip side of this would be for us to define a rigid format
>>    for entering schedule information where we target support for
>>    something like 80+% of the common schedule definitions and then
>>    figure this out once for everyone. I'm not sure if you feel this
>>    will fit in your schedule or not?
>> We can sure provide functionality for some common formats, I will try
>> and do that within GSoc timeline if it works out, or we can work on that
>> later too. What im not clear is, how do we package this in the overall
>> pgRouting project?
>>    Thoughts?
>>    -Steve
>>        Now, this query should depend on the format of the time
>>        dependent data
>>        and its units. I think it is best that we keep this task with
>>        the user
>>        so that he writes proper sql query such that the values are
>> properly
>>        retrieved as required by the function.
>>        Do you see any specific cases, data formats  where we can
>>        provide the
>>        wrapper functions for above task?
>>        On Sun, Jun 12, 2011 at 8:26 PM, Stephen Woodbridge
>>        <mailto:woodbri at swoodbridge. com
>>        <mailto:woodbri at swoodbridge.**com <woodbri at swoodbridge.com>>>>
>> wrote:
>>            On 6/12/2011 12:33 AM, Jay Mahadeokar wrote:
>>                On Sun, Jun 12, 2011 at 1:07 AM, Stephen Woodbridge
>>        <mailto:woodbri at swoodbridge. com <mailto:woodbri at swoodbridge.**com<woodbri at swoodbridge.com>
>>        <mailto:woodbri at swoodbridge <mailto:woodbri at swoodbridge>. com
>>        <mailto:woodbri at swoodbridge.**com <woodbri at swoodbridge.com>>>>>
>> wrote:
>>                    On 6/11/2011 12:58 PM, Jay Mahadeokar wrote:
>>                        On Thu, Jun 9, 2011 at 9:16 AM, Jay Mahadeokar
>>        <jai.mahadeokar at gmail.com <mailto:jai.mahadeokar at gmail.**com<jai.mahadeokar at gmail.com>
>>        <mailto:jai.mahadeokar at gmail. com <mailto:jai.mahadeokar at gmail.**
>> com <jai.mahadeokar at gmail.com>>>
>>        <mailto:jai.mahadeokar at gmail <mailto:jai.mahadeokar at gmail>. com
>>        <mailto:jai.mahadeokar at gmail.**com <jai.mahadeokar at gmail.com>>>>
>>        <mailto:jai.mahadeokar at gmail.**com <jai.mahadeokar at gmail.com>>>>>>
>> wrote:
>>                            Hi,
>>                            Just a recap to our planned tdsp query model:
>>                                I agree. So, now can we assume we have
>>        following
>>                database
>>                                tables, as per things discussed till now:
>>                                   1. Ways: (On lines of the one in
>>                pgrouting-workshop)
>>                                    * gid
>>                                    * source
>>                                    * target
>>                                    * name
>>                                    * the_geom
>>                                    * static_length    (In case time
>>        dependent
>>                routing
>>                        is not used)
>>                                    * any other attributes..
>>                                     2.  TimeVaryingCosts (Any other
>>        suitable name?)
>>                                    * gid
>>                                    * start_time_and_date  (May divide
>>        this into two
>>                        columns:
>>                                      day_of_week and time_of_day ? )
>>                                    * travel_time / arrival_time
>>                                     3. TurnRestrictions (Time dependent)
>>                                    * node/source
>>                                    * time_from
>>                                    * time_to
>>                                    * node_to
>>                                    * ancestors
>>                                If only static shortest path query is
>>        made, then
>>                only
>>                        table 1 is
>>                                required.
>>                                If time-dependent shortest path query is
>>        made,
>>                table 1 and 2
>>                                will be used.
>>                                If in time-dependent shortest path query
>>        with turn
>>                        restrictions
>>                                is made , all 3 tables will be used.
>>                            So, for a general time dependent query, we will
>>                fetch edge
>>                            information from ways table and the time
>>        dependent costs
>>                        information
>>                            from the
>>                            TimeDepCosts table. (See previous msg above.)
>>                            The query on ways table can be supplied by
>>        the usual
>>                as on
>>                        normal
>>                            dijkstra shortest_path() query.
>>                            How do we form the query on the TimeDepCosts
>>        table?
>>                I see
>>                        two options:
>>                            1. We generate the query according to the gids
>>                obtained from the
>>                            query on ways table. We will have to query
>>        all the
>>                time slots
>>                            available, or form a query so that the
>>        time-window is
>>                        appropriate
>>                            and we have sufficient travel_time info so
>>        that we
>>                can reach
>>                            destination.
>>                            Here we can form query like
>>                            Select * from TimeDepCosts where gid in
>>        (list of gids
>>                        queried from
>>                            ways table).
>>                            We can allow user to more filtering parameters
>>                according to
>>                            start_time , date ?
>>                            But this will make our query specific to the
>>                database design. As
>>                            already discussed, we cant predict the time
>>        units /
>>                        requirements of
>>                            applications and so it would be better if we
>>        keep
>>                the query
>>                            independent of the database design.
>>                            Thats the reason our weight_map assumes
>>        start time from
>>                        source as 0,
>>                            and all travel times offset from the start
>>        time from
>>                source. A
>>                            function that will generate such weight map
>>        is to be
>>                written.
>>                            2. We allow user to pass the query for
>>        TimeDepCosts
>>                table
>>                        too. So,
>>                            we will have our pgsql function as:
>>                            CREATE  OR  REPLACE  FUNCTION  shortest_path(
>>                ways_sql  text,
>>                        time_dep_cost_sql text,
>>                source_id
>>                          integer,
>>                target_id
>>                          integer,
>>                directed
>>                          boolean,
>>                        has_reverse_cost  boolean)
>>                                     RETURNS  SETOF  path_result
>>                            This way, user can have more control on the
>>        amount
>>                of data being
>>                            queried. We will only consider the time
>>        dependent
>>                windows
>>                        that fit
>>                            the query.
>>                            Example of the time_dep_cost_sql can be:
>>                            Select * from TimeDepCosts where "
>>                USER_SUPPLIED_CONSTRAINTS".
>>                            The user can now supply his constraints
>>        according to
>>                        time_window he
>>                            needs, start times, holidays etc according
>>        to the
>>                database
>>                        table design.
>>                            The problem with this is, we cannot filter
>>        out edges
>>                        according to
>>                            bounding box etc since the_geom field is not
>>        there
>>                in this
>>                        table.
>>                            This is because that information would be
>>        redundant.
>>                            Thoughts? Any idea that combines the merits
>>        of both
>>                approaches?
>>                        Hi all,
>>                        I am writing some background code will be needed
>>        for the
>>                above
>>                        functionality.
>>                        Any input on the above mentioned point? I suppose I
>>                should not start
>>                        coding for any specific approach until we agree
>>        upon a
>>                viable query
>>                        strategy.
>>                    Hi Jay,
>>                    I always find it easiest to answer these questions by
>>                thinking about
>>                    the problem in terms of use cases, so:
>>                    A web app, where someone enters a start and
>>        destination and some
>>                    constraints like departure time or arrival time and
>>        maybe
>>                    restrictions on modes of travel.
>>                    Are there other ones we are trying to support? These
>>        should
>>                probably
>>                    be documented as part of the project description.
>>                I agree, we need to document the use-cases. A separate
>>        thread
>>                for this
>>                discussion?
>>                    Anyway, assuming the above, then the application which
>>                presumably
>>                    has some basic knowledge of the time constraints
>>        could do
>>                something
>>                    like:
>>                    Get the straight line distance between start and
>>        destination
>>                double
>>                    it and apply some average transportation speed to
>>                approximate the
>>                    time window. The numbers can be changed to be
>>        acceptable by the
>>                    application as long as it over estimates the duration
>> of
>>                travel. It
>>                    can then, specify the CONSTRAINTS in terms of a
>>        start and
>>                end time.
>>                    We do something similar with our spatial bounding
>>        box used to
>>                    collect the edges needed to build the graph.
>>                    Now as far as collecting the constraints and making
>> then
>>                accessible
>>                    for the Boost_dijkstra, that is another problem. This
>>                problem boils
>>                    down to the following:
>>                Just a correction, in this case we will not be using
>>                boost_dijkstra, but
>>                instead core_tdsp() function which we have build ourselves.
>>                    1. is there an acceptable abstraction that we can use
>>                internally to
>>                    represent various data sets that we might want to
>>        load. Or
>>                can we
>>                    define a schema that will work for some set of
>>        constraints
>>                we wish
>>                    to implement initially.
>>                Well, we had agreed upon the following schema for
>>        testing purpose:
>>            Yes, you are correct, sorry I was not paying attention when
>>        I wrote
>>            that.
>>                   1.
>>                      Ways: (On lines of the one in pgrouting-workshop)
>>                          * gid
>>                          * source
>>                          * target
>>                          * name
>>                          * the_geom
>>                          * static_length (In case time dependent
>>        routing is not
>>                used)
>>                   2.
>>                      TimeDepCosts
>>                          * gid
>>                          * day_of_week
>>                          * time_of_day
>>                The time_dep_costs table schema can vary according to
>>                application and
>>                its needs and the nature of data available.
>>                    2. do want to move this data into some static memory
>>                structures for
>>                    the analysis like we do for the graph and then
>>        dispose of
>>                them after
>>                    the analysis.
>>                We are doing exactly that! The Weight_Map data structure
>>        that is
>>                supplied to the core_tdsp() is designed specifically to
>>        fulfil the
>>                above functionality.  It assumes the start time as 0,
>>        and all other
>>                times offset from start time.  So, there will be schema
>>        specific
>>                wrapper
>>                functions that will help generate the weight_map data
>>        structure.
>>                Which brings me back, to my original question (couple of
>>                messages back),
>>                what is the best way to generate weight_map, ie retrieve
>>        data
>>                from time
>>                dependent cost table.
>>                Well, I think for now, I am going to go with approach
>>        #1. i.e
>>                user will
>>                supply his query. This might retrieve unwanted data,
>>        since we cant
>>            Yes, I think this is the way to go. It is up to the user that
>>            presumable knows his data to formulate an efficient query to
>>            retrieve the needed data.
>>                filter by the_geom in table#2. But, I think we can
>>        refine this
>>                by adding
>>                constraints like: where gid IN (list_of_edgeids_retrieved_
>>                from_ways)
>>            A query something like:
>>            select a.*
>>              from table2 a, table1 b
>>              where b.the_geom && <BBOX_OF_REGION>
>>               and b.gid=a.gid
>>               and <TIME_CONSTRAINTS>;
>>            This would allow the planner to pick the best index.
>>                So, I guess this approach combines the merits of both
>>        approaches
>>                discussed before. We can provide flexibility to
>>        application as
>>                well as
>>                add constraint on the number of rows retrieved.
>>                Thoughts?
>>            Yes, I think this is a good plan.
>>            I think that the bulk of the roads in the network will
>>        probably not
>>            have time dependent data associated with them. If you look
>>        at what
>>            Navteq and the Traffic people (however they are) are doing,
>>        you will
>>            notice that mostly they only track major highways in/out of
>>        major
>>            metropolitan areas. They do not track that information on minor
>>            roads or rural areas. So I think that the number of segments
>>        that
>>            are likely to have time dependent data for any given request is
>>            going to be in the 5% of the total segments. Even if someone
>>        were to
>>            collect say GPS cellphone average speeds over a much wider
>>        range of
>>            segments, I still think it is manageable. Anyway we just have
>> to
>>            solve the problem, they have to represent that data in a way
>>        the we
>>            can handle it quickly or this will not be a solution for them.
>>            -Steve
>>                    3. or do we want to construct a method that can
>>        dynamically
>>                request
>>                    constraint information from the database when it is
>>        needed by a
>>                    visitor. (2. is probably much more efficient and the
>>        better
>>                way to
>>                    go from a complexity and stability point of view).
>>                    Don't wait on me for additional input as I will be gone
>>                through June
>>                    21st. Keep it simple and modular and we can change
>>        or add to
>>                it in
>>                    the future and I;m sure whatever you come up with
>>        will be fine.
>>                    After all it is code and it can be changed it we
>>        need to. :)
>>                    Project seems to be moving along fine.
>>                    -Steve
>>                    ______________________________ _________________
>>                    pgrouting-dev mailing list
>>        pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.**
>> osgeo.org <pgrouting-dev at lists.osgeo.org>>
>>        <mailto:pgrouting-dev at lists. osgeo.org
>>        <mailto:pgrouting-dev at lists.**osgeo.org<pgrouting-dev at lists.osgeo.org>
>>        <mailto:pgrouting-dev at lists <mailto:pgrouting-dev at lists>.
>>        osgeo.org <http://osgeo.org>
>>        http://lists.osgeo.org/ mailman/listinfo/pgrouting-dev
>>        <http://lists.osgeo.org/ mailman/listinfo/pgrouting-dev
>>        <http://lists.osgeo.org/**mailman/listinfo/pgrouting-dev<http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
>>                Regards,
>>                -Jay Mahadeokar
>>        Regards,
>>        -Jay Mahadeokar
>>    pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.**osgeo.org<pgrouting-dev at lists.osgeo.org>
>> Regards,
>> -Jay Mahadeokar
>> ______________________________**_________________
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20110719/8580ab17/attachment-0001.html
More information about the pgrouting-dev mailing list
